Question about Amana Heating & Cooling
Ruud achiever 13 the outside unit needs a new motor. Can I do it myself?
  • 407 Answers
(IMPORTANT) Disconnect all power before you work on any part of the electrical system on the outside condenser and the indoor unit.
Yes, and it will save you a ton of money by doing this yourself. Besides the basic tools, adjustable wrench, 1/4 in and 5/16 in sockets ( nut drivers or a drill will work best), the only special tools you will need is a fan blade puller, which is just like a pulley puller. Other than that, it's all pretty straight forward. Remember each wires location before you disconnect them. You will need to have the following information to buy a new motor-
H/P example: 1/4 HP
RPM example: 1075 RPM
Volts example: 208/230v
The best way is to pull the motor and take it with you to the supply store. Make sure you get a "REVERSIBLE" rotation motor. This will be to insure it turns the right way after you install it. When you turn the unit back on, it should blow air out of the top of the unit. Installation is reversed from how you took it out, but you will want to make sure the position of the fan blade is the same when you set it back into the unit and by that I mean on the shaft of the motor. The only other thing you will need is the new capacitor for the new motor, it will tell you what MFDs you will need on the new motor, just ask when you pick up the motor from the supply store. You will need to buy these things from an Heating and Air supply store, but you do not have to be licensed for these particular things. If you are even somewhat mechanically inclined, this shouldn't be a problem at all. Hope this helps and good luck!
Posted on Jul 17, 2010
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
I have a 15-year old Ruud Achiever 10 A/C unit outside that has blown a second set of fuses in just a month. The fuses are in the box on the wall adjacent to the unit. What may be causing the fuses to...
A BAD RUN CAPACITOR INSIDE THE CONDENSING UNIT ?.SEARCH YOUR AREA FOR FREE CAPACITOR TESTING.OR LOCAL ELECTRIC MOTOR REPAIR.. CHECK THAT FAN SPINS FREE, IF NOT, IT CAN BE OILED .. SEARCH POST ON OILING FAN MOTORS
Jul 26, 2011 | Ruud Matching Split Air Conditioner
Ruud Achiever® Series 13 SEER the fan will not spin I have checked the breaker is there a reset button inside the unit?
There is a reset button on the outside of the unit near where the tubing and wiring comes into the unit. The button is encased with a red plastic cover. If the unit is making noise but the fan is not spinning, the problem may be related to the fan itself. First with the unit turned of, see if the fan spins freely. Then fire the unit up again to A/C and see if the fan is not moving. If not, carefully nudge the fan blade with screw drive in the direction it normally moves. if the fan engages, most likely the bushings are old and need to be replaced; RUUD may only sell the entire fan assembly.
Aug 14, 2010 | Air Tools & Compressors
Wiring diagram for contacts on the outside unit
I have a wiring diagram I can send you. I took a picture of mine. Mine is a Ruud Achiever PNE 2 ton.
May 23, 2010 | Ruud Matching Split Air Conditioner
Ruud Achiever 10, outside Fan wont spin unless I help it.
The part you are talking about is called a capacitor. They come in various voltages and ratings. The best thing to do would be to find the rating tag on the motor, and look for the capacitor rating. There are many, many different sizes and types, so it is best to consult a proffesional before attempting to replace it on your own.
Jul 06, 2009 | Ruud UBHC Air Conditioner
I have a RUUD Achiever 11 and the outside fan does not come on, and house won't cool. Was told I need a condenser unit. Perhaps I'm overly skeptical, but wouldn't replacing the fan be an easier (and less...
depends on the condition of the unit and if the condenser fan motor is the only problem?
whoever told you that you need a condenser he or she needs to tell you why and point out the issues with what you have seems to me.
to answer your question it would be yes to the fan motor vs.condenser
Jul 05, 2009 | Ruud UBHC Air Conditioner
Replace Rudd Achiever 10 ???
if the fan motor outside let go it could overheat the compressor which he should have known before he replaced the motor. also there is no way of knowing if there is enough freon in the system if the compressor does not start,your best bet is to get another repairman as a second opinion
May 12, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
