Need repair help. Panasonic RM 1500A and RM G30P motor cycle audio systems/radio
2 Suggested Answers
  • 653 Answers
SOURCE: Need p/n for RM-G30P female connector for the
Another suggestion can you or the shop try to build a cable that would fit your need? If the shop have the wiring diagram and you know what the connectors should look, improvise then to get it working. Cheers.
Posted on Mar 28, 2010
Testimonial: "Thanks..The shop and I talked about doing this yesterday. I'll wait and see what he comes up with"
Panasonic CN-HDS700TD touchscreen car audio system comes on when you start the car but becomes unresponsive after about 10 minutes,shuts down only to reboot again and cycle repeats.please help.
[PDF]Compact Stereo System - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/audio/om/schc25_mul_om.pdf
PanasonicOne that lets the sound come through loud and clear .... This function switches off thesystem (except in radio source) if you do not use the system for .... All phone features can only be controlled by the touch screen of the. iPhone. • The system ...
[PDF]Model: CQ-VD6505U - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/caraudio/om/cq-vd6505u_en_om.pdf
Panasonicwater, is smoking, or smells), turn it off immediately and consult your dealer. ...components of your car audio system carefully before using the system.Missing: touchscreen
Jan 05, 2016 | Cars & Trucks
Need p/n for RM-G30P female connector for the radio 96 GL1500 or where to purchase one.
Mar 26, 2010 | Honda GL 1500 Gold Wing Motorcycles
I have a 04 acura and the lights in the radio clock an heat controls does not work.
ACURA Service Bulletin
04-021
Applies To: 2004 TSX - From VI N JH4CL9...4C000001 thru JH4CL9...4C028982
July 9,2004
Audio-HVAC Display Module Is Dim or Dark
SYMPTOM
The audio display and controls (knobs, buttons, bars)
of the audio-HVAC display module are dim or are dark.
PROBABLE CAUSE
Faulty audio unit.
CORRECTIVE ACTION
Replace the audio unit. Refer to S/B 87-015, Audio Unit
In-Warranty Exchange/Out-of-Warranty Repair.
If a client calls ahead to schedule an appointment, and
the vehicle is in the affected VIN range, order the
remanufactured audio unit right away so it is available
when the client comes in.
PARTS INFORMATION
Order the appropriate replacement audio unit:
NOTE; The audio unit is listed as a Tuner Assembly in
the Interactive Network (/N) Parts Catalog. This unit is
both a tuner and a 6-disc CD changer.
Tuner Assembly (without navigation system):
P/N 39175-SEC-A02RM
Tuner Assembly (with navigation system):
P/N 39175-SEC-A82RM
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies
Operation Number: 010149
Flat Rate Time: 0.5 hour
Failed Part: Use the RM part number (from the
repair order) without the RM.
Example; 39175-SEC-A01
Defect Code: 03214
Symptom Code: 03272
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starlina work.
REPAIR PROCEDURE
1. Go to S/B 87-015, Audio Unit in-Warranty
Exchange/Out-of-Warranty Repair, for guidance on
how to get the remanufactured audio unit.
2. if you can read the audio display, write down your
client's radio station presets.
3. Remove the audio-HVAC display module (see page
22-267 of the 2004 TSX Service Manual). (In ISIS,
use the keyword DIS MOD, and select Audio-
HVAC Display Module Removal/Installation frorn
the list.)
4. Remove the faulty audio unit from the audio- HVAC
display module (see page 22-268). (In ISIS, use the
keyword DIS PAN, and select Audio-HVAC
Display Panel Removal/Installation from the list.)
5. Transfer the left and right brackets from the faulty
audio unit to the remanufactured audio unit. If the
remanufactured unit has a shipping cover and
shipping screws, make sure you transfer them to
the faulty unit being returned.
6. Install the remanufactured audio unit in the audio-
HVAC display module. Then reinstall the audio-
7. Enter the anti-theft code for the new audio unit.
Enter your client's radio station presets if you
recorded them in step 2.
8. Make sure all of the functions of the audio unit and
HVAC work properly.
9. Replace the sticker on your customer's anti-theft
radio identification card with one of the new stickers
that show the anti-theft code. Apply the other
sticker that shows the anti-theft code onto the
vehicle history file copy of the repair order.
10. Remove all old serial number stickers from the side
of the glove box or inside the center console. Then
apply the new sticker that shows only the serial
number to the side of the glove box.
11. Return the faulty audio unit to the parts
department. Refer to S/B 87-015 for parts return
in structions
Jan 29, 2010 | 2004 Acura TSX
MOVED HOUSE LOST THREAD TYPE AERIAL FOR MY SMALL PANASONIC CD STERIO SYSTEM MODEL SAPM01. WHERE CAN I OBTAIN A NEW ONE? CANT LISTEN TO THE FM RADIO ANY MORE! HELP!
put a 3 foot piece of wire on it.does the same thing.any parts house will have an antenna ,and for sure an authorized panasonic repair depot...they are listed in the back of the warranty book for the radio
Jul 04, 2009 | Panasonic Audio Players & Recorders
Preset channels on Panasonic car radio out of tune
this is simple enough to do, just find the channel you want to save, then press and hold a number u want to save it to!
i.e No. 1 - 96.9Fm
hope this helps
Feb 15, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
Panasonic washing machine stops prior to spin cycle
First my washer stopped working during the spin cycle, and some of the water still in the tub,i have to wait for about half an hour to have the whole process done after continuing the washing process,then after 2 weeks not doing any laundry, when i tried to switch on the on/off button,it doesn't do anything at all!I tried changing the plug fuse(thinking maybe it needed to be changed after 4 years using it) but nothing happened.please help me . TQ
Mar 20, 2008 | Washing Machines
F61!!!!!
I think I have the solution after extensive research and troubleshooting. I will update you as soon as I fix my system.
Cheers...
Dec 28, 2006 | Panasonic SC-AK600 CD Shelf System
305 people viewed this question
 Grubhead
Grubhead
