Question about Garden
We moved into a house with a Toro Expander system and there is no manual and I need to reset the system. Where is there a manual I can download?
3 Suggested Answers
SOURCE: I need an owners manual
http://media.toro.com/documents/solution-center/diy/LMII_User_Guide_53805_53806.pdf
Posted on Jul 10, 2011
SOURCE: Just closed on house with
Hello Dear, Congratulations on your new house, the Toro ECx sprinkler system is a dynamic unit with lots of features and specific instructions to turn it on would not be sufficient to make you enjoy usage of the unit. So HERE IS A LINK to help you download a complete user manual for your unit. Take a look at it and enjoy the usage of your Toro ECx Timer Sprinkler system. Hope this solution has been helpful. Thank you for using FixYa.
Posted on Jul 13, 2011
Toro controller manual for a toro greens keeper
Go to toro's website and download it
Aug 03, 2015 | Toro Garden
I need a diagram for toro deck 30753
Hi
I have located both the owners manual and a parts manual with breakdowns of all the components of your Toro 52" Groundsmaster mowing deck.
Both can be downloaded from Toro directly at the following link;
Toro 52" side discharge mower, Groundmaster 120 Toro Direct link.
I hope this helps you and if you have any further needs, please feel free to ask.
Jul 11, 2014 | Toro Garden
Just closed on house with a Toro ECx system and there is no manual in the house and the system is off and I need instructions. Please help me.
Jul 13, 2011 | Garden
I need an owners manual for a Toro Lawn Master II sprinkler system? Is there a website that I can download the manual?
Jul 09, 2011 | Garden
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    I have a netgear wireless router with WPA security. and i bought a WRE54G . I cannot configure the expander as you know netgear IP is 192.168.0.1 and lynksys expander is 192.168.1.240. when i open...
    Try to reset WRE54G
    Resetting the Range Expander to Factory Default
    The range expander can be set to factory default by pressing the Reset button of the range expander for 20 seconds.
    NOTE: The default IP address of a range expander is 192.168.1.240.
    After resetting the range expander to factory default and you're still unable to access the web-based setup page, make sure that your computer's proxy settings are disabled. For instructions, click here. To disable the proxy settings using a Mac computer, click here.
    NOTE: If all the steps above failed, try to disable any security software on your computer before accessing the range expander's web-based setup page. Click here to learn how to disable your computer's firewall.
    If you are using a Wireless-G Range Expander (WRE54G v2 or v3) and you can't access the web-based setup page, perform the following steps:
    Checking Physical Connections
    Make sure that the computer is connected to the range expander's LAN or Ethernet Port. If the range expander is properly connected, check the LEDs on the network adapter. For instructions, follow the steps below:
    Checking LEDs on the Network Adapter
    Make sure that the LED light of the computer's network adapter is lit or blinking. After checking the LEDs on the network adapter, assign the computer a static IP address.
    NOTE: If the network adapter's LED is not lit, try using a different cable to further isolate the problem..
    Assigning the Computer a Static IP Address
    For instructions on how to assign a static IP address on your computer, click here. After assigning a static IP address, check the computer's connectivity to the range expander.
    Checking the Computer's Connectivity to the Range Expander
    For instructions on how to check the connectivity of your computer to the range expander, click here. If you're still experiencing difficulty accessing the web-based setup page, reset the range expander.
    For instructions on how to restore the range expander to factory default, click here.
    If you're still having difficulty accessing the web-based setup page, make sure that your browser's proxy settings are disabled.
    If you're using a Wireless-G Range Expander (WRE54G v1), you need to do the following:
    For instructions on how to assign a static IP address on the computers' wireless network connection, click here.
    Connecting Wirelessly to your Range Expander
    NOTE: In this example we used WUSB54GS V1.0 (Wireless-G USB Network Adapter).
    If you're using a Mac computer, click here for instructions on how to connect to a wireless network using the AirPort card.
    Step 1:
    Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen.
    4146-005.pngStep 2:
    Click Site Survey then select the SSID of your wireless range expander and click Connect.
    NOTE: The default SSID of the range expander is in this format linksysRxxxxxx.
    4146-007.pngChecking the Computer's Connectivity to the Range Expander
    NOTE: If you're using Windows 98 or Windows ME, click here.
    If you're using a Mac computer, click here.
    Windows 2000/XP
    Step 1:
    Click Start, then click Run.
    Step 2:
    When the Run window appears, in the Open field type "cmd", then click OK.
    3984-003.pngStep 3:
    When the MS DOS Prompt appears, type "ping 192.168.1.240" then press [Enter].
    Step 4:
    See if you're getting 4 replies, Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
    Nov 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Forgot password for my netgear range expander
    Reset it and reconfigure it. You need to know the configuration of your wireless router to make your range expander work again. Can you still connect to the Internet without the range expander?
    Sep 12, 2009 | NetGear RangeMax WPN824 Wireless Router...
    Range expander
    back side reset button is there pull out the power cable and put in on that time u have press the reset button on same time. eithere you go the page of linksys configuration there one opiton is there reset or the default settings.
    May 26, 2008 | Linksys Wireless-G Range Expander (WRE54G)
    Linksys Range Expander...
    Initially, it is possible that the WRE54G has not been configured to talk with WiFi AP/Router downstairs and all that is needed is to configure/set it up.
    Setup (to be done in the same room where your WiFi AP/Router is installed and preferably with your daughter's laptop which can already connect to your network when it is near):
    1. Download the LinkSys WRE54G Setup Wizard from the LinkSys site;
    2. Use a LAN cable connection to the WRE54G Ehternet port (located underneath a flip lid in front panel) to one of your daughter's laptop;
    3. Power up the LinkSys Expander;
    4. Press the Range Expander’s Auto Configuration button for about five seconds. Normally this should be sufficient for the Expander to auto-detect and auto-configure itself;
    5. Power off;
    6. Move the Expander to your intended place of installation;
    7. Again using your daughter's laptop, expand/install the downloaded LinkSys Setup Wizard. Soon as the program is running, follow the on screen instructions. Please don't forget to Save before exiting.
    8. Move your daughter's laptop to its intended location and try the system.
    Should you still need a User's Guide, it is available here.
    Another possibility that we cannot discount is that the WRE54G is also not reaching your router downstairs. Perhaps what can be done is installing it not a floor down from your daughter's but halfway between your daughter's floor and your office downstairs.
    Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
    Good luck and kind regards.
    Nov 16, 2007 | Linksys Wireless-G Range Expander (WRE54G)
    Garden Logo
    787 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
    Marvin
    Marvin
