Konica minolta 4960 has an error "check print mode" customer is wondering how to clear or address this issue
Press the left button key, scroll down once and select tray 1, and select continue.
Posted on Dec 22, 2011
  • pell dumpster Aug 23, 2013
    I have a 4695 and this worked for me. Thanks!!!
  • Renee Fisk
    Renee Fisk Feb 13, 2015
    Thanks! KM Bizhub C20 up and running!
Konica minolta 240f error code 18 stands for what
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20240F&code=18
Konica Minolta bizhub 240F Error Codes
Quoting from the web link shown above:
Konica-Minolta bizhub 240F Error Codes
Exploded Views and Parts List Free!
Code
18
Description
Fuser Error
(The number indicates the detailed error code) 0 The fuser did not become to the main motor driving temperature in 50 seconds after printing started. 1 The fuser did not become to the paper pick-up temperature in 50 seconds after printing started. 2 The fuser did not become to the main motor driving temperature in 30 seconds after warming up started. 3 The fuser did not become to the warm-up finishing temperature in 30 seconds after the motor started driving. 4 A temperature of 250°C or higher is detected in a mode other than sleep mode. 5 The fuser does not warm after fuser error is solved and the power is turned OFF/ON. 6 A low temperature of 10°C is detected in 10 seconds after printing started. 7 A temperature of 190°C is detected in ready mode after printing finished.
Remedy
1. Turn on the power again, and verify the fuser warms up. If it does not, see step 4. 2. Check the contact between Fusing thermistor and Connect A PCB(P89). 3. Check the contact between Connect A PCB (P80C) and the main board. 4. Replace the Fuser. 5. After replacing the Fuser, verify the fuser warms up when the power is on. 6. Replace the main control PCB.
Apr 07, 2018 | Konica Minolta Office Equipment & Supplies
I need help to clear error 18 on konical minolta 240f.
Code
18
Description
Fuser Error
Remedy
Nov 19, 2017 | Minolta Office Equipment & Supplies
After upgrading to windows 10, unable to scan doc from Konica C203 to PC
To help you troubleshoot the issue about unable to scan but able to print, it is recommended to try uninstalling the previous software and driver and re-install Konica Minolta BizHub C203 printer software and drivers from the link given below:
http://www.biz.konicaminolta.com/download/driver.html
If issue persists, you can find the troubleshooting link and check if that helps to resolve the issue:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C203&page=1
If issue persists, it is recommended to contact Konica Minolta bizhub for further assistance:
GuruAid.com
Jun 13, 2016 | Konica Minolta bizhub Office Equipment &...
Change the clock on a konica minolta bizhub 423
Go to cofiguration settings, scroll up/down to see the item you want to make changes.
Mar 10, 2015 | Konica Minolta Bizhub 423 Copier Printer...
How to make Konica Minolta copier online?
What model? Can you ping it? Does it show up in the control panel as available. have you reloaded the print drivers have you power off the machine then powered on. have you cleared all print jobs in the print que. Those it copy ok? Ethernet cable ok or using old serial? Can you print from a different computer. have loaded the IP address as static most copiers do not like DHPC where the server decide the IP address. Always use Static you tell the copier what IP address to use. Mite also check to make sure you have the right drivers for the machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 03, 2014 | Konica Minolta bizhub Office Equipment &...
My printer drypro model 832 is giving me an error 4122 what should i do the hospital is stuck,my email address is ssekania@gmail.com please help.
My printer drypro model 832 is giving me an error 4122 what should i do the hospital is stuck,my email address is anan4937@gmail.com please help.
Aug 22, 2012 | Konica Minolta Minolta Laser Printers...
KONICA MINOLTA CHECK PRINT MODE ERROR
check printer mode how to ,i will clear
Feb 12, 2011 | Computers & Internet
We have Konica Minolta Bizhub 250 What does error C2557 mean
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Sep 20, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
1,251 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
