Question about AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
Aquavac Tiger shark won't operate
We bought a resale home with an in-ground pool. It came with an Aquavac Tiger Shark automatic pool cleaner. I used it 3 times with the water dirty and it worked normal. Once the water was clear, I used it and the unit was practically climbing out of the pool and not covering the entire pool. Last week I bought new filters for it. Now, yesterday I put the new filters in, went to use it and the unit wont turn on. The Base powers on but not the pool unit. I called the 800 number on the manual and the company is now owned by Hayward. They sent me hopelessly thru the automated phone system. I typically fix my own things so I'm hoping I won't have to take this in for repairs. Any help will be greatly apppreciated. Thanks
  • DIYknievel Jul 19, 2010
    Hi, Thanks. I tested the power supply and sure enough sockets 1 & 2 have 24V across but 3 & 4 do not.
    Having discovered this, can you recommend any next steps? I plan to remove the cover later today and trace the wires coming from sockets 3 & 4 just to see if something came loose. If that doesn't help I guess I'm done. I am having trouble finding a repacement power supply online let alone the inner components for this one.
    I do have another question. Again, I inherited all this used equipment. Although this Tiger Shark system worked 3 time before dying, I can't help but notice the acutal cleaning unit motor states "P40000" & "26V" while the power supply states "P30000 & "24V". Should I be concerned about this difference? The cleaning unit is labeled "Tiger Shark"(not Tiger Shark II, Plus, etc...)
    Thanks again for your help.
  • 3 Answers
The power supply powers on even when it doesn't output any voltage, so it's kind of misleading. You should have the power supply checked or you can do it yourself if you have a multi-meter, by measuring the output and making sure there is 24V.
Posted on Jul 17, 2010
  • bakhaldoun Jul 19, 2010
    I wouldn't be concerned about the 2V difference. If you know how to measure diodes and trasistors, you could probably fix it yourself by buying/recovering components and replacing the defective ones. Otherwise, find a electronics repair shop and they will fix it for you. Good luck!
Tigershark comes out of the water too far
You need to reduce the flow through the impeller - there should be a baffle (something in plastic, round, that will be installed at the top of the shark) in the box that it came in.
May 29, 2014 | AquaVac Tigershark Plus Robotic Automatic...
My tiger shark does not work!! I have power to the transformer and shark, but it won't move. I just spent $400.00 at my pool store to get it fixed, they put new wheels, filters, and a new cord and...
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
Jul 23, 2011 | Aqua Vac Tiger Shark
My Aqua Vac Tiger Shark is sqeaking. I think the wheel tube bearing assembly is broken. How do I replace this part?
Thank you for posting your question here on Fixya.com.
Either side's drive system is composed of two guide bearings, a drive pulley and both wheel tubes. You need to replace whichever one(s) are failing. Remove the seven screws inside the unit that hold the side plate on as well as the handle screw. Pull the side plate and replace parts as needed. Reassemble in reverse order. For a price on the part(s) please contact us thru www.arrowpools.net. We stock most Tiger Shark parts.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Aug 29, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Tiger shark will not move
The motor that drives it forward and back is seperate from the fan and is defective unless your stuck on the main drain the motor unit needs replacing.
Mar 14, 2009 | AquaVac Tigershark 2 Commercial Vac with...
AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner Logo
1,125 people viewed this question
Top AquaVac Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Steve Slater
Jay Finke
Jay Finke
Are you an AquaVac Pool and Spa Expert? Answer questions, earn points and help others
