Question about Delphi Roady SA10035 XM Radio Receiver
No power transformer good
No power. transformer good. won't turn on .
  • Delphi Expert
  • 509 Answers
Your power connector has probably broken off the little plastic tip on the end, and it is stuck inside the power connection around the power pin. You will have to use a needle to try to poke and pull the plastic piece out and off of the power pin, then it will work - a common problem and it has happended to me twice already!
Posted on Aug 10, 2010
It won't turn on
I would check the fuse first and if thats good then I would suspect the flyback transformer
Apr 02, 2013 | GE 46GW945 46" Rear Projection Television
Power button lights up but tv won't turn on
Older set but pretty good set, set is prone to the HV transformer going bad but not many other issues.
Sep 03, 2012 | GE 46GW 948 46" Rear Projection Television
Gem sound 1300 watts pro 480 won't turn on
The main fuse has blown, or the power transformer has a open primary, one or too audio outputs semiconductors have shorted. To narrow it down the top needs to be removed and unplugged, set digital meter to ohms and check fuses, next! the too wires going into the transformer should have a low reading, but if it reads infinity or open the primary side of the transformer is open.
Jul 08, 2012 | Gem Sound Audio Players & Recorders
Won't power up at all
If there is no power on on the primary side of the transformer look for a open fuse.
Apr 04, 2012 | Pioneer VSX-818V-K Receiver
Won't even turn on. Was flashing cup size lights on left & right and I turned it off and later tried to turn it on and it won't turn on.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 13, 2011 | Keurig B100 Coffee Maker
The power won't turn on, I've check the breaker, etc.
heatman101
Sep 09, 2011 | Keurig B60 Coffee Maker
The machine won't turn on at all. Tried t in several functioning outlets and it won't power up. Only 6 months old. Keurig B60
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
My keurig won't heat up and the switch at the back won't go on or of
heatman101
May 26, 2011 | Keurig B70 Coffee Maker
No power from transformer
I had the same thing happen on my original Roady2. I suspect the powerplug port on the Roady2 unit is not getting a good connection. Does the transformer plug have a plastic tip? You can try to cut that off with a sharp razor blade. Sometimes that will make a good tight connection. What I did was buy a used Roady2 unit on ebay. Also another cause is
the power connection is not being made by an internal problem or wear caused by constantly plugging and unplugging the power port. I use a Cambridge XM playdock boombox at home. I bet getting a different unit will solve the problem. The only problem is that finding a used unit might take some work. Good Luck
Oct 27, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi Roady SA10035 XM Radio Receiver Logo
102 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
