Question about Krups XP 4050 Espresso Machine
How do I reset the machine to the 50ml/cup factory setting?
I have a similar problem that the 1 cup (50ml) setting now produces about 150ml and the two cup setting just keeps going until the machine is empty.
The manual says press and hold the 1 cup button until it starts flashing together with the power light and the coffee starts flowing, then press the 1 cup button again when you want it to stop and the machine will memorise the new setting. I tried this on mine and it didn't work - I'm guessing something has worn out but dunno what...
Posted on Aug 30, 2010
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
My nespresso stops half way though making a cup of coffee and have to press the button again repeatly to start it again
Has anyone operated your machine that was unfamiliar with the correct method. It sound as though the quantity has been reset. Try holding both buttons down while turning the machine on - hold till buttons stop flashing. This will reset to factory settings. Then, you can programme each button by holding it down whilst extracting, then releasing when the correct amount is extracted. It will remember this until you return the machine to its factory settings as above.
Hope this helps!
Mar 12, 2015 | Nespresso Coffee Makers & Espresso...
Both lights on my older model machine won't stop flashing
Try holding both buttons down while you turn on the machine - hold down till they stop flashing, usually 2 - 5 seconds. This resets the machine to its original factory settings.
Oct 11, 2014 | Nespresso Coffee Makers & Espresso...
I have a Pixie but the large cup does not shut off
Hold both buttons down while you turn the machine on - for 5 seconds - which will reset the machine to its factory settings. Then you can reprogramme to suit your taste, as in the instruction book. Good luck - hope this helps.
May 27, 2014 | Nespresso Le Cube
The machine pours too much coffee for an expresso and even for a normal cup. We have been using it for 3 years and this just started a few weeks ago. I reset the machine to factory settings and it still...
You don't mention if you've programmed the quantity since it started behaving strangely, so....
instead of pressing the 'coffee cup ' icon button once, hold it down all the way through the brewing procedure (it will bip) until the correct amount of coffee has been pumped into your cup, then release the button. This quantity has now been programmed into the memory and should produce the same amount of coffee every time, on a sigle press.
Mar 04, 2011 | Saeco Incanto Sirius Fully Automatic...
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
My nespresso does not make a full cup any more
Another good solution, though the previous one was good, is that you can factory reset the cup sizes. All you have to do is switch the machine off, and then press and hold the large cup button. After about 10 seconds, keeping your finger on the large cup button, switch the machine on -- then let go of the large cup button after about two more seconds.
Aug 15, 2009 | Nespresso Essenza C100 Espresso...
Less water than supposed to be
Hi
The sieve in the brew unit appears to be clogged, you say you have cleaned under the flaps, but are you sure there`s nothing left on the sieve? Clean out all coffeegrounds you find inside there. Also, check the grinder setting; it could be you have set it to fine. This usually makes the coffee barely dripping from the spout. After cleaning and adjusting the grinder setting, you should run a cleaningprogram.
In worst case; the sieve has to be taken out and cleaned, this is not recomended to do without training.
Jul 24, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Nespresso C1OOB not sucking water out of the tank anymore
I had the same issue and spoke to Nespresso this morning.  To solve this you need to reprogram-put a capsule in the slot and place a cup on the drip tray-press and hold the lungo button until the coffee has reached the desired height in the cup and then release the button.  That should work and every time you make a lungo cup it should be that amount. Hope this was helpful.
Oct 19, 2008 | Nespresso C100B Essenza Single-Serve...
2-cup won't work
you can try descaleing it again ,then go into
the factory reset program and reset it , I had a
similar problem this fixed mine
Dec 26, 2007 | Saeco 00034 Incanto Sirius Super Automatic...
Coffee Makers & Espresso Machines Logo
849 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
