Question about Samsung Jet S8000 Cell Phone
Hii there if got my samsung jet for about 6 months but now the touchscreen is very slow i dont know how it happened cause im very carefull on my phone and never dropped it but when i text or press its responding very slow and its verry ittitating does somebody know what the problem is??
    Sergeant:
  • 298 Answers
Go to the touch screen setting and do the calibration and sensitivity settings to suite urself
Posted on Jul 17, 2010
How do i clean jets on a spear & jackson strimmer sgt33n
After removing the carb, your gonna have to acess the inside . most jets are screwed in with a tiny flat blade screwdriver. When removing them go slow and be carefull, they are delicate. Have your can of carb cleaner ready to clean eyerything down. As for cleaning the jet itself, use a wire from a wire brush, the bigger kind, 1 1/2 inch or so. The wire works great, stiff enough to clean, but not do and damage. Also if you can blow out the inside with compressed air the would be better, just dont let the jet fly, no pun intended.
Mar 08, 2011 | Garden
Dropped samsung jet touch screen not responding,
The touchscreen connector has come loose. It's a small flatcable which connects the digitizer (touch screen) with the pcb on the back of the screen. It's repairable, however you need to disassemble the complete phone. A great disassembly guide can be found here: http://www.formymobile.co.uk/jetdisassembly.php Good luck! :)
May 28, 2010 | Samsung Jet S8000 Cell Phone
Have a 03 vmax 1200 has ufo 4-2 exhaust and holeshot stage one jet kit- ran good all last year and month this year since winter. doesnt want to idle well and when i role the throttle it bogs right down- no...
Sounds like you PILOT jets are gummed up. try to run it with the choke on and see if it runs better. what happens is, when the pilot jets are clogged they dont let enough fuel through to allow it to idle. also, when you roll the throttle on then the venturi lets more air through and the jets aren't allowing enough fuel to accomodate the increase in air flow causing the bog down.
Apr 30, 2010 | 2003 Yamaha V-Max
Im having no signal on my samsung jet s8003
same as me exactly - signal fades away after less than 5 mins .
Have done the phone reset as detailed above but no joy
anyone help ?
Oct 18, 2009 | Samsung Jet S8000 Cell Phone
Touchscreen has blue spot. what should i do?
It looks like a dead pixel. Check with your Samsung retailer if it's still covered by a warranty so they can replace it.
Sep 15, 2009 | Samsung SGH i780 - Microsoft Windows...
How to block un wanted text messages
hii
call up ur network provider customer care and ask for the procedure on blocking unwanted text msgs as well as calls.
Regards
Sep 06, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
How to see Full screen vedio
hi..Go to the playlist,there you have a option
called settings.In that u ill get full screen select
that.Now you will be able to see in the full screen.
check this out..
thank u..
rate me..
Feb 12, 2009 | Samsung M200 Black OEM GSM Unlocked Cell...
Blackjack 2 being slow
i dont have a blackjack but this happened on my blackberry 8800. i just deleted a bunch of old text messages and it started working fine. i guess it was running out of memory and that was causing it to run slow.
i dont know if this will work for a blackjack.
Aug 02, 2008 | Samsung Blackjack SGH-I607 Smartphone
Windshield washer jet not aimed correctly
you could get a sewing nedle and insert it into the jet and aim it doing that this will also clean any gunk out but dont use one thats a tight fit as it could force any gunk further into the jet causing it not to work at all so be a little carefull doing this.
Jul 25, 2008 | Toyota Pickup Cars & Trucks
Samsung Jet S8000  Cell Phone Logo
375 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
