Question about Husqvarna 24HP VTwin Hydrostatic 54" Cut Riding Mower
Turn key wont starts
Installed new battery turn key on nothing swithed on front lights nothing. checked battery ok. are there any fuses
  • 51 Answers
Yes there should be,its ether near starter solinoid or near battery
Posted on Jul 18, 2010
2009 jeep commandeer wont start, when I turn the key there is no sound, lights wont turn on and is that wasn't enough the key gets stuck in the ignition. any ideas?
it wont crank, no A/t car starts unless cranked first. (a key point)
fix head lights first. this is a feature in all cars.
that is SIMPLE and HOT all the time
they must work at all times and is the top way to diagnose
electric problems
you have a dead battery,.
only why remains.
i bet it cranks jumper cable started, call AAA or buy some cables.
or swap in a charged battery , or heck charge yours, buy a charger.
check fuses.
check battery lugs for green death?
check battery voltage. at 12.6vdc, if not charge the battery
if the battery continues to disgharge.
that is called phantom drains, or bad battery .
or the alternators is bad.(system)
once started the battery volts must be 13.3.to 15v, if not the charge system is bad ,(fuses, belts slipping and lots more possibles)
Sep 19, 2014 | 2009 Jeep Commander
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
93 infinity j30 wont start
CHeck for loose/bad connection at battery and starter.
Jul 19, 2012 | Cars & Trucks
My 2002 dodge caravan wont start i turn the key and nothing
Start by cleaning battery terminals try to start if headlights are bright and nothing check the starter relay by the fuses stick the same type from another circuit or a spare one where it says spare. Try to start if the lights are bright hit the starter with a hammer a few times while someone has the key turned if it starts you need a new starter. If lights go out recharge battery or replace battery
Nov 05, 2011 | 2002 Dodge Grand Caravan
Car wont start have power everywhere but when i turn key nothing, could it be a fuse or neutral safty swith? starter new, battery new
alternators usually make a noticeable whining sound when they are going bad. if you picked up a used starter it could have died already. bad starter core. could be a fuse somewhere. idk im not an expert. 2 fuse boxs. under the hood closer to the windshield. the other is in the drivers side footwell. if the turnover clicks starter should be alright. if not you'll need a new starter.
Oct 13, 2011 | 1994 Oldsmobile 88
Car wont start. when you turn the key everything lights up and i get nothing. i just replaced the starter and its still doing nothing
check for fuses,starter relay,and look at clutster if there is a ligts flashing,it might be has a tefft system fault,try start in neutral,it could be the neutral swith too.
Nov 23, 2009 | 1995 Buick LeSabre
2005 king quad wont start
Double check the voltage on the battery. I have seen batteries with a bad cell when they are brand new.
Oct 05, 2009 | 2001 Suzuki Burgman 250
Bike will not start no power
Touch a 12" piece of wire to one terminal then touch the other end of the wire to the other terminal. Got a really good spark? No spark = bad battery. Okay, so you do get a good spark. Check the wiring harness for an unplugged wire. Also check for loose connections and burned wires. Bad ignition switch? Kill switch turned on?
Mar 13, 2009 | 2005 Honda CBF 500 ABS
Husqvarna 24HP VTwin Hydrostatic 54" Cut Riding Mower Logo
196 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
