Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Zero Model 550 Ice build-up in the freezer
I have a Sub-Zero 550 and ice builds up in the freezer. Several years ago I had a Sub-Zero approved service company work on it, and they added a heater assembly in the drain tube. This worked for a couplke of years, but the problem came back. Called service again and they found the heater assembly "shorted out" and melted inside the drain tube, so they can't install a new heater assembly since the previous installed one is broken / stuck inside the drain tube. The repair company says they can't do anything else to fix the problem. Since the ice returns about 3-weeks after I fully defrosted the freezer, it is not usable. I can't live with defrosting every 3-4 weeks.
I read somewhere on the internet were someone had the same problem. They solved it by pulling the built-in out from the wall, cut into the side of the freezer to gain access to and replace the drain tube, and then sealed it back up. I am a handy person, but that operation seems a built drastic for me to handle. And I am sure a reputable service company would not take-on such a repair.
Any ideas? I hate the idea, and can't really afford, to replace a $8,000 built-in refrigerator. It is especially upsetting that it is such a simple and low cost problem (meaning it's not as if the expensive compressor's went bad).
Rotu
  • 175 Answers
SOURCE: refrigerator not cooling top shelf
it sounds as though you have a fridge that is low on freon. If the ice is appearing mostly to the left, then thats surely your problem. if it goes all the way across, you may have a bad evaporater fan motor, fan motor switch, bad cold control, or just a door that isn't closing or sealing properly. If its the ice mostly to the left side, it probably means your evaporater is leaking the freon. I am assuming you have a model that has a cold control on the back wall, not the electronic display by your description. If your unit is less than 12 years old by the installation date, the part will still be under warranty (sub zero has an unmatched 12 year sealed system parts warranty) but the labor and freon will not be. The repalcement of that evaporater in my area usually runs about $450 with labor, freon and trip all together. It is a repair you cannot do unless you have an acetlyn torch and some silver-soldering/ brazing ability. If your model is in fact the newer style with the electronic temp display, call sub zero up (the # is on the model/serial tag in the door jamb) and tell them wahts going on. If it is in fact an evaporater leaking on this style, they will most likely pay the bill for you even if its well out of the 5 year full warranty. If you want to know for sure, remove all the shelves, then remove the cover over the lights. Then if its electronic remove the 3 screws holding the top of the back panel and tilt the panel out to you and pull it up and out: if its a dial type, remove the 2 screws holding the fan cover and then tilt the back wall out to you and lift it up and outwards, but not too far as it wil pull the wires of that control knob (cold Control) Look at the coils back there and see if the coils are frosty. If they are only frosty on the upper left of the coil, its low on freon and needs an evaporater. if its frosty all the way across, top to bottom, you need a cold control, or possibly a fan or fan switch. Hopefuly you can wade through all this. Just post back if you have any questions. Good Luck!
Posted on Aug 16, 2007
  • 56 Answers
SOURCE: Sub-Zero 550 water dripping on right side of freezer forming ice on draw
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
  • 37 Answers
SOURCE: My Sub-Zero drain ices up too!
There is a drain tube heater and a floor pan heater kit for this model from Subzero
This is Not for a DIY project
Affordable Appliance Repair
Lake Forest, CA.92630
Posted on Aug 22, 2009
  • 1274 Answers
SOURCE: I have a Sub Zero fridge about 15 years old. The
try turning the thermostat down a little,..........don,t know what you got it set on ........but water freezes 32 degrees
Posted on Feb 16, 2010
  • 83 Answers
SOURCE: A service rep was out
just a thought sometimes when the defrost has been set you have to go and reset the freezer temp. it should be around zero-f ..... when you reset the freezer temp you should hear it start up. if that dont work call the service company and explain over the phone you need directions to reset or turn it back on.. and tell them if they have to come out you shouldent have to pay because the freezer was working before they came.... and you should have no problems.... the last thing they want is an unhappy customer.. atleast the good companys... good luck i hope this helps
Posted on Aug 13, 2011
Sub zero 501 freezer and refrigerator ice builds up on back panel
Possibly the timer that controls the defrost cycle is defective.
Do you get any defrost melt water in the pan below the frig?
Sep 01, 2012 | Sub-Zero Refrigerators
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice build up behind the veggie drawer. My 550 is 13 years old. This always starts with the warm, humid weather, but this year, it is not improving as the weather turns colder. Any advice? I can't open the...
sub zero are vey expensive, and sometimes tough to diagnos, but judging by your description, i would inspect your door seal, make sure it is closing and former a good seal all the way around
the best way to handle this, is to turn it off for the day, and let it defrost for 24 hours,
Oct 13, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero Freezer ice keeps building behind coils
in 601 model. really common problem is the drain hater. watch close the ice maker for a BIG long ice. on the cotton psrt of the back wall. some models have 1 some 2 depends in the serial num. ask you tech for replace the DRAIN TUBE HEATER. that way your cover. really helps a lot the code number...................good luck................. leave a comment...........thanks
Sep 28, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Aug 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
10+ years old sub zero 550. ice cubes are green
I would not recomend using those ice cubes. Sounds like theres lots of mold or worse growing in your freezer. I would get rid of it. ;(
Jul 09, 2009 | Freezers
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Sub Zero 550 Frost Build up in Refrigerator
This means you are low on freon. You will get an ice ball on the bottom left side in the back of refer.
dartmanc
May 27, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
342 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
