Question about Canon Office Equipment & Supplies
The paper won't feed and the paper jam light goes
The paper won't feed correctly and the paper jam light goes on after it attempts to feed.
  • 1,219 Answers
Wich copier model do you using?
My wild ques would be paper feed rollers. Try to clean them with alcohol and try to copy.
But still I would want to know the model.
You can also contact me on emma.servis@gmail.com, if its Canon copier.
Posted on Jul 17, 2010
Epson sx235w paper jam error-there is no paper jam!!!!
I have had this exact problem this morning with Epson SX235W.
4 from the end of a print run the feeder grinded to a holt.
I removed paper switched off machine checked for jam but every time I turned it on it span the feed rollers for a few seconds and came back with the error. I tried everything I could find on Google and after 2 hours its was still the same . by now I was sure that this was mechanical failure. In a last ditch attempt I used good old brute force and pushed a thick piece of card through the feed whilst it was turning on . HA !! Jam light goes out, printer works . 3 sheets later I find a very old/inky rubber band has been pushed out with the paper. must have been in there for ages before becoming a problem.
Moral is - there is almost definnatly someting stuck, even if you cant see it.
Feb 14, 2012 | Epson Office Equipment & Supplies
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
HAVING A 13.20.00 ERROR CODE ON A HP 43OO. PLEASE HELP!!
JAM IN TOP COVER AREA
A jam exists in the top-cover area.
A 13.20.00 error message indicates that the printer power was turned on or that the printer attempted to initialize while the pre-feed sensor (PS102), the top of page sensor (PS102) and/or the fuser delivery sensor (PS108) was detecting media.
When the paper feed assembly is installed, the sensor-flag spring must be correctly positioned
for the flag to operate. If a paper-jam error message (13.20.00 JAM) appears on the control-panel
display after you replace the paper feed assembly, verify that this sensor-flag spring is installed
correctly.
Hook the spring over the flag tab (see 1 in Figure). Fasten the paper feed assembly to the
chassis with the flag spring positioned in the hole in the transfer assembly. Release the spring
from the tab on the flag (see 2 in Figure). See figure below.
Verify that the flag is held in the upright position, can freely move, and always returns to the upright
position. If the flag does not move freely, or return to the upright position, an error
message (13.20.00 JAM) will appear on the control-panel display when the printer power is turned
on.
Aug 10, 2011 | Office Equipment & Supplies
Paper feed won't pick up paper. tried to put single paper in but paper jam light goes on but no paper located. we think we need new rollers for the paper feed but not sure where to get them in...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
May 12, 2011 | Lexmark E232 Laser Printer
A sheet of paper keeps getting jammed - we remove it and try again but it keeps jamming. We have cleaned the rollers inside where the cartridge goes and it did not help
If the first sheet of paper is correctly feeded and it shows up after fusing unit and that happends every time, then probably you have damaged exit paper sensor. It have to be replaced with new one.
If the paper feeds only few santimetres then you have to replace paper feed roller
pifonski
Feb 23, 2011 | Samsung Office Equipment & Supplies
The paper in my canon 2270 is sticking every time it feeds. This only occured after we ran some books
Make sure the paper size dial is set correctly for size and orientation of paper loaded (on the front right corner of the paper tray). The copier will display paper jam every time if this dial is incorrectly set. After this has been confirmed, if it still jams, try cleaning the paper feed rollers with soapy water or isopropyl alcohol (make sure rollers are dry before attempting to copy again) Let me know, please
Oct 25, 2009 | Office Equipment & Supplies
HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Mar 13, 2009 | HP Officejet 6200 All-In-One InkJet...
My Epson cx 4200 won't print because each attempt the paper jam light flashes and the printer stops trying to print. The paper is being pulled into the machine un-evenly.
It's highly likely that you either have a foreign object down the paper feed tray or the guides are incorrectly set...
Hopefully one of these will solve this:
1. Remove any paper, tape down the scanner lid and
gently tip your printer upside down and give it a GENTLE shake to see if anything drops out. This is really only something I'd recommend for someone strong and careful so take your time.
2. Check for any jammed foreign objects such as pens, paper clips, etc...that have fallen down into the printer. The place to look is wherever the paper seems to be bunching up most as it goes through
3. Make sure you're inserting the paper, with the guides set to the correct width and not loose. The guides help correct any issues with skew as the paper is pulled in, so this may correct any other issues.
Hope one of these helps..
Jan 24, 2009 | Epson CX4200 All-In-One PSC Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
147 people viewed this question
old marine
old marine
