Question about Frigidaire Refrigerators
The fridge runs all the time but it is not cold & the freezer is only as cold as the fridge should be.
    President:
  • 2,468 Answers
Check the back wall of the freezer for frost build up,if so remove panel and the evaporator is iced up,thaw ice out with hair dryer then check the defrost heater under the evaporator coil you de-iced its either bad or the defrost control is bad be it a timed or adaptive type defrost control
Posted on Jul 17, 2010
The freezer is working fine but the fridge is not cooling. The motor is running constantly. I did accidently leave the fridge door ajar for a few hours
Check to see if the cold air supply from the freezer to the fridge section is blocked and that the fan is running. The fridge uses cold air from the freezer to cool and many times the intake is blocked by something in the freezer compartment.
Sep 13, 2010 | Kenmore 72912 / 72914 / 72919 Bottom...
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Amana bz22rw fridge temp fluctuates & is a little warm - freezer is ok should i replace the fridge temp control or the damper
Temp control = controls run time of the compressor and temp of freezer.
damper and cold control = control how cool the fridge is...
also check you fan speed and air flow to the fridge.
Sep 19, 2009 | Amana Refrigerators
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 31, 2009 | Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Refrigerators Logo
119 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
