Question about Goodman CKL42AR42 Air Conditioner
The fan coil in the attic is leaking water. The drain is clear , and the inside tray is not full. But the insulation beyond it is wet. The system is eight years old and working good other then this.
  • Brian Niten Jul 17, 2010
    One possibility is condensation on the duct work.
  • 70 Answers
The pan may of cracked, also check to make sure the coil is clean water may be running off due to it bening dirty.
Posted on Jul 18, 2010
My Samsung SRL550DW keeps cutting out. If you turn the power off it restarts and works fine and then cuts out again after a few hours. Is this a main PCB problem. Prior to this happening the door chim
I have had the exact same issue and its not a samsung issue but any modern fridge with a defrost system in the freezer (fridge doesn't generally frost up as its not run at freezing temperatures.
You need to check a few things:
1. Clear the freezer draws out and clear any ice build up.
2. Be careful and unclip the first white plastic vent panel (hint: pull from the middle an inch or two then push the sides in so the tabs are pulled towards the middle and the panel pops out)
3. Unscrew and unclip the 2nd panel (holds the circulation fan) to view the freezer coils - you will need to unclip the power for the fan and the heating coil for the drip tray under the freezing coils.
4. This is where the issue usually is:
If the tray is full of ice then do the following. If not and you can poor water through the drain hole on the bottom, then the issue is a dead sensor or control board - seek professional advice or if your game, there are swap out kits you can buy.
So the drip tray is full of ice ? Unscrew the freezer coils from the back wall but DO NOT touch it any further in case you damage it. There should be some silver tape tape that holds the tray in place - remove it and then gently lift the coils up to allow the tray out. If its too full of ice, use a hair dryer or warm water to de-ice. Once the tray is out, defrost it completely and dry it - be careful not to damage the heating wires under the tray as this is used to deice it during a normal defrost cycle. Clear any remaining ice on the coils or along the back wall - Dry it well.
Usually the cause for the drip tray to freeze up is a blockage in the drain pipe that empties into the back of the fridge. Unscrew the back panel and you will see 2 soft plastic pipes drain water into a water tray. pull both off and clean/inspect. You will notice they pinch in the middle to stop air getting back in, but allows water to drip out. If they are blocked, they will back fill the internal drains and freeze, thus fooling the fridge into thinking it hasn't defrosted yet and not turning the compressor back on. (Since this ice is hidden at the back, it is the last to melt thus the freezer gets warmer waiting for the insulated ice near the drain to melt.
When I did my freezer, the water is dripping out slowly (it was cold) but once I removed the pipe, it emptied properly. inspection of the pipe showed dirt/insect blocking the pinched section of the pipe.
Reassemble the pieces in reverse order, ensuring the water was been dried with a cloth. My fridge/freezer hasn't skipped a beat since.
May 07, 2012 | Refrigerators
GE Refrigerator side by side TFX24JRSA AD.....Right hand door leaking small drops...on very bottom edge towards the left there are 2 holes about 1/2" in diameter...there's wet insulation I feel by...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 11, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a spit system air conditioner.Celestial KFR-70GW/K it is leaking water/condensation internally behind the fan.I think it it from therear grill and for some reason it does not go into the drain...
Leaking water from indoor is a common problem. Please check the following:
1. Cooling coil and air filter blocked-Clean it. 2. Drain pan and hos dust blocked-Clean it. 3. Non insulated pipelines-Insulate properly. 4.Less rpm of blower motor.-Replace capacitor.
Helpful?
Jan 01, 2011 | Heating & Cooling
I have a GE side by side model #tfx22jrba ww and it is leaking. It is wet under the left front corner. I took off the grill to see if I could find the drip pan and see if it was full but didn't see it. Any...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Sep 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have water leaking through the ceiling under where the Air con is. I have checked the drainage pipe and blown it clean but still getting water comng through the ceiling. Is there any wher else I can...
You need to determine if it is coming from your Air Handler. If it is, and you are confident that the drainage pipe is clear, then you could have a cracked condensate pan. I would suggest shutting the system off and opening it up to inspect the inside of your system. If there is ice present on the coil, check your filter and the cleanliness of the coil. If both are okay, call a contractor.....there could be a problem with airflow or refrigerant levels. If there is no ice present, check the bottom of the unit, if it is wet, it could be a leaking condensate pan (the part the drainage pipe taps into). You can shut the system off with the fan running and allow the inside to dry out......then begin pouring water into into the pan and watch to see if it leaks out...or if the unit is draining. If it is leaking, you should consult a contractor. Generally speaking, condensate pans cannot generally be repaired....and being that it is located in your attic, it's not worth the risk.
In Summary:
Ensure your air filter(s) is clean
Ensure your airflow is not impeded by closed or blocked off vents
Ensure your evaporator coil (located inside your unit) is not clogged with dirt/debris
Ensure your blower wheel is clean.
Ensure your condensate pan is not leaking.
If these steps do not help to correct the problem, contact a professional.
Let us know if you found this information helpful and Good Luck! :-)
Feb 22, 2010 | Heating & Cooling
TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 14, 2009 | Heating & Cooling
Condensate drain not working. Water driping from entire attic unit. Have flushed and vaccumed line to no avail. Secondary tray does drain but water drips outside the tray area. American Srandard Allegiance...
the drain coming off the unit is the one you need to clear, not the secondary pan. its usually clogged in the P trap which is usaully not far downstream from the outlet on the coil.
Sep 13, 2009 | Heating & Cooling
Inside leak
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice collecting on floor of freezer and water dripping inside frig
Most likely you have a blockage in the defrost drain that begins behind the rear panel in back of the freezer and ends up in a pan beneath the refrigerator were a fan blows warm air over the water to put it back into the air inside your home. You need to unplug the refrigerator and remove the back panel inside the freezer and look at the condensate collector tray at bottom of the evaporator coil. Sometimes its ice blocking the hole because temperatures are too cold for the liquid to drain and it freezes before leaving the freezer and sometimes the line is blocked beyond the tray. Examine first and melt the ice and pour a warm solution of clorox and water in the pan and check if the amount ended up in the pan below the refrigerator. Sometimes a wet vacuum cleaner will help get what ever dislodged from the drain and sometimes we need to install something to warm the hole as the defrost takes place. But cleaning the drain is the best solution for now..Sea Breeze
Jun 22, 2009 | Whirlpool Refrigerators
Goodman CKL42AR42 Air Conditioner Logo
77 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Dennis Boxerman
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
