2 things really, may be connected but dont no. 1# my 4gb(2x2gb)OC2 ddr2 pc2 6400 800mhz(i think) is readin in my bios as unstable.. ive tried memtest programs in the past which gave me no anwser.... 2# which is the main problem..and im left completely clueless. my system halts of stalls during windows updatin(vista 64bit Ultimate) and explorer.. or when the comp is left idle for a period of time it just freezes... yet the HDD led is continuously flashing as thou its having a heart attack.. recently brought new case/extra fans and performed a full format... but this problem still continues... Any ideas??
  • 4,737 Answers
Please try the hard disk on another and let me know. If it's working find without any problem on that system, then we need to go ahead with other components. If you can, bring in another hard disk, connect it on the system after removing the one which is installed and boot from the new one, your best option is using a new hard disk, install new windows and boot from the hard disk. If the old hard disk is the culprit, you can easily fix it by replacing with a new hard disk. You can backup all the files, no matter, maybe it will take time, but i'll save you from future disaster.
This problem relates to many causes, so we need to do step by step. This is the hard disk troubleshooting measures, next we'll do with the Memory/Ram and Cpu.
Let me know when you are done.
Good luck.
Thanks for using FixYa.
Posted on Jul 17, 2010
  • sirbloggsluk Jul 17, 2010
    ill have to get back to u on a later date as dont have a spare hdd drive atm.. but will test this n go from there. thanks.
  • Lebanon Raingam
    Lebanon Raingam Jul 17, 2010
    Never mind, I'll always be here to help you.
    Good luck.
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
Help me overclock ASUS P5GC-MX/1333
LOOK IF A BIOS PASSWORD IS SET.
May 26, 2013 | Computers & Internet
Can i put 2x2gb ram in k9vgm-v motherboard
It should specs say:
• Supports Dual DDR II 533/667/800
- 2 DDRII DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 2GB.
Most systems will pick up the 4GB, but Windows 32Bit has a 3GB limitation.
May 06, 2013 | MSI K9VGM-V Motherboard
I have a c51gm-m Motherboard and it does not recognize my full ddr2 2x1 667mhz only half . i want to change them with 2x2gb 800mhz but i only get 2 beeps when i boot i already did a bios update and...
Hi, you can download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=9&detailid=653
Here is some more info:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=653&CategoryID=1&MenuID=21&LanID=0
I think one of the ram modules is defect.
Set the bios setting to auto for the ram and let it handle it itself.
It has to work together with the cpu. Maybe the cpu does not
supports 800 mhz.
Read all about that in the manual.
Sep 01, 2011 | EliteGroup C51GM-M Motherboard
1.help how to update the bios..i cannot locate the bios file from the open window. 2.the motherboard asus m4n68t m v2 has a feature of core unlocking but when i tried it seems unstable. i have amd...
1. Go to your products site to locate the latest BIOS update.
2. Core unlocking can be very dangerous. The 4th core is locked for a reason, usually because of a manufacturing defect. If it seems unstable then it probably is. Some people that you see online get lucky and successfully unlock the 4th core. However, this is not the safest thing to do and could actually damage your CPU. If you think it is unstable, then you should probably restore it to its factory defaults.
Mar 26, 2011 | ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3,...
My system becomes unstable since i put a pair of PNY 2x2Gb 800 Mhz memory modules (in dual channel)and freezes with the screen full of artifacts. The system used to have a Sureptalent 1Gb (~400 Mhz i...
You can use -240pin-ddr2-sdram-800MHz- (PC2-6400).non-ecc
You have a duel channel kit PNY memory.
There are 4 dimms,
A1-- A2,,,,,,,B1--B2,,,,
In which dimms do you have the two sticks installed ????????
Important question above!!!!!!
Feb 16, 2010 | ASUS P5E-VM HDMI Motherboard
Power Saving Mode Problem
try swapping power supplies or improving internal cooling. your not overclocking the cpu or the video cards, are you?
Jun 09, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
Memory not recognized. 4 gig installed only 2 gig recognized by bios and windows. Vista home premium 32 bit.
2GB is quite low but you will never see the full amount of ram.
Your video card will use some and then Windows reserves some for itself.
You dont say if its 2x2gb sticks or just one, if two does bios see the full 4gb. Check the memory is properly seated. Try swapping the sticks round.
Apr 25, 2009 | Acer Computers & Internet
Computers & Internet Logo
David Payne
David Payne
