Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Wont get cold
The fridge is only 3 yrs old. has worked perfectly. i unplugged it for about a week and a half and put it up for sale. the people who bought it claims its not getting cold. they plugged it in for two hours and said it never got cold. i have a problem believing this.
    President:
  • 2,047 Answers
Normally when a fridge is moved from one location to another it has to be put down for a while for the gas in the compressor to settle to its normal state before it should be plugged. To solve this tell the buyer to allow the fridge a little while probably about a day to settle and then put on the fridge it should function properly if this is done.
If this is not the problem with the fridge then probably in the process of transportation they accidentally bumped the unit against something which might have affected the control board or something. this shouldnt be a liability on your part (unless you arranged transportation).
The buyers should also ensure that the current powering the fridge is sufficient as this happens to be the cause of a lot of refrigerator problems recently.
Hope this solution has been helpful?
Posted on Jul 17, 2010
My fridgedaire fridge FRT856embg wont get cold on the bottom
Im not familure with this item but on the older style fridge ice would build up in the freezer blocking the air ways to the bottom half of the fridge in this case you would need to remove the food from the freezer and fridge and unplug it open the doors and let it thaw out for a day or so I wish you luck and I hope this was helpful
Dec 07, 2012 | Frigidaire FRT21H8 Top Freezer...
I've got the device for three weeks. It was working fine at temperature 4. But it was too cold so i turned it down to 3, still tooo cold then turned it down to 2. I even switched it to zero for a while...
I would say your thermostat in the fridge has had it. Try the internet for a local appliance parts sales shop, give them the make and model number and / or get a fridgie in to fix it.
Jun 16, 2011 | Heating & Cooling
Fridge had a lot of frost at the back (top fridge/lower freezer), turned it down and it defrosted, however, the freezer doesn't seem to be working properly either. Defrosted it all last night and this am...
It sounds as if the freezer coils and vent stack are frozen solid. This usually requires
removing the back panel in the freezer compartment and defrosting carefully with
a hair dryer. (If this becomes frozen it blocks off the fan/vent that feeds cold air down to
the fresh food compartment) Make sure to unplug unit before servicing as you will need
to unplug the fan to remove the back panel.
While doing this check the defrost termination thermostat (a small device attached to
the tube with two wires coming out of it). The black plastic ones sometimes come apart
and fail.
Once defrosted put everything back together and test.
Hope this helps.
Mar 15, 2011 | Refrigerators
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
if u can hear the compressor going , then dont worry about fixing it , it would need to be regased , not worth it too old, if u cant hear the compressor going then it wud be a cheap fix wud need a new thermostat or a defrost timer
Jan 31, 2010 | Fisher and Paykel Fisher Paykel 21768 -...
with the unit being that old , the compressor probably whent out the oils inside probably froze up ,,,,, to replace a compressor you are better off replacing the unit it is a major repair
Jan 31, 2010 | Fisher Freezers
FRIDGE AND FREEZER IS COLD AT THE BOTTOM AND WARM AT THE TOP
It is a thermostat problem. It can be fixed but is sometimes cheaper to buy a new one.
Aug 19, 2009 | Refrigerators
Belling Bi60 Integrated fridge freezer (fridge) not working
I also have probs with Belling Bi 60 less than 3 yrs old...already had
enginneer out & paid......now fridge aint cooling showing H
its frost free and this may be too sensitive ??
tried unplugging no Go
wont buy Belling again
Dec 15, 2008 | Refrigerators
Only 3.5 yrs old stops getting cold...
It has a defrost problem.  If the evaporator gets totally frosted up it can't circulate the cold air.  It will be one of 3 things.  I will list by most common.  1.  Defrost thermostat (clips onto the evaporator).  2.  Defrost timer.  3. Defrost heater.  If you have some basic tools and a multimeter I can walk you thru the checkout.  I would need the complete model # from the sticker inside the fridge section.  Let me know if I can help further.
Oct 16, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
23 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
