Question about Maytag M6P09S2ACOM Air Conditioner
Water is spilling out of the back of the unit.
I drain the unit every other day. My model no. ends with REV B
The serial no. is MR769027 355W
  • 70 Answers
The only thing to do is put the unit in a permanent place and run a drain some where.
Posted on Jul 18, 2010
Ge portable air model APH1GAAG1. Can't find a the water bucket. Has been at 83f for past 2 days. The spout in back leaks water. Home depot suggested I put the unit on small table and bucket...
Call GE customer support at 1-800-626-2005 or... go to this link:
http://genet.geappliances.com/DocSearch/Dispatcher
and enter this model number APH10AA
The manual file is 1.28 mb.
This is straight from the manual page 6:
Drainage/Routine Maintenance
This air conditioner produces water during normal
operation. The unit should be drained if it is not
going to be run for an extended period of time.
The unit should also be drained prior to storage
at the end of the cooling season.
To drain the unit, follow the instructions below:
1. Unplug the power cord and roll the unit to a
drain or outside.
2. Pull out the drain cap and allow water
to drain from the unit.
3. Securely replace the drain cap.
Thanks for choosing FixYa,
Kelly
Jul 21, 2011 | Heating & Cooling
I have a Kenmore freezer top refrigerator with: Model #: 106.78202891, Serial #: EJ0320474. The problem is that the drain in the back of the freezer is freezing up and water is frozen on the bottom of...
this is a common problem that we see on a daily basis in my appliance business... over time food particles/open pkgs. etc trash will get into drain and clog it... what has happened is the drain hole located in the back bottom of freezer is stopped up and everytime the unit goes into defrost the water from the heater defrosting your coils is suppose to go down the hole since it is stopped up it is backing up into freezer and some spilling over into refrig. the whats left in freezer will freeze and continue to grow in size larger and larger...your going to have to remove panel to back of freezer inside .which is going to require removing all food and shelving/ice maker etc... unplug unit and start with a hair dryer thawing unit out. you will eventually see the hole and there will be ice in it..the water is suppose to drain all the way down to compressor area if you remove back panel on bottom you will find end of hose usually hard plastic.you want to thaw until you can run a glass of water down and see it run completely through or you will be doing it again in a few days if not it takes a good hour and a few towels but its possible. good luck
Jan 05, 2011 | Refrigerators
Kenmore coldspot refrigerator, 2003 model. Serial #ep1732308. Cold water leaks onto the floor from the refrigerator. Collects under the vegetable bin, once or twice a day, but not sure. Do you know what's...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Sep 08, 2010 | Refrigerators
I have a Whirpool fride serial#et1mhkxmbd8 (or 08)that is dripping water in the back middle part of the fridge with no icemaker we have to empty a bowl about every 2 days
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 06, 2010 | Refrigerators
Water leaks from below the fridge a couple times a day?
There are several sources of water from within your refrigerator. The most likely source for the frequency you are experiencing, "couple of times a day", is the defrost system.
When your refrigerator defrosts, a heater that surrounds the evaporator piping behind the freezer back wall comes on which melts the frost on the coils causing the water to run into a drain below the evaporator. This drain can clog up with foreign particles accumulating in the drain. The clogging can cause the drain to spill over into the floor of the freezer and run out the door along the bottom of the freezer door through the door seal. This will usually leave an ice sheet on the floor of the freezer. If you do not have an ice sheet...the drain is not clogged.
The second method by which water ends up on the floor is a broken pan beneath the refrigerator intended to catch the water as it leaves the drain in the freezer. To test this, use a turkey baster and pump water into the freezer drain at the rear bottom of the freezer behind the wall using the holes in the wall. Watch under the refrigerator to see where the water ends up.
Performing these actions will lead you to the solution.
Nov 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer runs but clothes never dry. Water is not collecting in plastic tub
Same problem. You need to empty the condensor. Take the bottom panel off the front of the unit. Place a LARGE towel under the dryer to catch all the water that is going to spill out. Move the 2 red tabs to the right & SLOWLY open the panel. Allow the excess water to drain into the towel, then fully open the panel. Have a bucket handy to catch the water as you remove the condensor. Slide the condensor out & drop the back end into the bucket to catch as much water as possible. Then take the condensor to the laundry tub & rinse it out thoroughly. Re-assemble. Next time you switch the dryer on, just check that you get a short burst of water from the drain hose. You will probably have to do this every 5-10 loads.
Oct 19, 2009 | Asko T721 Electric Dryer
Have frigidaire model FRT 18B5JB1, the space below the crispers fills with water and spills out on my floor about every week and a half..there is no drain, no condensation on the walls..help!!
Sep 04, 2009 | Refrigerators
GE frdge model ctx21eazhrww has water accumulating under lower crisper drawers and spilling onto floor
Aug 20, 2009 | Refrigerators
My unit displays P2 mode flashes red wont turn.....
P2 error indicates that the spill reservoir in the base of the unit is full.
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
Aug 20, 2009 | Heating & Cooling
Hotpoint 18.2 cu ft refrigerator -water pooling on the floor
Was it the tubeing that drains the defrost water that you cleaned. Did you clean it at the top where it would be stopped up with ice. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If not
Aug 15, 2009 | Refrigerators
Maytag M6P09S2ACOM Air Conditioner Logo
113 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
