Question about DFI NF4 INFINITY Motherboard
Board stopped working
It's an DFI nf4 infinity, not shure if ultra or not...
Problem:
computer wont start, board wont beep at all, green led is blinking, all fans working, no viedocard output...
I think it is fried but not 100% shure (could it be graphics card? or power source?)
Thank you
thassardur@gmail.com
  • Sergej1 Nov 08, 2008
    Have replaced the video card. PC works now. Not sure if it was the video card or the pci express socket since I only had a old 5200FX pci version.
    Genius:
  • 2,785 Answers
Try one by one first the graphic card then with powersupply
Posted on Apr 21, 2008
Manual for LPUTNF4SLIDREXPERT
please help me find an online manual for this motherboard please mate hi brian i was wondering if u cud help me find an online manual for this motherboard (DFI LANPARTY UT nF4 Ultra-D) as im selling it on and want to check all the jumpers are in the correct positions please help me out dude, many thanks in advance for any help matey
Mar 27, 2013 | DFI LANPARTY UT nF4 SLI-DR Expert...
I want driver for this motherboard
Here are the links for the DFI NF4 driver you have requested.
Jan 26, 2011 | DFI NF4 ULTRA INFINITY Motherboard
I have a DFI LanParty NFII Ultra motherboard. I had to move the power supply to a different machine and have purchased a new one to drive the DFI system (Win Power) rated at 650w. The power standby...
It's the craziest thing, I'm looking dead at the Motherboard Manual for the DFI LanParty NFII Ultra B motherboard, and the diagnostic LED lights are Not referred to.
Looking at the view of the System Board, the LED lights are shown down by the CMOS Battery.
LED 1, 2, 3, and 4.
The manual indicates only two types of BIOS Beeps are listed;
1) One Long beep followed by Three Short beeps.
Video error has occurred and BIOS cannot initialize the video screen to display any additional information
2) Single Long beep
A DRAM error has occurred. {Problem with the Ram Memory modules}
The BIOS program is a Phoenix - Award BIOS, but doesn't indicate what version or date.
[ The motherboard manual is downloaded for free from here,
http://productsmanuals.com/computer-manuals/dfi-lanparty-nfii-ultra-b-system-board-user-manual
Go to > To view the Products Manual - or to Download it - just click HERE.
{Click on HERE}
Allow up to 30 seconds for the file to download.
Offhand I would say it is Ram Memory that is the problem. Remove the ram memory module/s, and clean the gold plated contact pins with a pencil eraser, then use air to remove the eraser dust.
However, in looking up for information on the diagnostic LED lights, (The info IS out there. Maybe on DFI's support website, but I couldn't find it), I see that if you are using a graphics card that requires an additional power cable, you'd better have that baby plugged in.
The motherboard won't work if the additional power cable isn't plugged into the graphics card.
Regards,
joecoolvette
Dec 06, 2010 | DFI LanParty NFII Ultra B Motherboard
DFI infinity wont post
Hi...
When your computer continuos beeping the problem is the RAM you need to open the CPU casing and check the remove the RAM clean the dust then after that, reinsert the RAM to the socket, then turn on your computer. "good luck".
Regards
PCmania
Jul 13, 2009 | DFI NF4 INFINITY Motherboard
I need to connect wires to DFI LANParty mother board.
You can find your manual here in PDF version, this will allow you to " zoom " in on any connection information your may need.
http://img.lanparty.tw/Upload/Manual/CM/lputnf4%20847505101.pdf
Jun 20, 2009 | DFI LanParty UT nF4-D Motherboard
DFI NF4 INFINITY MOTHERBOARD NON BOOT
sounds like a hardware problem. try unplugging all external devices including keyboard and mouse but not monitor. test if it works. if not, open the side of the case and remove the little battery found on the flat motherboard for 30 seconds. then slide it back into place. now try to see if it works. if still nothing, check to see if there are motherboard jumpers (they will be 2 tiny pins on the board with a clamp over the top of them, you probably wont find them), if you see the jumpers, move the clamp to the spot that says "clear cmos" then put it back. or if your motherboard has a clear cmos button on the board, press it and try the computer. if it still will not boot, it could either be the flat IDE cable (for a hard drive or cd drive) or the power supply which means you will need to purchase either a new power supply or ide cable. if all still fails, i would say the motherboard is shot.
Feb 25, 2009 | DFI NF4 INFINITY Motherboard
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Jun 28, 2008 | DFI Computers & Internet
DFI nF4 Infinity problem!!! plz help
are the fans running - sounds like a PSU problem to me do you have a mutlimeter you can measure the voltage from the PSU - the motherboard website should have a manual, with pinouts and voltages.
May 08, 2007 | DFI NF4 ULTRA INFINITY Motherboard
DFI NF4 INFINITY Motherboard Logo
194 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Steve Frost
Steve Frost
jason
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
