I have a thick dark band that runs up my screen .from bottom to top .its a bit darker in colour than the other picture
  • 3,230 Answers
Well first of all tell us the Brand and the Model Number of your TV so we can help you..
Thanks
Posted on Jul 17, 2010
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
Band of darker good quality colour at top quarter of screen - below lighter colour and poor quality text
Try having your colour depth at 32 bit, right click on your desktop and goto graphics properties and select 32 bit instead of 16bit
Feb 28, 2011 | Acer Computers & Internet
Darker screen after replacing a samsung dlp lamp
DID YOU USE THE FOLLOWING LAMP
BP96-00826A (PHILIPS WRITTEN ON THE LAMP)? ALSO PLEASE CHECK THAT THE LAMP IS COMPLETELY SEATED OR IT WILL RESULT IN BRIGHTNESS ISSUES. THERE WAS ONE THAT I REPLACED THE LAMP IN AND I NOTICED THAT THE DIAL OPENING ON THE LAMP HOUSING WAS A BIT SMALL AND WOULD NOT ALLOW THE COMPLETE SEATING OF THE LAMP AND I HAD A DARK PICTURE AS A RESULT. I USED MY CORDLESS DRILL WITH THE PHILIPS HEAD STILL ATTACHED AND REAMED THE HOLE LARGER AND IT SOLVED THE PROBLEM.
HOPE THIS HELPS.
Jul 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Dark band 6 inches wide middle of the screen
YOU MAY HAVE A DEFECTIVE Y DRIVER BOARD OR A RIBBON CABLE THAT HAS COME DISCONNECTED. THIS NOT USUALLY THE PANEL SINCE THE PANEL DOES TURN ON. TAKE IT TO AN AUTHORIZED SERVICER.
Apr 10, 2009 | Televison & Video
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Dark Blurry Ink Line
When I print darker color images I get what I call Zebra stripes across the picture on a slant about 1/2 inch apart. Changed the toner and the drums are at 45% capacity. Any suggestions. Thank you.
Sep 03, 2008 | Konica Minolta magicolor 7450 Laser...
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Dark area on screen
If it's a circular area you might be delaing with magnetism. Check the menu and there should be a control for geomagnetic correction and adjust accordingly.
Feb 07, 2007 | Panasonic CT-34WXD65 34" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
