Question about HP Compaq Presario SR5501F Athlon 64 X2 4200+ 2.2GHz 1GB 160GB DVD RW DL Vista Home Basic PC Desktop
I would like to see an inside wiring diagram to see if I plugged something in wrong or not
  • HP Master
  • 5,660 Answers
If this problem is in direct relation to a Compaq Presario SR5501F desktop computer;
HP Support > Compaq Presario SR5501F > Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01237538&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3740354
The motherboard is made by ECS for HP/Compaq
ECS model number is MCP61PM-HM
HP/Compaq's name is Iris 8.
There is no wiring diagram per se to give you.
I'll have to detail the wiring connections step by step for you.
This may be a little lengthy.
On the link above you are looking at a photo of your motherboard.
There is also an illustration available.
I would like you to copy, and save them both.
Using this method you will be able to enlarge them for further clarity, of the connections to the motherboard.
Right-click on the motherboard photo. Left-click on Save Image As, in the list.
In the Save Image window that comes up, you will see the heading File name:
To the right of File name: will be c01237541.
Unless you want to search for c01237541 you may wish to do this:
Put your mouse cursor after the 1 in c01237541.
Left-click twice.
Make one space with your spacebar.
Type Compaq Presario SR5501F Mobo photo.
(Mobo stands for MOtherBOard)
You want this photo to go to your My Pictures folder.
(Windows XP. Different for Vista)
At the top of the Save Image window is the heading - Save in:
In the box to the right you should see - My Pictures
If you do Not you will have to change the destination.
Left-click on the blue down arrow to the right of the box.
In the list, left-click on - My Documents, then left-click on - My Pictures.
Now go to the bottom right of the Save Image window, and left-click on Save.
In the link, scrolling down you will see the heading - Motherboard layout
Left-click on the + sign next to Motherboard layout.
Copy and save it as you did for the motherboard photo.
In the File name: box type - Compaq Presario SR5501F Mobo Illustration.
Now all you have to do is go to your My Pictures folder (Start>My Pictures), and double-click on the photo, or illustration.
Left-click on the Zoom In icon at the bottom of the window to enlarge.
(+ sign in a magnifying glass icon)
Wiring Connections to the Motherboard:
A) Front Panel header: (Panel 1)
The Front Panel, is the plastic front of your computer where the Power On button, HarDDrive LED light, and Power On LED light is located.
The Front Panel header is the connections, or pins, on the motherboard, where the cables (Wires) go to from the Front Panel.
On the motherboard illustration it is marked as Panel 1.
(Down in the bottom right corner)
On your motherboard, Panel 1 (Front Panel header) is Black in color.
As you can see it is a rectangular block, and is placed vertically.
Has 2 columns of pins.
5 in the left column, 4 in the right column.
The Left column is numbered Odd.
Starting at the Top going down, Pins 1, 3, 5, 7, and 9
The Right column is numbered Evenly.
Starting at the top going down, Pins 2, 4, 6, and 8.
Pins 1 and 3 are for the HarDDrive LED light.
(HDD activity LED)
Pin 1 is for the Positive connection ( + )
Pins 5 and 7 are for the Reset switch.
Pin 7 is for the Positive connection. ( + )
Pin 9 is reserved, and may not be used.
Pins 2 and 4 are for the Message LED light. (LED = Light Emitting Diode)
Power On LED light.
Pins 6 and 8 are for the Power On switch.
There is No Pin 10.
If the cables (Wires) are not marked coming from the Front Panel, you will have to remove the Front Panel, and trace where they go.
You will be able to physically see where wires go to the Power On switch, Power On LED light, HarDDrive activity LED light, and so on.
B) 24-pin ATX main power cable:
Only plugs in one direction. Plugs next to the blue IDE connector on the motherboard. (To the right of the ram memory slots)
C) 4-pin ATX +12 Volt power cable.
Looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Plugs into the whitish square 4 socket hole connector on the motherboard, next to the Processor socket.
(On the motherboard illustration this connector is labeled - ATX12V1
D) Processor Fan:
Connects to the 3-pin CPU header on the motherboard. Right above the ram memory slots.
E) Harddrive:
You have a SATA harddrive. (500GB in size)
Connects to the SATA 1 header on the motherboard.
The SATA 1 header on the motherboard is Black in color.
The data interface cable has 7 pins.
Looks similar to this, (May not have a 90 degree elbow though),
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
The SATA power cable has 15 pins.
Looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
If your SATA harddrive has a place for a SATA power cable, AND a 4-pin Peripheral power cable, DO NOT plug both power cables in!!
This will lead to damage of the SATA harddrive!
The standard 4-pin Peripheral power cable looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The standard 4-pin Peripheral power cable connector, has had a misnomer for years as a Molex connector.
Molex was the first design implemented when this style of connector came out.
The name stuck.
It is the same as calling an adjustable open-end wrench a Crescent wrench)
F) Optical drives:
If you have a DVD burner drive it plugs into the SATA header 2.
(Uses the same style of SATA data interface cable, as the SATA harddrive)
If any of your optical drives are IDE, they plug into the blue IDE header, next to the ram memory slots.
This is what a flat ribbon IDE data interface cable looks like,
http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
(You can click on the photo to enlarge. You can enlarge twice)
G) The Floppy Disk drive, (If your computer came with one), plugs into the FDD connector shown on the motherboard illustration.
(Black in color, right above the 24-pin ATX main power cable connector)
Do you need information on the USB connections?
Post in a Comment.
Posted on Jul 17, 2010
Need 2910 E 450 FUSE DIAGRAM
If the vehicle rear lights are all working there will be nothing wrong with the fuses. Check the wires inside the trailer plugs as they are probably broken off or badly corroded.
Aug 26, 2014 | Cars & Trucks
My 2002 Kia Sedona won't start?
There is something wrong with the glow plug circuit and it needs to be troubleshooted using a wiring diagram
Aug 15, 2013 | 2002 Kia Sedona
Ephiphone guitar pickup wiring
Or a bad solder connection on the ground wire on the jack, or shell/sheild on the guitar.
Here is the list you seek.
http://www.gibson.com/en-us/Support/TechSupport/Wiring Diagrams/
Feb 03, 2012 | Epiphone Les Paul Studio Electric Guitar
Is there a stereo wire color diagram for a 2006 Chevrolet Tahoe
If you are installing a radio, I recommend you purchase a wiring harness. They are relatively inexpensive, seeing as how you could fry your entire electrical system if you do something wrong. The Harness will have the wires marked for you to hook your unit to, then plug into the vehicle harness. All radio wires are standardized.
Aug 20, 2011 | Car Audio & Video
I need a diagram for the wiring inside a Gateway GT4016
A wiring diagram? What for? Are you trying to re-solder the caps? Because the only wiring inside computers these days is power cabling, and thats pretty self explanatory. If you are looking for the die for the motherboard, I would try contacting the manufacturer. but chances are they would not give it to you. If you are just trying to plug in a drive or something similar, the flat plugs are the ones that plug into drives and the long 24 pin connector is the power for the board and the 4-8 pin connector is for the secondary motherboard power (CPU Power).
Short of these, I can't really give you a better response without knowing exactly what you are trying to do.
I hope this helps though :D
Nov 23, 2010 | Gateway GT4016 Desktop PC
Spark plug wires order
from front to back
1-2-3 on passenger's side
4-5-6 on driver's side
the coil
1-2-3 in the rear counting from passenger's side
5-6-4 in the front counting from passenger's side
Mar 09, 2010 | 1992 Ford Explorer
How the wire go connected to the spark plug
You may have put the wires in the wrong location, usually there is a diagram located under the hood to tell you where the spare plug wires goes, also located in the operators manual there should be the diagram for the spark plugs.
Jan 07, 2010 | 2001 Oldsmobile Alero
HP Compaq Presario SR5501F Athlon 64 X2 4200+ 2.2GHz 1GB 160GB DVD RW DL Vista Home Basic  PC Desktop Logo
1,111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
