I bought a Panasonic DVD (DMREZ25) last June and it has now frozen up with the signal "please wait" flashing constantly. No other controls work and I've tried switching it off, there is a disc inside.
    Master:
  • 518 Answers
Try unplugging the unit, wait 30 seconds and plug it back in then hit eject.
Hope that helps...
Geno
Posted on Apr 21, 2008
"Please Wait" flashes continuously. Cannot
I was wondering if you found a solution for the "please wait" flashing. Mine started doing this today, last night it played a blue-ray fine then I turned it on this morning and all it does it starts to turn on and then just flashes "please wait". Mine is also about a year and half old.
Aug 27, 2011 | LG BD390 Blu-Ray Player
Frozen up with please wait read out on unit
Hello MrBrokeit, Shotgunning works sometimes, but the effort spent is often not worth the time spent. Let me explain if your power supply is defective then shotgunning will produce results, however if the problem is elsewhere you will never know it. I would suggest troubleshooting the unit, to determine where the problem really is. For this task I would suggest that you get a schematic diagram of the unit, a multimeter, and an oscilloscope. use the schematic to find the various test points, use the multimeter to measure the voltages at the test points, and then use the oscilloscope to measure the signals at the test points. Troubleshooting in this fashion will produce better results than as with the shotgun method. I would suggest checking for ripple voltage in the DC path. This voltage is due to AC bleed over from poor regulation by malfunctioning filter capacitors. you will not see physical signs of the problem but a quick check of the capacitors will let you know if the is the problem. Also check to see if the DC voltage across the positive terminal of the capacitor is held at the level it should be at. Then check all points on the power supply and compare them to the schmatic. Thank you, Shuttle83
Oct 09, 2007 | Panasonic DMR-E85H DVD Recorder
Tip
DVD stuck on Panasonic DMR ES10 in eternal cycle of "self check"/"please wait"
My DMR ES10 was eternally in a "self check"/"please wait" cycle. Couldn't even turn it off normally. By pressing the "Power off" for 10 seconds it will turn off forcefully. Now, after it says "BYE" press the "CH UP" (on the recorder, NOT on the remote))+"STOP" (with the recorder turned off) for another 10 seconds. This will force the opening and we now can take the DVD off. Turn the DVD recorder ON and, if the problem is on the laser, because of dirt, etc it will work and we can now run a DVD cleaner. In this case, the machine was stuck just because the first thing it does is check the DVD inside, and because it can't and just keep trying, it will never do anything else, until we take the DVD off with it turned off.
on Oct 18, 2013 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmrez25 dvd recorder display showing u80 and can not change channels. no tv display but dvd still works.
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Jun 02, 2010 | Panasonic DMR-ES10 DVD Recorder
Watching dvd, great pictue and all of a sudden black out
7 Blinks is the failure of the SC/SU/SD PCB's (1 2 or 3 depending on how lucky/unlucky) you are.
Panasonic have a great warranty usually. Give them a ring, it has failed.
The flashing LED is the fault code.
Sep 06, 2009 | Panasonic TH-42PZ77U TV
"Please wait" ... panasonic dmr-e85h seems frozen
Have you tried unplugging it for a couple of minutes?
Aug 25, 2009 | Panasonic DMR-E85H DVD Recorder
Need operating manual
CLICK HERE for your owners manual in PDF format.
Thanks for using FixYa - a FixYa rating is appreicated for answering your FREE question.
May 25, 2009 | Panasonic DMR-ES25 DVD Recorder
PANASONIC DVD RECORDER DMR-E85HP
Check caps on P/S C1270 and C1271 if puffy replace with {2} 1000uf 35vdc and you should be fine.
Jan 12, 2009 | Panasonic DMR-E85H DVD Recorder
Locked up. Hard drive frozen?
i have the same frickin problem.someone please help
Dec 29, 2007 | Fostex MR16HD/CD Digital Recorder
Please help me with the set up of two Panasonic DVD recorders
To record and veiw DVD movie at the same time connect the DMRE55 RCA cable output to DMREZ25 input 1 then the DMREZ output to yout TV input. Then on the DMREZ press input select and select IN1 to record from the E55.
Nov 04, 2007 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
