2005 Yamaha Royal Star Tour Deluxe Logo
A
Anonymous Posted on Jul 07, 2010
What oil how much. How do i check the oil - 2005 Yamaha Royal Star Tour Deluxe
Anonymous
Level 2:
  • Expert 73 Answers
  • Posted on Jul 25, 2010
Anonymous
Expert
Level 2:
Answers
73
Questions
0
Helped
67026
Points
176
This applies to the Royal Star, Tour Deluxe, and Venture 1996 and up. Crankcase capacity is 3.7 US quarts (3.5 liters) without filter change, 3.9 US quarts with new filter. The clutch and transmission operate in the same oil; Yamaha recommends oil changes at 4,000 mile or 6 month intervals (whichever comes first), filters at alternate oil changes, but most tourers change filters whenever the oil is changed.
Oil, religion and politics are topics upon which there is considerable debate and no agreement; neither religion nor politics, however, will leave you stranded 50 miles from nowhere with a seized or galled bearing or broken gear or shaft. Poll tourers - I've found most take the advice of OTR truckers and buy the best synthetic oils they can find. Three names keep coming up - Mobil Delvac 1, Mobil-1 SUV and Shell Rotella T Synthetic. The last is available at Walmart for $19.00 a gallon, I use it in eveything - car, scooter, bike, lawnmowers, rototiller. The last car I got rid of was a Camry V-6 with 306,000 miles on it; I gave it to a nephew that needed a car and it's still being driven daily at U.T. Austin; mileage at last checkup - 355,000, and, except for spark plugs, I've yet to touch an engine component. The RSTD has 121,000 miles on the clock, and still strains a weak battery at start-up; I have no idea how long the engine may last.
To check the oil level, look for a glass window on the right side of the crankcase marked for high (max) and low (min) levels. Get on hands and knees, have somebody hold the bike upright, and look under the front crankcase cover directly beside the right operator's footrest; you'll probably need a flashlight to read it.
  • Anonymous Jul 29, 2010
    LATE NOTE!!!!
    I've always warned people
    away from oils that were labeled "energy conserving", but lately I've
    noticed that those same oils no longer carry that label. I've been
    seeing a new seal on the same oils; on the outside of the seal are the
    words "American Petroleum Institute" on the top, "Certified" on the
    bottom, and in the center of the seal are the words "For Gasoline
    Engines", and - surprise, surprise! - they ALL contain molybdenum
    disulfide, the stuff that makes clutches slip.
    Check the bottles of the oil that you're considering for use in your
    motorcycle. If you see the API seal, keep going. Unfortunately, a
    member named "rasolheim" is learning the hard way how expensive an
    error like that can be; I hope that I can warn others before they make
    the same mistake.
2answers
Oil light flashing
oil light means loss of oil pressure.. not good ..check oil level fill to full if low..low oil pressure will cause fuel pump to be shut off..
Low oil pressure in a ford sabre 350c marine.
Check oil level in sump. Check for correct viscosity of oil for area and temperature. Have the oil pressure check on a master oil gauge to check oil sender unit. Low oil pressure comes from worn big end/ main bearings---worn hydraulic tappets-- loose head tension and oil leaking from head gasket.
2helpful
Peugeot 207 oil level increase
Check to see if gas is getting into the oil which would raise the level. This can happen from flooding, i.e. a leaky injector dumping too much gas or possibly gas blowby past the piston rings and ending up in crankcase. If gas is in the oil most likely an injector is bad. Smell the oil and check to see if it smells like gas and or check viscosity of oil.. thin oil
2answers
Oillifter noise, oil getting sticky
Need to check the oil pump pressure or if there is a lag in pressure. You need to check if the oil lamp lights up soon after starting and if so the pressrure can be low. Also check the quality of oil , change the oil if this was not done for a long time.
3answers
My oil light is flashing red and making a dinging noise
Could just be out of oil. Check the oil. Don't drive it! If it has plenty of oil the oil sending unit maybe faulty.. Best have a shop check engine oil pressure with a mechanical oil pressure gauge before driving it.. Engine will be ruined if you drive it with no oil pressure.
2answers
Oil light came on. checked oil and it is fine. car does leak about a quart of oil every two weeks. is this a oil pump problem. if so, how do i check
check for a leaking oil pan gasket. or a leaking oil filter. the oil pump is inside of oil pan. good-day! and also check the valve cover gaskets out.
2helpful
2answers
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
How to check oil and when to add oil
Check oil when oil is warm use a towel the stuffs hot.
Theres a yellow dipstick under the hood located on either side of the engine or on the back side of engine.Pull the dipstick out wipe it clean then check the oil after the oil is warm and the car sits for about 4 minutes not running.Gets all the oil to the pan.Check then if its not to the line on the warm side of the stick add oil. Check oil monthly and change oil every 3,000 miles you can add oil to the oil if low before 3,000 but do not mix two different oils use oil that the truck requires usually it tells you on the cap or inside the hood .
2answers
Oil light on
first make sure oil level is up, then check or just replace oil preasure switch, if light still comes on, have your oil preasure tested, could be low oil preasure or electrical problem start there. good luck.
I have a 1992 toyota camry LE, 4 cyl. and the oil indicator light keeps flickering on and off, what is the problem. I have checked the transmission and the oil levels and they are all okay. Confused as to...
Is it an oil pressure light or an oil change light (check the owners manual) If its an oil change light it may be time to change the oil. If its an oil pressure light you could have a short to ground in the wiring or at the oil pressure sender mounted on the engine. Also are you checking the engine oil with the engine running or off. The transmission is checked with the engine running, engine oil with engine off. If it is low on oil it will intermittently flash. Also when you check the oil wait five to ten minutes after the engine stops to let the oil settle before checking or you may get false readings.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
