Question about Yahoo Messenger
My Yahoo Messenger is not Singing in...(in Windiws 7)
The error message is:
Sorry. We were unable to begin the login process. Please check your network connection and try again.
I am facing this problem with every version of the Yahoo Messenger...
Please help me out i'll be very thankful to you...
  • 182 Answers
This must be a problem with our computer security settings
check your system firewall and put the Yahoo messnger in the exception
or simply try disabling the System Firewall
Also try to unistall Yahoo messenger and delete all entries of Yhoo messenger from registry "Click START>RUN> Type REGEDIT"
and re-install yaoo messenger
Posted on Jul 17, 2010
I cant open my yahoo messenger
Please explain what is the issue exactly. Is it "You can't login with your ID and Password" or "The Messenger is not working". If you are unable to login with your ID and Password, try login with http://webmessenger.yahoo.com
If you are unable to login with it also just reset your password and login. If you can login with web panel, check if there is any prosy set inside messenger network preferences. Remove the proxy and try again. If no proxy found. Uninstall and restart the PC and re-install the latest yahoo messenger.
That's all.
Thanks for joining us. Have a nice day.
Jan 14, 2011 | Yahoo Messenger
When i login to yahoo messenger or yahoo mail it says that i logged in from another computer or device and disconnects . I ' ve allready changed password but nothing changes. When i go to yahoo mail it...
if your yahoo messenger is unable to connect, it all depends on firewall that blocks messenger connectivity. Try this open yahoo messenger> click on messenger> click on connection preferences> select no proxies> click OK. Now try login in. Cheers,please comment on this post by telling how helpful it is
Oct 31, 2010 | Yahoo Messenger
Cannot Log into Yahhoo messenger
1. First, ensure that your computer is connected to the Internet.
2. Confirm that your password is not hacked by loging into your yahoo email account with the same user ID that your using to login to the yahoo messenger, by going to http://mail.yahoo.com.
3. If you are able to log into your email account, your ID is safe.
4. Try to kill yahoo messenger on your system using "Task Manager"
5. To open Task Manager, right click on your computer's task bar at the bottom and click on "Task Manager".
6. Next, click on the "Process" tab in Task Manager, select "YahooMessenger.exe" and click on "End Process" button.
7. If you cannot find "YahooMessenger.exe", then select "Ymsgr_tray.exe" and click on "end process".
8. Now start your yahoo messenger again and try to login. You should be able to login succesfully.
9. If your Internet connection is fine and you have followed the above-mentioned process and still cannot login to yahoo messenger, your system's fire wall is probably obstructing yahoo messenger to access internet.
10. Change the necessary settings on your firewall to leverage access to yahoo messenger.
May 15, 2010 | Yahoo Messenger
Yahoo! Messenger is unable to download files needed for install
yahoo!7 messenger is unable to download files needed for installation. Please
check firewall settings and retry installation.
I found the answer its so simple, The problem has nothing to do with firewalls.
Yahoo instant messenger (yim) needs internet explorer 7 or above version to
enable yim to operate properly with the current yim versions. If you have an
earlier version of IE (I was using IE 6 coz I always use firefox and did not
have windows update enabled coz I did not want my windows operating system to be
revealed as it was copied and theredore not legit) So I disabled windows update
and kept using firefox, but even if you never use internet explorer, yim still
needs internet explorer 7 to operate without these errors shown above. I tried
to fix it for weeks thinking it was fiewall or such, but it just needed IE 7 so
I downloaded it here:
http://www.microsoft.com/en-au/download/internet-explorer-7-details.aspx
and even tho it says its for a windows server it still worked on my windows
XP pro 64bit and now yim is working properly, allowing multiple copies of
contacts etc, no problems at all now. I also downloaded firefox version 35,
which helps yim too coz its yahoo preferred.
https://www.mozilla.org/en-US/firefox/35.0/system-requirements/
Apr 02, 2010 | Yahoo Messenger
How do I fix this problem? I get this error message when trying to login to messenger. "We can't sign you in to Yahoo! Messenger. There might be a problem with your Internet connection. Make sure your...
Hi
Please downlaod latest messanger and install in computer which can fix issue
link for latest yahoo.messanger
http://messenger.yahoo.com/download/
please rate the service if issue resolve
Thanks for using Fixya
Error 81003004.......unable to login error showing ; check network connection
May be your Network Admin/ISP blocked your messenger port....Please contact your network administrator.....if you use socks proxy please clear the proxy from network connection>Lan Setting>Unselect Use Proxy Server.......etc. or check the Connection Preferences in the messenger window and select Connect directly to the internet and save....All the best
Aug 02, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Jun 02, 2009 | Yahoo Messenger
Unable to login to yahoo messenger after downloading 9.0
download a latest copy yahoo messenger, sometime when your yahoo messenger become old it cant log you in download from here
http://messenger.yahoo.com/download/win/
install yahoo messenger then log in again
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Jan 18, 2009 | Yahoo Messenger
Sorry, Unable to process request at this time -- error 999.
visit some solus for same.... u might be knowingall these . still have a try
bye]
http://ycoderscookbook.com/tutorials/999_Error.html
Jan 02, 2009 | Yahoo Messenger
Yahoo Messenger Logo
121 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
