Question about D-Link AirPlus DI-524 Wireless Router
Where can I get installation /configuration guide and driver for DI-524 Wireless Router?
  • 10,319 Answers
Http//192168.0.1
Hi!
The wizard (link below) will get your wireless up and running in just a few minutes.
Hope this is helpful.
-Steve
DI 524
Jan 29, 2013 | D-Link AirPlus DI-524 Wireless Router
How to i setup this router "D-link DI-524
Link to router information, you need to select your model revision, then you will be able to download your installation guide, firmware updates, etc
ttp://www.dlink.com/products/default.aspx?pid=DI-524&tab=3
Mar 04, 2011 | D-Link AirPlus DI-524 Wireless Router
DI-524 wired/wireless access point
Just for fun, make the router give out IP addresses starting at 192.168.0.101 forward. Configure the AP at 192.168.0.2 with no DHCP (the host will give out the addresses), a netmask of 255.255.255.0, and a gateway of 192.168.0.1. Now, let the laptop find DHCP, or give it a 192.168.0.x address where x is greater than 2 but less than 101.
How lucky is that?
Carl
Nov 19, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Using DI-524, can't find the wireless network
Have you properly configured the web based Wireless configurations of the router? Also check WLAN IP configuration of your laptop. Configure WLAN IP configuration to DHCP and try again.
Regards;
Hassan
Jul 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Does DI-524 spport WAP
It looks like the 524 will support WPA-PSK.
Try this:
http://support.dlink.com/faq/view.asp?prod_id=1506&question=DI-524
If your 524 doesn't look like this you amy need to update the firmware.
Good Luck
May 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless bridging
read ur user guide carefully in it it will give u ip addres with that it open in web browser then u can configured it .............
Jan 26, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect DI-524 to VISTA
There is nothing on DI-524 what is Vista specific. Make sure you installed your dirivers properly. I have the same , works without problems.
Jan 22, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524
make sure you have the wireless lan activated(software/hardware) and also configure your router's wireless setting(connecting thelaptop to the router by ethernet cable).write the wireless configuration down and configure your laptop with the same SSID and WEP key.it shud connect and you shud able to be good to goo..don'tforget to configure your DSL to therouter.post your router/modem/ISP details for further help
Feb 02, 2008 | D-Link AirPlus DI-524 Wireless Router
Router not working, help please!
You may may need to configure your D-Link to use your type of internet! Try following the Quick Install Guide which can be found here: ftp://ftp.dlink.com/Gateway/di524/Manual/DI-524_manual_06292005.zip The WLAN light doesn't come on probably because you have the wireless disabled, which can be re-enabled once in the configuration for the wireless(in the document mentioned above) If you are having any difficulty following the guide or have folloed the guid and still can't connect, please get back to me regards, babb
May 14, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
171 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
