Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
How do you clean inside of screen of grand wega
Can I clean the inside of the screen on my Grand Wega? How is it done?
ctf1800
  • 4402 Answers
SOURCE: Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever heard of this? Part runs about 300 bucks. TV is out of warrenty as it is 2 years old. Do you think it is worth it to fight sony and get them to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
Posted on Feb 01, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: Sony grand wega KF60DX100 Won't Power on
THE RED LIGHT THAT BLINKS IS IT THE LAMP BOX THAT THE RED LIGHT BLINKS IN OR THE STAND BY LIGHT THAT BLINKS ? IF ITS THE LAMP BOX THAT BLINKS THEN YOUR LAMP HAS BLOWN AND NEEDS REPLACED YOU CAN FIND THE PART # FOR YOUR T.V. FOR A NEW OR REFURBISHED LIGHT IN YOUR OPERATING MANUAL AND WITH THE PART # BUY A NEW ONE OFF EBAY,ALSO YOUR OWNERS MANUAL WILL GIVE YOU STEP BY STEP INSTRUCTIONS ON HOW TO REPLACE IT AS THIS IS A COMMON PROBLEM WITH PROJECTION T.V.'S IF ITS THE STAND BY LIGHT THAT BLINKS I NEED TO KNOW HOW MANY TIMES IT BLINKS AS THAT'S A SELF DIAGNOSTICS CODE THAT YOUR T.V. IS GIVING FOR THE PROBLEM AND FOR SONY THERESE NO CODE FOR 1 BLINK OF THE STAND BY LIGHT.
Posted on Mar 18, 2009
rob52078
  • 40 Answers
SOURCE: Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
SOURCE: Sony Grand WEGA KF50WE610 50 blue hue blue dots
This model also has a paper filter for the Optic block that should be changed. No one ever said anything about it. shortens the life of the optic block if not changed.
Posted on Sep 02, 2009
  • 1527 Answers
SOURCE: reset lamp hours on sony grand wega
hello
  1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
  2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
  3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
shaun
Posted on Nov 06, 2009
Dark smudges/spots on my HDTV screen
The model indicated here Sony Grand WEGA KDF-50WE655 is a LCD rear projection and rarely if ever requires cleaning.
If black spots or such are gradually appearing the issue on this model is the optical light engine.
Set uses a LCD engine which the lamp shines directly into and heat from that very hot lamp can damage sensitive baffles inside the engine.
I would suggest also you contact Sony as they have on several models extended the warranty for this kind of issue---Engine is very expensive part and several of these Sony sets were involved in a class action lawsuit--hence they are dealing with them.
Do not take no for an answer if you want them to help you---the hinge that is sqeeks gets oiled...........
Apr 02, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
I have a blue line problem with 50 inch sony wega.
Take to TV repair shop. contact Sony get RMA first for warrenty work! so free work gets done!
Oct 09, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Aug 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
A-1084-658-A
Mar 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Cob webs
Hi, remove rear top cover, this will give you access to clean the unit, be advised you should use 2 people once you get all the screws out, the back is HEAVY because there is a mirror attatched to the rear cover(on the inside) and if you drop the cover it`s expensive to replace, good luck, BMW Rider
Jan 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
144 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
