Question about IOGear (GWA502) Router (DHGWA502)
Having trouble resolving my strict nat on xbox 360 live through my router if i hook up straight to my modem my nat is open but with the router hooked up its strict
  • 708 Answers
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
Posted on Aug 26, 2010
  • 182 Answers
Open the GUI page of your router and configure DMZ
(Open command prompt on your system, Start>RUN>CMD, type ipconfig in the black window, check the default gateway, put the same address in the address bar of your internet browser like internet explore, it might ask you for username and password, which would be either 'admin' 'admin' or admin for username and 'pasword' for password)
Put your XBOX in DMZ and it should work
Or else simply go into advanced configuration in the Router GUI page and disable NAT
Posted on Jul 17, 2010
My xbox is telling me that my router's NAT setup is on moderate. what does that mean? and how can i fix it?
Here is Microsoft's definition of a moderate NAT and their suggested fixes.
http://support.xbox.com/en-US/xbox-live/connecting/nat-type-strict
Dec 24, 2011 | Microsoft Xbox 360 Console
How do I change the NAT type from strict to open so i can play xbox 360 I have a Belkin 3D54 router
There are several things you need to configure in order to change your NAT to open. Here's a link to help you out:
http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
It has steps that can help resolve your issue.
Mar 27, 2011 | Belkin Office Equipment & Supplies
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Feb 10, 2009 | Linksys WRT160N Wireless Router
Open NAT with Thomson (Speedtouch) TG585 v7 Router
First, try adding a wireless card to the Xbox, run the wireless off of the router OR if you have multiple connections (broadband, should be an "In" port, and several "Out" ports) Try connecting your PC and you Xbox through the "Out" ports, with the cable modem cord hooked into the "In" port...
Feb 02, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How do I turn NAT from strict to open on a 2.4GHz router
sir try to view your router using the web base configuration, locate the NAT configuration and enable DMZ function. it should open all ports with your xbox
Sep 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
NAT
Everyone has NAT, whether its strict (which i'm guessing yours is) mederate, or open.
Open NAT can be achieved by buying a new router or connecting your 360 via ethernet to your modem. If you connect it to your modem, restart both the modem and your 360 and you WILL have an open NAT
-Erk
Jun 08, 2008 | Microsoft Xbox 360 Console
Xbox Live Strict Nat
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
May 05, 2008 | Microsoft Xbox 360 Elite Console
Xbox Live (Xbox 360) Strict NAT PROBLEM!
You can hook it up to your computer where the ethernet connection is then plug in your internet through USB and if it still doesn't work then it is most likely a problem with your computer's security at that point. You can also call 1-800-MYXBOX for technical support and every time i have called they have been pretty good and they were also American every time so they were easy to understand.
Mar 12, 2008 | Microsoft Xbox 360 Console
Nat / strict
First, why are you connecting to your laptop? Second, reset your modem and router. I doubt you need to open ports that are not normally open...but if you think you need to do more, access the router and open the ports manually.
Nov 27, 2007 | Microsoft Xbox 360 Console
IOGear (GWA502) Router (DHGWA502) Logo
134 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
