Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
HOW DO CLEAR A 49 ERROR - HP LaserJet M1522nf Multifunction Printer (CC372A)
  • 182 Answers
This error is usually caused by a bad formatter board.
Try this :
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
Posted on Jul 17, 2010
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
Error 49.38.07
Power off the printer for a minute. Power it on. Do you get the 49 error, does the printer READY? If it comes READY wait a few minutes. No 49 error? start printing, anything. 49 come back? clear the print queue after powering off the printer. Power back on. Do what you did above. No 49 error, it was probably a bad print job in the queue. If it comes back again, you will have to go to www.hp.com/support and answer the questions until you get to the FIRMWARE UPGRADE. Read it carefully and do it.
It's also possible there is a bad network, bad memory or bad formatter.
Jul 08, 2014 | HP Laserjet P3015X Printer
49 server error
49.xx.xy error- General firmware error ( like a blue screen in windows)
a corrupt print file is usually the cause and can be cleared by disconnecting the printer from the network, then cycle the power , allow the machine to come to ready and ask the pritner for a configuration page( just a test to see if the printer is able to respond- if not then replace formatter/firmware chip) when this has finished printing goto the workstation that sent the last files to the printer and clear ALL print queues form the PC then and only after clearing the print queues can you re-connect the network - failing to clear the print queue will cause the printer to re-try printing the corrupt document which will result in 49.xx.xy error being displayed again.
Dec 28, 2013 | HP LaserJet 5200 Printer
No display clean ram and switch on ok but not reddy 49.FF05 ERROR in valied nand key press any key
ISSUE: A 49.x service error appears on the HP Color LaserJet 4500 or 4550 printers display, and other unexpected errors may be displayed such as:
  1. Turn the printer off, and then turn it on again. If the 49 error clears, proceed to Step 9.
  2. If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card, which is located on the formatter, (see Figure 1 for location), or any third-party devices, if installed.
  3. Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
  4. Turn the printer on, using a cold reset. If the 49 error returns, turn the power off, and unplug the printer. Remove the formatter, and check that the parallel I/O board is firmly installed on the formatter board.
    NOTE: To perform a cold reset, turn the printer off, and hold down the GO button while turning the printer back on. Remember to remove the Jetdirect card (if installed) before performing a cold reset. (The Jetdirect card is located on the formatter).
Mar 28, 2013 | HP LaserJet Office Equipment & Supplies
HP LaserJet 3055 All-In-One Printer "49 error turn off"
The 49 code is related to one of three things on this unit.
1. You accidentally used a refurbished toner instead of one directly from the manufacturer which tends to cost a bit more. The certified one from the dealer is known to clear this error code instantly.
2. Your internal memory cash will need to be reset
3.You have internal hardware failure which can not be repaired by the user and must be sent to the manufacturer.
Mar 22, 2013 | HP LaserJet 3055 All-In-One Printer
How to clear error code 49.4c18 on HP laserjet 4250
any 49.xxxx codes are related to firmware crash.
the probable cause is a corrupt file in the print queue. remove the printer from the network then after network is disconnected - cycle the power on the machine ( switch off then wait 10 seconds switch back on)
the 49 error will probably clear . if so Clear All print jobs in Print queue on the computerr workstation. then reconnect printer and away you go!
if however the error remains then you will need to Upgrade the firmware or replace the firmare chip/formatter ( unlikely I've only ever replaced one out of thousands of calls for this fault)
Nov 04, 2012 | HP LaserJet 4250n Printer
Error 49
If the error can be reproduced, use the following sections of this document:
  • Product-specific documentsProduct specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html. Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate errorIf the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific errorThe error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Nov 03, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
The error "49. FF05 SERVICE ERROR" is displayed on
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
Oct 26, 2010 | HP LaserJet P3005d Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
Error message 49,ff81
it is temporary printing error, turn off the machine and wait 10 sec and turn it on again it should clear.
Oct 15, 2008 | Office Equipment & Supplies
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
792 people viewed this question
Ben Johnson
