Question about NetGear WG311 (0060449028409) Wireless Adapter
54 mbps PCI Adapter Card limits my connection to 2 mbps
I got a desktop connected by wire, and a PS3, Xbox 360, 1 desktop and 1 laptop connected by wi-fi. I'm using a 54 mbps router. My actual connection speed is 10 mbps (I can download at 1.3 mb/s).
I've installed a PCI Network Adapter to my desktop, WG311v3. I've updated the drivers. Somehow I can only recieve 2 mbps of bandwith, even with the router right next to my desktop. I've tried differenct channels (1, 6 and 11), and I've tried different security keys (WPA and WEP). My laptop recieves 54 mbps of bandwith on the same connection, and all of my other devices work properly.
Is there any way to fix this problem and get the desktop to recieve a bandwith of 54 mbps?
  • 42 Answers
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Posted on Mar 30, 2017
enda story
  • 61 Answers
SOURCE: onnecting Netgear WG111v3
make sure that the ariel on both sides is connected fully
Posted on Apr 24, 2008
Hans1980
  • 11 Answers
SOURCE: Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Posted on Jan 11, 2009
  • 9 Answers
SOURCE: netgear wn111 adapter doesnt work
have u tryed downloading latest drivers??
Posted on May 06, 2009
anandg27
  • 1272 Answers
SOURCE: Sir , my netgear WG311v3 pci adapter was working
follow the steps below to configure settings on the computer with the adapter:
FOR XP :
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 30, 2009
sourabh_035
  • 45 Answers
SOURCE: Windows XP desktop can connect
you remove ip address from desktop & select automatic ip address
Posted on Oct 11, 2010
How do you install a 54 mbps wireless pc card (wg511) Netgear to a desktop computer?
You can use a cardbus/pcmcia to pci adapter card just like this one below:
Nov 03, 2010 | NetGear WG511 54 Mbps Wireless PC Card
I am only getting 34-54 Mbps with my Linksys. I have a wireless adapter in my computer. It will go lower, but never than higher than 54 Mbps? I know i can get 100mbps because my Xbox does. Help me out!
Wireless Ethernet (802.11a or b or g) does not get the bandwidth you would get through a cabled connection. My guess is that you have an 802.11g network card in your computer and 54 Mbps is the top theoretical speed for that type of Wireless adapter. Cabled connections will give you the theoretical throughput of 100 Mbps. Also, since this Linksys device is not a Wireless access point but simply a switch, your computer doesn't actually connect to it. Most likely you are connecting to your cable or DSL modem. Most of these have a wireless radio built in.
Oct 15, 2010 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
100mbps on my house computer but only 54 on my laptop
100mbps is just the maximum speed capacity that can be used and depends on the speed that you subscribed so it doesn't mean you'll get a sharp 100 mbps on that.
Mar 31, 2010 | Toshiba Satellite M55-S331 Notebook
Limited or no connectivity
When your computer does not get IP address from the router, you get the message " limited or no connectivity ". There might be 2 possible reasons for this . 1) If your wireless network is secured then you are not entering the correct network key. Open the set up page of the router and check the wireless settings of the router .
2 ) Your router is giving the IP address to the rotuer.
Open the set up page of the router and check , the DHCP server is enabled or not ? It should be enabled.
You are entering the corerct network key and DHCP server is enabled, but still getting the same message. Assign a static IP address to the computer.
Click here for more instructions
Mar 29, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connection wireless adapter to laptop dell
Open up PC, Plug it wireless network into a PCI slot, turn on PC, the network device will be recognized and ask for drivers, you insert the CD/DVD that came with it, or use the software you downloaded from Belkin web site and install the WiFi card.. Run the Belkin software and it is installed. reboot PC, put case side back on.
Mar 02, 2010 | Belkin (F5D7000) 802.11g/b Wireless...
Xbox 360 connection withthe netgear WGR614v9
This is beacuse there is NAT on the router for which you need to open certain TCP/UDP Ports on the router . but firtstly you need to Bridge the Verizon DSl Modem set up the internet connection as per same .
Feb 13, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Xbox Live for the xbox 360 is red bar for cod waw
HI, this is an issue that concerns the Ethernet port that is integrated within the main hardware design. Contact Microsoft for this type of repair.
Feb 22, 2009 | Microsoft Xbox 360 Console
X Box 360 can't connect in hotel room!
I figured it out! I am also in a hotel room with only ethernet...and can connect to the network but not to the internet. When I got onto the internet for the first time on my laptop, there was a hotel internet webpage that came up immediately. You have to click CONNECT for 24hrs; 48; 1 week etc. unfortunately for us, Xbox doesn't have a internet browser like the PS3 does. So we can not click CONNECT when we are attempting to connect on the 360. The only reason why I know this is correct is because my friend brought his PS3 to my hotel room and that hotel connect window popped up and immediately we were playing Modern Warfare 2 with "full bars"...Xbox should really add a download for a browser! Like 360 way more. Sorry guys!
Jan 28, 2009 | Microsoft Xbox 360 Console
Problem with streaming from my laptop to my xbox 360 wirelessly
Call microsoft for a solution, they will most likely know in a few minutes. Even though you get punjab from india.
Mar 02, 2008 | Microsoft Wireless Network Adapter Xbox...
NetGear WG311 (0060449028409) Wireless Adapter Logo
115 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
