Question about Pentair Master Temp 400000 Btu Gas Pool Heater 460736 ()
Have power to the heater. LED lights are lit, but no display, no
Have a pentair 400dv heater was operating ok, then noticed that the power and pressure swithch lights are on but no display, no errror codes and heater will not operate
  • jwdibart Jul 17, 2010
    Are there tests that will tell me what is causing my problem? I know how to use a voly/ohm meter.
  • 532 Answers
If the power and pressure swithch lights are on but no display, no errror codes and heater will not operate, the problem is the thermostat.
Check the thermostat if it is not low, if low adjust it. if the problem continues, multimeter to read the meter. If it is not working replace with a new one.
Thanks.
Posted on Jul 17, 2010
    Guru:
  • 630 Answers
Here is a quote from a customer who had this unit and replaced it, and he goes on to say....quote.....
"If it's anything like the Pentair MiniMax NT we had, the best advice is to wrap a chain around it and drag it to the curb. I'll never buy another Pentair Heater!
This unit was in service for exactly one year and when it was removed, it looked like a 30 year old unit. It was that burned out and sooted up.
After numerous errors and several trips out by their service rep. they now tell us that the Minimax NT was just a stopgap fix for a LowNox system at the time and they have now stopped making them.
They replaced our unit with a 200,000 btu Peerless unit that oddly, resembles R2D2 or a shop vac but it's working perfectly so far.
I was impressed to learn that a 200,000 BTU unit on a 50,000 gallon pool keeps up perfectly, 90 degrees F. all the time."
I just through that out there because I found too many complaints all about the same problems and the solutions all seem to elude the replacement of the controller(DDTC) providing you have the correct incoming power and correct wiring of which I am sure the wiring is fine as it recently was working, are you getting 24 v into the panel, if not the transformer may be the culprit, I mean this heater has a lot of issues so you may be doing yourself justice having a repairman work on it..... another item in question can be the therm sensor,( when the thermistor is bad or voltage to the back of the control board drops below 20vac. 9 times out of 10 it is the thermistor or temp sensor)but all indications are the $300.00 control(DDTC).
A soot build up could cause an issue with either gas pressure or gas flow. With the heater fired the pressure into the valve should maintain no less than 6" wc for natural gas 13" for propane. If the pressure is good, it is a good idea to clean the orfices regularly to ensure good gas flow to the burners.
Hope This Helps.
  • 1 more comment
    how do I check the voltage, I would assume that if the Pwr and Pressure led light I have power?
    I do not get a temp reading and it will not start. I pulled offf the thermistor probe wire and it did not change the display.
    The reply you supplied I already read on line.
  • JOHN DAVIDSON Jul 17, 2010
    If you have never worked with test equipment like volt/ohms meters I would highly recommend not trying to do this cold turkey without someone there to guide you that works with electrical devices as a profession, one wrong step and you can get seriously injured, even the pro's have it happen.
    Hope This Helps.
  • JOHN DAVIDSON Jul 18, 2010
    It is the DDTC controller a part that has a 99% failure rate on these units.
Pentair minimax NT pool water heater. Display shows no code violations. Heater does not come on.
check the roll out switch! or make sure your filters are clean if not those could be a flow switch!
Jun 20, 2018 | Pentair Pool & Spa
I have a Pentair Master Temp 200. My pool tech fixed the E-05 error code a week ago. Now the amber heating led blinks for maybe 30 seconds but the heater doesn't come on and goes to the service heater...
Take off he front panel so you can see the back side of the circuit board.
Turn it on and once it fails see what red lights are lit on the back of the board, this will point you in the right direction as to what needs to be addressed.
Feb 22, 2015 | Pentair MasterTemp Pool Heater 200, 000...
Pentair MasterTemp 250 Natural Gas with "Service System"
possible bad pressure switch or loose wire or plugged line to switch
Sep 05, 2017 | Pentair Pool & Spa
Pentair MasterTemp 250 Natural Gas Heater with "Service System" issue
this heater will display 2 red light related problem 1-service the system mean you need to clean you filter, and service the heater mean it may be a problem with the heater this 2 you will be able to see it in key pad control the heater ,now reset the board and see what happens (CUT THE POWER ON/OFF UNCE )
Jun 09, 2013 | Pentair Pool & Spa
Pentair MasterTemp 400 Stack Flu Sensor Reading Stuck
check gas pressure and for clogged burn tubes unit is overheating
May 12, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
I have a pentair minimax 400dv ,my heater burner comes on for a minute and then,the burner cuts off. The fan keeps running, the burner will ignite again. This will do this several times. Eventually the...
Cleaning the Thermal couple can work at times, however most times you will need to replace it. You may also be having an issue with the ignition control. You are in pretty deep now and it would seem like you are determined to save this heater, I would change them both.
http://www.parts4heating.com/Pool-Heaters-Pentair-MiniMax-NT-400-s/696.htm
Jun 30, 2017 | Pentair Minimax Ch 400,000 Btu Propane...
I have a Pentair MasterTemp Heater 250K BTU (i think) Turned on the spa the heat it today and lost all power to whole Pentair Intlitouch system. Reset system but now heater is showing Service Heater. AFS...
try cycling the power to the heater itself. Check for damage (pack rats, etc..). It sounds like you may have had a direct short. It could be a board problem or a transformer problem. If you're still getting the service heater light, check to see if any diagnostic LED is illuminated behind the board.
Dec 28, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
I have a SR333LP poolheater will not turn on
Those are not service codes. Turn top over and look at the circuit board to see what light is lit
May 17, 2009 | Pentair MAXITHERM 333K BTU PROPANE GAS...
My pool heater will not start. The power light is off and the pressure sw is lit.
You must turn on the pump and let water circulate through the pool and the heater before you turn on the heater otherwise you will ruin the heater
Apr 16, 2009 | Pentair Minimax NT Heater
Pentair Master Temp 400000 Btu Gas Pool Heater 460736 () Logo
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
