Question about Sony KDF-E42A12U 42" LCD TV
When i turn on my tv, the stand by indicator button keeps flashing alternate form red to green every two seconds, when i try to use the remote to put the tv on it knocks itself back to the alternate flashing indicator. can you tell me how to rectify this please, any advise would be most welcome
  • 10,594 Answers
Is this Sony KDF-E42A12U or any other model?
How old is this tv and when did you replace lamp last time?
I think lamp in tv is dead and need to be replaced but will confirm upon above info.
Thanks.
Posted on Jul 17, 2010
  • 4 more comments
  • daveburke421 Jul 17, 2010
    yes the model is KDF-E42A12U, the lamp was replaced about two weeks ago and i bought the tv in 2005, there is a neon red light on the front of this tv if the lamp goes, this is positioned just to the left of the indicator/stand by light. i have checked the lamp and this is in perfect working order so i am presuming it must be something else ?
  • Shahid Electronics
    Shahid Electronics Jul 17, 2010
    Get back to you shortly with info, please wait my next post.
    Right, as you said, lamp has been tested and found OK.
    Next thing is ballast supply that provides high voltage to lamp and lamp directly connected with it through its plug. Now if ballast fails, red power light will start blinking 3 times then pause and repeats.
    But tv indicator shows problem with lamp itself as lamp light blinks on tv front. This is bit confusing situation so I would suggest to test ballast supply board as well by swapping it in another similar model tv.
    thanks for your answer, to test the ballast supply, will i need to get an engineer out to rectify this and if so would it be a costly exercise to repair ?
    to repair ?
    It depends that you need an engineer, if you feel uncomfortable working inside tv than local tv repair shop option is good, they will check ballast supply and replace it for you, if required.
    Usually ballast supply board costs $120 to $140 plus labor.
    Thanks.
    many thanks for you time on this question.
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
Nov 28, 2010 | Hisense Televison & Video
Tv won't turn on.
  • Try resetting the lamp timer
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
May 06, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Code for jvc tv with ge universal remote
Here are the GE Universal Remote 4 digit codes for a JVC TV.
0060... 0026... 0197... 0069... 0160...0247... 0923... 0012... 0065... 0067... 0141
Direct Code Entry
1. Press and hold the SETUP
button until the red
indicator stays on, then
release the SETUP button.
2. Press and release the
desired Mode button (TV,
VCR, etc.). The red
indicator blinks, then
stays lit.
3. Enter the 4 digit code from
the code tables. Note:
after a valid code entry,
the red indicator turns off.
For an invalid code, the
red indicator flashes.
4.With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of the
other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for 3 seconds.
Hope this helps!
Sincerely, CBR2009
Jun 17, 2009 | Universal Remote Control GE174Universal...
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Sony KDF-E42A12U 42" LCD TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
