Question about GE Refrigerators
GE TBF16SKBL REFRIGERATOR COMPARTMENT WARM BUT FREEZER SECTION WORKING
  • GE Master
  • 1,711 Answers
The first thing that is might need tobe replaced is the thermostat. Then the valve for refrigerator.
Since you have the freezer work fine then your cooling system is good and no need to replace any expesive part.
So try to find a very good service repair near you and honest so you will be trastaed not to overcharge.
Good luck
Posted on Jul 17, 2010
Freezer is cold, refrigerator is warm.
If your evaporator fan is working (the fan in your freezer) you might want to check the air baffle. That is located in the back of your frig section. It is most likely all the way top left. Put your hand in front of it there should be air coming through the baffle. If there is no air coming through you either left your door open and froze the inside lining if your refrigerator or your air baffle control is broken.
If you left the door open and it froze the lining the only solution is to shut it down and leave both doors open for at least 24 hours straight. There is no way to get the ice out.
Nov 20, 2011 | GE Profile PSI23NCR Side by Side...
I have a GE refrigerator GFSS6KKYSS Model. Serial #: LS900091 It appears that there is ice on the back of the refrigerator and water is collecting on the floor of the compartment. What is the problem and...
This is a rather unique refrigerator in that there is a seperate evaportator (cooling coil) for the refrigerator section and the freezer section, where as almost all other refrigerators only have coils in the freezer section and use a fan to blow some of the cold air into the refrigerator section. This design will prevent cross contamination of odors between fresh foods and freezer sections, and allow lower humidity freezer at the same time as higher humidity fresh foods. All good things.
That said,..... you need to take the cover off the back wall from inside the fresh foods section and thaw out the defrost drain locted at the bottom of those cooling coils. If I remember correctly, there are a couple hidden screws, and the back panel needs to be pryed off using a putty knife, I think you will find 4 small arrows / pointers for the spots to pry at. With cover removed, use a turkey baster with warm water until the water flows out the drain.
Apr 03, 2011 | GE GFSS6KKYSS
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Temperature is reads 73 on freezer and 34 on refrigerator But... inside all are warm Help
It may be vice versa.
You need to check and make sure that the freezer section is 34 degree. The refrigerator compartment depends on the freezer in order to maintain a temperature suitable for food storage. If it is the case, you defrost heater and thermostat may be defective.
Dec 10, 2010 | GE Profile Stainless Bottom-Freezer...
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge running warm
one thing to check for if you whant the freezer to colder the fresh food compartment will not go down i temperature because you stre blocking the air floe lower the freeezer control knob thanks from gilles
Feb 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Warm refirig compartment
is there a heavy frost build up in the freezer section?? do you hear the fan running?
May 20, 2008 | Kenmore 77870 Top Freezer Refrigerator
FRESH FOOD COMPARTMENT TOO WARM
it could be a defrost heater problem . the heating cycle is not defrosting the ice that is why your having frost build up. the heater could be damaged, thermosdisc damaged, electronic timer module damaged.try thawing it up by unpluging it for a day or two until there is no more water dripping at the back then try it again, im sure the refrigerator section would cool again for a week or two before it wouyld go back to the same problem. dont forget to bring back the setting to 5 for freezer and 35 for refrigerator in order for the thermostat to work.
Feb 04, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
