Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Riding lawnmower wont start . backfires and pops when i turn it over with key. I have changed plug, battery, air cleaner, fuel filter, drained old gas, new gas.
  • fmhatcher3 Jul 18, 2010
    I did not store the mower. I just purchased it used from another party. It started and ran a while and I drove it while purchasing. Now i got it home, unloaded and it wont start. It backfires. I changed the plug, gapped 0.030, battery, gasoline, new gas added. The guy said he changed out a push rod. When you crank it, it rotates bad. Not even spins. He said it always did that. One guy told me i got another bent valve rod, and sheared flywheel.
  • fmhatcher3 Jul 27, 2010
    I took my mower to be fixed. probably needs a complete engine overhaul. So, dont respond anymore. Wont probably be repaired till end of summer. What a racket. ONe riding mower repair shop for 350,000 people. they are horrible, rude, etc. monoply. Money down a toilet.
  • 6,826 Answers
Briggs and Stratton engines are very good in general. Did you store it over the winter and are just now trying to start it?
Troubleshooting Points from their manual:
Engine out of fuel, engine not choked properly,engine flooded, Bad Spark Plug, Dirty Air Filter, Dirty Fuel Filter, Water in Fuel, Loose or Damaged Wiring, Carburetor out of Adjustment, Engine Valves Out of Adjustment.
Did it work last year?
Posted on Jul 17, 2010
  • Duane Wong
    Duane Wong Jul 27, 2010
    could be a bent valve
  • 821 Answers
Hello,kindly check if the fuel tank has enough fuel because this can also prevents it to start.
If your lawnmower won't start, you hear a clicking sound and you've checked all the usual suspects by insuring that the battery is fully charged and will provide the starting load, the spark plug is connected and non of the safety devices like having the machine in gear or the blades engaged are causing the problem, the next place to check is the solenoid. The solenoid is usually easily accessible and is an electromagnetic switch that engages when you energize the ignition - by turning the key to the start position
If you lift the engine cowling and look to the rear of the engine you will see the solenoid. The positive (red) and negative (black) battery wires will be attached to it at heavy posts as well as some other electrical wires connected to smaller posts. First try gently tapping it with a rubber mallet. Sometimes this electromagnetically activated switch gets stuck. If that doesn't work, you can try jumping the solenoid switch. The safest way is to take your battery jumper cables and using just one of the jumper wires, connect one side to the negative post (black) on the solenoid and then touch the other side to the positive post (red) of the solenoid. Make sure your key is in the on position and the lawn mower is otherwise ready to start. Be careful that the jumper wires do not become tangled as the engine starts. Also, someone sitting in the seat to prevent any mishap is the recommended and safest procedure.
wish you good luck,
take care.
--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); riding lawnmower wont start - avw.php?zoneid=2&cb=4121765134552359&source=&n=a14de4a9&slice=-689-&dma=-0-&cty=-ng-&content_type=article&content_type_id=351067&category_id=27&key_ad=573429113&site_id=1&ad_pos=2&key_page=4121765134552359&ac_url=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f351067%2friding_lawnmower_wont_start_think_solenoid.html
Posted on Jul 18, 2010
    I will try that solution. mower has plenty of gasoline. i will try solenoid tomorrow morning, Monday.
  • Hammid Disu Jul 29, 2010
    hello,the following should be checked to put your ridind mower in it's supposed functional position,
    1.water i the gas, It goes to the bottom of the tank, and the bottom of the
    carb - where the engine picks up gas. Drain the carb and dry the
    tank if you find water in the carb
    2.you might hit something and this will make the motor not to start,it is the flywheel key
    3. it could easily be the air filter,or probably that the gas has gone bad.
    you can as well visit the site below for a comprehensive instruction and diagram on your riding mower repairs.
    www.kichline.com/chuck/fixit/mowers/default.htm
    take care.
Husqvarna 18538 engine starts smooth but starts popping like backfiring . Trying to figure it's old gas ? Just serviced the machine.
to most owners a service means change oil. plug ,and clean air filter
drain the fuel tank ..new gas
cant see the carby .. if it has one
undo fuel drain nut on side of carby bowl
popping ....check valve adjustments
if no better
you may have a burnt valve
May 31, 2016 | Husqvarna Garden
Motor quit put new gas, charged battery, checked oil still does not turn over- prior to this the engine would backfire prior to starting- I have checked connections-
Does not turn over or does not start? Does not turn over usually means a bad battery or starter. Or connections which you have already checked. There may be a fuse block or inline fuse as well. Does it have a manual pull start as well? Does this turn over the engine or is it siezed up, low/no oil.
Turns over but does not fire usually is spark or the fuel. Back firing would guess spark plug or carberator (air fuel mixture) If it turns over but does not fire, try putting in some Seafoam fuel system cleaner. This will get the varnish-gunking stuff out of the carb. Mix in your tank, turn over quite a bit to get it pulled into your carb bowl and into some of the carb port holes. Let it soak a while and then turn over again every so often to pull in new cleaner. If it starts at some point it will stink a little while burning the cleaner in the tank.
Make sure you have check the old fuel lines and and air vacuum lines for pin holes and cracks as well. Change the plugs. Make sure the air filter is clean. Change the fuel filter. Does it fire if you shoot starter fluid in the carb air intake, this would suggest a fuel issue, such as dirty carb, bad fuel line or fuel filter, or fuel pump.
Jan 09, 2016 | Ariens Lawn Tractor 42"" Riding Lawn Mower...
Have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
Jun 24, 2014 | Briggs & Stratton Briggs Stratton...
Toro ride on wont start
Battery required? Charge battery or replace. Replace air filter and spark plug. Dump out old oil and replace with 30w oil. Electric start may have a fuse blown. Dump out old gas fill with new with Stabile always added to gas. Try spraying starter spray in carb at air cleaner with filter removed. All mowers have a low oil sensor to prevent starting on low oil. Remove bowl from carb, should be full of gas. Pinch off fuel line with pliers or turn fuel valve off. Check float should be hanging down allowing fuel flow. Float up stops fuel flow.
Sep 19, 2012 | Toro Power Lawn Mower
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs,...
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Aug 12, 2017 | Garden
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2003 Suzuki Volusia 1,600 miles. Runs on choke
do you have a k and n air filter,or the like?
Apr 09, 2010 | 2003 Suzuki VL 800 Volusia
My craftsman riding mower model917.274641 won't start. I was using it and when I stopped to put a bagger on it wouldn't start. have replaced plug,gas and air filter. It backfires sometimes when turning...
First, take the air filter off and spray a shot of carb cleaner/ starting fluid in the carb. If it starts for a second and runs on the prime then its a fuel issue. Check fuel filter, fuel delivery, and carb.
Nov 23, 2009 | Craftsman Garden
New battery re-charged but still wont fire
Check for spark
If yes, it is getting FIRE, just needs AIR and FUEL
Give it a 5-second shot or two of Starting Fluid (Ether) through the Air intake (filter) and try to start
Does it kick and run really fast and then stop?
If not, pull the plug, clean and check for GAP of 2-3 matchbook covers. Retry. Does it run (or try to)?
If it does, Now we have to look at Clogged air or fuel filter or water in line(s)
Remove air filter. Try ether again. If it starts and runs, replace or clean air filter. Done!
If not... Replace AIR filter and Drain fuel into metal or Glass jug, take off fuel filter, open and drain fuel bowl. Replace fuel filter, refill tank, prime, give it a shot of ether and try again. If it runs, Done!
If it still will not stay running, but you can coax it by giving it a blast every 5-10sec, it could be linkage, stuck choke, throttle plate or jets. Give carb a good cleaning, check throttle plate (in carb throat between it and Air Cleaner) and.check Choke. Try again.
If it still will not run, take to mower mechanic.
Mar 26, 2009 | Garden
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
707 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
