Question about Dewalt Planer (DW734)
How do you change the blades on a dw734 planer
  • 2,100 Answers
Did you save the wrenches for the blades and the setting gauges? You need them. It is hard to do without. You have to take off the dust cover, should be called the finger cover, get the cutter head to lock up, it should have a pin on the right side to lock it from turning, loosen the jib screws,(bolts), and blow out he cutter head. Leave the adj screws where they are. Then do the other side, sharpen the knives, or get the new ones ready, don't answer the fone, or eat dinner at this time. The knife setter sets each knife to the same height and/or depth across the cutter head. It is a small C shaped thing that rides on the head and grabs the tip of the knife when it is at the right depth, they all have to be the same, and they just scrape the knife, they don't pull it or move it, it just touches it. Snug up the jib screw, and move to the middle, check and adj the height snug up the screw, move to the end, do the same, go back to the other end, check it again, use a small piece of wood to tap it down if you have to move it, when it looks good, torque it down, then do the other side the same way. I hope this doesn't have those tiny 2 sided knives in it? They are the worst, they have no meat, they don't cut worth a flip. You need the big knives, something with some meat to them. Check it out, hope this helps.
Posted on Jul 17, 2010
Blades wont lower
DeWALT DW734 Type 1 12 1 2 inch Planer Parts
Clean the machine inside usually there is a line or square wood cross and
use a dust extractor with an induction motor, high enough capacity
Dec 01, 2015 | Dewalt DW734 15 Amp 12-1/2-Inch Benchtop...
My planner won't draw the wood thru my planner.
check that blade is correct and guides correct
Mar 20, 2014 | Dewalt Planer (DW734)
No power. I used my planer the other day and then changed the blades, now there is no power. Is there a safety switch that would stop the motor from getting power? I have checked everything that I can...
You might of either pinched or knock a wire loose.. I would open it back up and check for a loose wire. Start with where the cord comes into the machine and go from there.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jay_17408fb1a2cad107
Oct 24, 2013 | Dewalt DW734 Heavy Duty 12 12" thickness...
Change the belt on a dewalt 733 planer
Here is a link to a site I am a member of, Lumberjocks.com. The link is for a discussion on how to replaced the belt on your planer!
Good Luck!
http://lumberjocks.com/topics/10176
Oct 03, 2013 | Dewalt Planer (DW734)
What side fo the blade on dewalt planer goes up
http://www.fixya.com/support/t5326180-change_blades_dw734_planer
Aug 20, 2012 | Dewalt DW734 Heavy Duty 12 12" thickness...
Dw734 planer
More than likely the screw threads are gummed up. Make sure the locking mechanism is up and lower the carriage. Clean the screw threads, spray with WD40 and wipe off the excess. I had the same problem because rarely raised the carriage above 2". Hope this helps!
Jun 30, 2012 | Dewalt Planer (DW734)
Owners manual for a dewalt planer
The Instruction Manual for the Dewalt DW734 Heavy-Duty 12-1/2" Thickness Planer can be downloaded from this link:
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DW734#
Scroll down in the list of downloads to Instruction Manual and select the icon under PRINT DOCS.
May 15, 2011 | Dewalt DW734 Heavy Duty 12 12" thickness...
Need owners manual for Delta DW734 thickness planer
look on the right side of the page you can download the parts list or the manual
http://www.dewalt.com/tools/machinery-portable-thickness-planers-dw734.aspx
Nov 18, 2010 | Dewalt Planer (DW734)
How to change Blades on Dewalt DW 733 Planer I lost the manual
Go to Dewaltservicenet.com and in the middle of the page towards the bottom is a box indicating manuals/breakdowns. Type in your model number and you can download one this way.
Jul 20, 2010 | Dewalt Planer (DW734)
Dewalt Planer (DW734) Logo
1,163 people viewed this question
Top Dewalt Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Dewalt Craft and Hobby Expert? Answer questions, earn points and help others
