Question about GE (PSS26MSRSS) Side by Side Refrigerator
My refridgerator runs all the time and the fridg side is not cooling properly. What could be the problem?
    President:
  • 2,468 Answers
Check in the feezer compartment rear wall for frost build up,if so remove rear freezer panel and thaw out with a hand held hair dryer,then check the continuity of the defrost heater element to see if its bad,if not check the defrost timer or adaptive defrost board for problems
Posted on Jul 17, 2010
SOURCE: refridgerator is not cooling properly
Ours does this too; it says its 34 degrees but really its 53-58 degrees. . . The compressor coolant part of the machine freezes and then it can't circulate the cold air to cool the fridge. You have to unplug it for at least 24 hours to let it thaw, or you can take out the lower drawers and shelves, unscrew and remove the lower back pannel (from the inside of the fridge). We use a blow dryer to thaw out the ice block that formed on the unit. It goes faster if it is unplugged, this fridge is horrible we lost hundreds of dollars in groceries before we figured out the problem.
Posted on Aug 02, 2008
erpaalai
  • 999 Answers
SOURCE: the fridge doesn't cool anything
There is a damper that allows air into the frig side to cool it. There should be a tech sheet in the toe grill with a diagnostic to check the damper operation.
Eric
Posted on Jun 30, 2009
  • 403 Answers
SOURCE: fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Posted on Oct 06, 2009
  • 2699 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
  • 3 Answers
SOURCE: ED2KVEXVL Whirlpool refridgerator - not cooling in refridgerator
Tip: Most self-defrosting household refrigerators that loose part or all of their cooling in the freezer or fridge are having problems with the self-defrost system. Three components to check: defrost timer; defrost heater elements (esp. on side x side units); and evaporator fan. All cold air is normally produced in the freezer, then circulated via evaporator fan to the refrigerator section. About every 12 hrs. a defrost timer turns off the compressor, and turns on the defrost elements to melt the frost from the evaporator coils. This normally takes about 20 minutes to complete, then the timer turns off the heaters, and restores normal cooling operations. If the cycle does not complete properly, the coils will "ice up", restricting proper air circulation through the freezer and refrigerator sections. Worse yet is if timer sticks in defrost mode (rare), it will turn the freezer into an oven. If the defrost system seems to be working normally, then you should check the condensing coils for excess dirt, and vacuum &/or bush the dirt and lint out to restore proper head disipation. It's recommended that you vacuum out a condensor that's located on the bottom of the unit once a year. You should also check the condensor fan (if present) for proper operation. If the condensor fan fails, heat can not be properly released from the condensor, and will cause the refrigerator to 'run all the time' yet not cool efficiently. There are many things to check on modern frost-free refrigerators, before turning to the actual sealed refrigeration system and compressor unit.
Posted on Jan 11, 2010
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Freezer control works fine but refridgerator side not cooling properly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 27, 2010 | KitchenAid Refrigerators
The refridgerator is not cooling - coils are not iced over. what should I try now? Both sides not working properly. This is a side by side model.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
tut
Aug 01, 2010 | GE GSH25JFR Side by Side Refrigerator
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag refridgerator not cooling
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Fridge not cold
I think that I have a solution. Refridgerator side not cooling.
I read in the blogs that holding down the top two bottons(power cool & fridge) at the same time resets the refridgerator control panel.
I may have caused the problem by leaving the door open. If my above solution does not work, then I will defrost the frefrigerator just in case the coils are froze up. It works with my air conditioner.
Ed
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
129 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
