Question about Motorola Mobility W230 Phone US with Warranty
I want to know where i can connect 3.7vdc (from external source)
My motorola w230 had a complaint. it does'nt get charge from charger or usb. so i need to connect a 3.7v to its battery-phone connecter. but i don't know which is the voltage input + and which is the -.so please tell me
    Sergeant:
  • 298 Answers
If the warranty is still valid. return it and dont try to open it
Posted on Jul 17, 2010
How can i charge my motorola w230 via pc and usb cable?
Before using the computer as a charging system for the phone, the appropriate drivers must be installed on the system.
The W230 can be connected to the computer with a USB cable or data charger cable.
Apr 24, 2012 | Motorola Mobility W230 Phone US with...
W230 not charging with USB
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 05, 2010 | Motorola Cell Phones
Is it possible to use motorola w230 with a pc as a usb modem
My battle with moto. phns. lasted aprox.2 months and 300+$ .main factor ur. carrier its that easy.ask! I purchased the software +2 diff. phones .There is no slick way.good luck
Jun 21, 2009 | Motorola Mobility W230 Phone US with...
How can i charge w230 phone via pc?
If you have the Usb data cable for your phone,Just download and install the Motorola usb drivers from here once it is installed just plug in the phone.
Jun 07, 2009 | Motorola Mobility W230 Phone US with...
W230 model phone not connecting to system
First you need to run the USB charging driver to the system.
You can download the USB charging driver from Motorola website.
Once you run the driver, better you restart the system.
Now you connect your mobile to the system.
Make sure that, you should not connect your mobile while screensaver is running.
Your mobile screen should be on. Don't go to your menu.
Now when you connect the USB cable, it will ask you that
connect mobile as a storage device?
select Yes.
Now it will be connected.
Even if it is not connected. Unplug the USB cable.
Switch off and switch on the mobile and connect it.
Definitely it will connect.
Cheers...!!!
May 27, 2009 | Motorola Mobility W230 Phone US with...
Phone can not be identified by the pc. it wants the usb charging
micro sd card has a built in driver on its own, all you have to do is to unlock your phone and connect the cable to your phone and your pc.. press "yes" on your phone questioning you "connect as a storage device" or something like that.. then you can start file transfer from pc to phone and vice versa..
Jan 24, 2009 | Motorola Mobility W230 Phone US with...
I want pc suit or want 2 know how 2 connect my motorola w230 2 pc
Check if your phone has any USB slots if it does you can use that just fine.
Jan 10, 2009 | Motorola Mobility W230 Phone US with...
W230 cant connect to a pc
http://www.cellphone9.com/motorola-w230-file-transfer-problems-firmware-update/
follow the above line.... and probably you must have a memory card in the fone.... once you are done with downloading the driver  connect the fone and you would get the 'found new hardware baloon' select 'no not this time' and click next and browse to the driver which is downloaded, click next and finish the process...
once you remove and connect the fone you would get a prompt on the fone's display "connect phone as storage device" click yes to transfer data or click no or leave it alone for the fone to get charged...
hope this helps you..
use this alt link to download driver
http://direct.motorola.com/hellomoto/in/support/usb_drivers_pc_charging_drivers.asp
incase of any further clarifications  vishal at games.com....
Cheers, vishal...
Nov 12, 2008 | Motorola Mobility W230 Phone US with...
Want to connect motorola w230 to internet with USB
I want to connect motorola w230 mobile to internet by using usb.so how can i connect and from where i can get software(Modem driver) for that.
Jul 01, 2008 | Motorola Mobility W230 Phone US with...
Motorola Mobility W230 Phone  US with Warranty Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
