Ferroli DOM F24B Is leaking from the two 22mm pipes on the secondary heat exchanger
  • 1 more comment
  • Anonymous Nov 27, 2008
    me too. i had one leak so bought new seal set and put them in then all 4 started leaking. these boilers have **** poor fastenings and are a pain in the backside. im going to try using ptfe tape tommorow to seal it. not sure if it will work but ill get back to you if it does.
  • jamie-1966 Dec 14, 2008
    mine is leaking from all 4 on the secondery heat exchanger and from thecopper heat exchanger i put new orings in it put still leaks so bad what can i do the ferroli f24b is only 16months old
  • Anonymous Jan 03, 2009
    Same problem here -- leaks from the secondary heat exchanger. Had all 4 o-rings replaced and 6 weeks alter it's started again. Can't decide whether to live with it or not. I found the problem is much worse if you have the eco setting selected as the water gets too cold when not in use.
    Can any fix for this ever work for more than a few weeks?
Yes, this is a common problem on the domi compact. unfortunately ferroli accept no responsibility if not in warranty period! can be a costly repair..
Posted on Aug 19, 2008
Had this before on this model, ignore the fault codes provided you have checked possible causes given in manual. it is either the thermistor is too close to the heat exchanger on the top left, move it further down the pipe and the fault normally stops. it is the thermistor not overheat sensor as that would induce a fault code. if the fault goes away when the cover is off it is the ignitor lead, sounds strange but electrical leakage is occurring to earth due to the high voltage leaks onto the case,
The mad sparkie (also gas engineer!)
Posted on Jan 07, 2014
Scrap the boiler domi compacts are total ****
Posted on Dec 24, 2008
2005 ford taurus leaking antifreeze but doesn't overheat and it leaks out the passenger side of the car in the front
if its leaking inside the car its the radiator or heat exchanger for the climate control where the hot air comes from. will get worse and it will eventually over heat the engine.
quick cheap fix is to disconnect the two pipes in the engine bay that go to the heat exchanger at the the fire wall in the engine compartment. you will have to join them together so that everything on the engine still works. they are usually 20mm or 3/4". you can use a bit of copper pipe that size and the hose clamps.
Sep 25, 2016 | 2005 Ford Taurus
Condinsate leaking on furnace blower
Drain tube is most likely stopped up on the heat/cooling exchanger and running over. Locate the drain and clean it out and your problem should be solved.
Feb 19, 2014 | GAPCCCAR2025 Bryant Air Cleaner Filter
Ruud achiever 90 condensation overflow
Not a furnace guy but I do know that your drain should be insulated. Gotta figure out if it's water from the drain leaking or actual condensation dripping from the outside. If sweat, it needs insulated. Good Luck.
Mar 11, 2017 | Ruud UBHC Air Conditioner
How do i reseat the prv on a ferroli f24b boiler?
Hi, any pressure relief valves i have ever worked on, can't be reset. They are there to release water pressure that builds to high. If they continue to leak if you have discharged it, you can tap on it to see if you can get it to seal, or just replace it if it continues to run or drip water.
Sincerely,
Shastalaker7
Dec 30, 2010 | Heating & Cooling
Coolant leaking into car from passenger side
Coolant passes through the heat exchanger below the dashboard heating the interior air from the engine heat. The heat exchanger or its pipe is leak somehow.
A temporary measure is to change the heat/cool knob to cold position. This disconnects the radiator.
Note: If the leak is before the valve then it will not stop leaking.
Also if you use the heater then You need to get the pipe repaired.
Aug 12, 2009 | 1986 Chevrolet Cavalier 2 Door
Leaking from secondary heat exchanger
Hi cgcol
I just had the same problem with the same boiler and was recommended to get in touch with a company called Wolseley uk. http://www.wolseley.co.uk/servlet/reality/rscp/IN.BRADETFRMBP1?app=centers&ses=99999|47543&website=www.wolseley.co.uk
link is to their website branch locator. You need to click on parts center on the left hand side of your screen under branch locator, then put your post code in as easy as 123. The parts you need are o rings. They come as a set, their part number for the set is 459382 FROLI 39817620 ORING SET as shown on my invoice. Only cost £7.19 + VAT. Plus bought 798007 REGIN REGZ40 SILICONE GREASE 50G cost £5.47 + VAT (smallest size they do). This is to lube Orings before fitting and pushing pipes together. Make sure you have turned all stop taps off that are under the boiler and drained rads.
Hope this has been a help!
Jul 13, 2009 | Fujitsu Heating & Cooling
Goodman leaking water from the sides what is going on?
could be the venting adapter which is abs plastic could be cracked or a hose came off inside the furnace which connects to the secondary heat exchanger or the heat exchanger is bad
May 02, 2009 | Goodman GMS90703BXA Heater
GMPN goodman furnace: Water leaks from the base.
Check the drain tubes inside the furnace. There may be a loose connection or a split tube.
The unit could also leak from the gasket between the secondary heat exchanger and the vent fan housing. The secondary heat exchanger ould also be leaking or cracked.
Hope this helps.
Matt
Jan 08, 2009 | Heating & Cooling
Heating & Cooling Logo
1,012 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
