Question about Curtis-Mathis CM27101S TV
Nedd to reset TV manually...... remote is not working
Curtis Mathis Model #CM19022S. I must have hit a wrong button and took TV off TV setting. I need to find TV/video button manually because my Reomte is not working. All I have is snow???? I have turned On/Off and tried Custom settings etc.......no go.
    New Friend:
I have a curtis Mathis model number cm19102 . I have no remote. It is stuck on no more than 14 channels. Then the word line comes up on blank screen. How can I get it to get more channels
Posted on Jan 21, 2015
5 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: Curtis Mathis TV
Not a lot of info your giving us, but what it sounds like is the closed caption is on. Take the remote and there should be a button on the original remote unit, or the closed caption is controlled by the menu. Good Luck
Posted on Sep 05, 2007
SOURCE: no audio
i would be looking for electrol capacitors near the audion chip or audio amplifier
Posted on Feb 15, 2008
SOURCE: curtis mathis universal control code for 13 in tv cm13102
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
Posted on Apr 26, 2008
  • 4090 Answers
SOURCE: Philips universal remote needs code for Curtis
Try these
Curtis Mathes
0047 0466
0016 0054
0060 0093
0145 0030
0154 0451
0166
Please rate my help++++Thanks for using FIXYA
Posted on Jun 09, 2010
I have an old model Curtis Mathis TV and cannot find the code to program my remote. Do you have Curtis Mathis codes at all?
Have you tried downloading the user manual for the TV model you have if there are codes for the REMOTE it should tell you .
Jan 08, 2016 | Curtis Televison & Video
Need the code list for quantum view model QTC32A7F to set remotes
I found a perfect fix for the 32 inch Quantum View TVs with a DirecTV remote.
Press Menu (on your directv remote) , go to settings/help>Settings>RemoteControl>Program Remote>TV.
When prompted to choose a brand, select CURTIS MATHIS. The codes from Curtis Mathis should match the codes for your Quantum View TV.
Note: Make sure the remote can 'see' the receiver during this process.
Sep 09, 2012 | Televison & Video
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
I have a universal remote control that I want to use with my Curtis Mathis TV. What code do I need to use to make the remote compatible with the TV?
Hello
Thee digit universal remote code for Curtis Mathis are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jan 10, 2011 | Curtis-Mathis CM25011 25" TV
I have a working 1993 Curtis Mathis tv model #1953TB and the remote does not work very good any more and I've been trying to find a "universal remote" replacement that has the "sleep...
We would be happy to help you with getting your DISH Network remote to control your TV. located on the top of your remote until all mode button back lights come on, then release. Use the number buttons to enter the codes foryour Curtis Mathis TV; here some of the codes we currently have: 516, 670, 219, 507, 674, 680, 708, 664, and 650. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Keep in mind that some codes may not be compatible with your equipment. If this is the case, please try the other codes listed for that device until you find one that is compatible with your equipment.
We hope this help and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Dec 02, 2010 | Curtis-Mathis CM32010 TV
No sound
Check on the manual control on the tv itself Vol + - buttons see if functions normallyTry website like Remotes.com to buy a remote same as an exact original remote.
Jul 16, 2010 | Curtis-Mathis CM27101S TV
I have a curtis mathes/tronics tv Made in May/2001 Serial no#CM19022S I am trying to hook up a digital conventer box to it and I am having troubles. I also need a users manual for this model and year, pls...
No need for the tv manual.Just follow the basic hook up instructions in the booklet came in with the Converter box.Very easy use channel 3.Use the codes for Curtis-Mathis tv in the booklet for the remote.I hook this Exact model of tv is take 20 mins.
Feb 17, 2010 | Curtis-Mathis CM27101S TV
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Curtis mathis universal control code for 13 in tv cm13102
Mar 09, 2008 | Curtis CM13102 13" TV
Curtis-Mathis CM27101S TV Logo
424 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Vitally Alcher
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
