Question about Yamaha Audio Players & Recorders
I HAVE HAD A QY700 SEQUENCER FOR A FEW YEARS WITH O PROBLEMS. RECENTLY,WHEN TRYING TO LOAD A FLOPPY DISK IT SAYS 'BAD DISK' I HAVE TRIED SEVERAL NEW DISKS WITH THE SAME RESULT. THE MANUAL SAYS THAT THE CAUSE COULD BE THAT THE FLOPPY DRIVE HEAD NEEDS CLEANING BUT DOES NOT EXPLAIN HOW THIS IS DONE. HOW DO I CLEAN THE FLOPPY DRIVE HEAD?? JIM DRISCOLL
irc_affaires
SOURCE: Technic GN3 Organ 3 1/2 floppy drive will not read 720mb DD disks
You can change SY-FD20 floppy drive by a new one, modified to work on.
Service Manual, Schematics, pinout and floppy drives available : http://floppy.shugart.free.fr/page.php?page=materiels/technics/sy-fd20/index.htm
Posted on Dec 13, 2012
Will a sequencer malfunction cause my floppy disk not to load.
You may have to ENABLE floppy disk in BIOS, you can also change boot order there if you need to boot from floppy. They are obsolete now, so many set BIOS floppy to OFF {some do not not even connect the cables, floppy just plugs the hole in the case) . I use an external USB floppy for emergency access to old floppies. (ahh, memories !)
Sep 26, 2014 | Computers & Internet
Floppy disk problem
Are the drivers for the floppy drives up to date?
Dec 05, 2007 | Sony (1QTY) Beige 3.5" Internal Floppy...
I put new fan motor or heat pump now runs all time and doesat seem to heat well but line set going into a coil infurnace is hot
I would check the fan relay and especially the sequencer. I recently came across a problem with an older sequencer which had come partially apart and allowed the thermo disk to keep the fan running continuously. The sequencer controls not only the fan relay (24 volt), but the heating strips(220 volt) as well. Make sure all power is off to the unit and verify. Make a wiring diagram and take several pictures if necessary. Replace sequencer with only an Identical unit, even if you have to order it. The newer sequencers have two metal straps to prevent this problem from occurring.
Feb 15, 2011 | Heating & Cooling
Computer will not read floppy disk
You have a bad floppy drive. In this system you almost have to gut it to replace the floppy drive, although used floppy drives should be pretty cheap on eBay. If this is a one-time thing, a USB floppy drive should do the job just as well.
Feb 14, 2010 | Toshiba Satellite 2805-S202 Notebook
New Dell Internal / External USB Floppy Drive 1.44Mb
It would appear that you may need to do a couple of things in order to restore the drive back to normal. I would disconnect the drive using the icon provided to this effect and doing it after the message says it's safe to disconnect it.
If the message says differently, I would still disconnect it, unles you're in the middle of writing, which you're not.
Upon reconnecting the drive, should the condition persist, I would recycle the laptop and try again. It does not make sense that a disk that you recently read from to burn a CD is no longer readable, unless the mechanism inside the drive had collected debris that caused the data on your floppy to be ruined. That would be an unfortunate disaster.
If rebooting the laptop still fails to read the disks, then try blowing any dust or dirt from inside the drive using one of those small canisters of compressed air that people use to clean their keyboards and other devices and try again.
Should the condition persist, try loading the floppy disks on another system to see whether they've been ruined by your drive.
If they are readable, then the drive would appear to be deffective.
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
''Platform signature not found in the interface'' BIOS HELP!
I remember a time when floppy disks were actually stable.
More than likely one or more things could be the cause of your headaches..
1) the floppy disk is flawed, or not properly formatted.
You can go to www.bootdisk.com and download a utility that will write a windows98 boot disk to your floppy.. this method writes per cycles, and checks that the write has been successful, once written, and booted into, you should be able to swap the floppy disk out for one with your flash utility, and bios file on it.
2) the floppy drive could be faulty. I have seen several drives claim to have formatted a disk, but infact had not because the read / write head in the drive had gone bad over the years.
3) There may be a memory problem on your system, faulty, yet funtional memory modules are all too common. When you boot from a floppy, most times they store the " dos " operating system in memory to save time from reading the floppy disk again and again.
May 31, 2009 | Gigabyte Computers & Internet
My floppy drive tells me to insert a disk when I try to use it
Sounds like you have a bad drive or the disk is corrupted. Did you try a different floppy disk to see if the drive is functioning?
Mar 21, 2009 | Computers & Internet
Troubleshooting Floppy Disk Drive Problems in Windowxp
try using the floppy on another computer, if you have the same problem then the floppy is bad, if it works on another computer then your floppy drive might be bad, if you built the computer, try using another cable for the floppy drive, i ran into problems like that when i put bad cables in
Dec 04, 2008 | Microsoft Windows XP Professional
77 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
