Question about K and N Kawasaki 750 Brute Force K and n Air Filter 0507
Hi! I own a Kawa brute f 750 and i have a problem with the rear brakes! it begin to block after the engine is warm ! when the engine is cold its ok but aprox 15 min of function it begin to block!
  • 4 Answers
Try washing it
Posted on Jul 17, 2010
I have a 2011 brute force 750 when I first crank it up what will make it smoke when I give it gas but ones I ride it for a min it won't smoke anymore?
normally a slightly worn bore, or tight piston rings. They leak oil past when cold, and then tighten up and seal when the engine warms up. You can try one of those carbon cleaning liquids that you squirt in the spark plug holes when the engine is hot, leave it overnight and then start up. It frees up rings and gets rid of carbon. Makes lots of smoke when you start back up, so don't get frightened!
May 08, 2016 | ATVs
Hit the start button and nothing happens 2008 750 brute force
Check your starter solenoid. You can trace it by following the power wire from the battery to the small solenoid block that contains a 30 amp fuse. You can bridge the posts on the solenoid by using needle nose pliers or whatever else you may have. If it starts up or you hear the starter run, you have a bad starter solenoid.
Feb 02, 2016 | kawasaki 2008 Brute Force 750 NRA OUTDOORS
My 06 Kawasaki 4 wheeler. Backfires when light switch is on going down highway. Is it battery related ?
Problem with Brute Force, please save my 4-wheeler from shop ...
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Nov 16, 2011 - Problem with Brute Force, please save my 4-wheeler from shop! ....2007 kawasaki 750 4 wheeler backfire problem ... should I save for my brute force 750? moe, Kawasaki Brute Force/Prairie/Bayou, 3, 10-18-2010 06:55 PM. Backfire thru exhaust
Feb 24, 2011
Low RPM Backfire Through Carb
May 24, 2010
four wheeler keeps backfiring
May 9, 2010
06 brute force 750 poping and backfire
Feb 18, 2010
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki Motorcycles
2002 kawasaki VN 750 Vulcan hard to start when cold
Hi, Gd2bbahun I would take it back to the dealer and have them fix it properly or ask for a refund and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
very hard start when cold
2005 750 vulcan hard to start when cold
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki/kawasaki-vulcan-owners-manuals
May 21, 2017 | 2002 kawasaki VN 750 Vulcan
Kawasaki 750 brute force brake
Remove and check the settings, check the bearings and the tolerance that is needed or if there was dirt or foreign particles that had caused this to happen. Also it can be due to worn out brakes.
Jul 04, 2012 | HMF Exhaust Kawasaki Bruteforce 750 05-10
I have a 2005 brute 750. It will start and idle fine, but when you give it gas it begins to miss and backfire through the carbs and tail pipe. I just took the carbs off and cleaned the jets, new plugs and...
If it just crossed the 100hr mark the Check Belt function of the ECU will be activated. Perform the Belt Light Reset if is crossing a 100hr mark on the odo
Jan 20, 2018 | kawasaki 2005 Brute Force 750 4x4i
Problems accelerating
the engine tickover is too slow when the engine is cold its running on cold start, ie:choke,, after it warms up the engine slows down this is what is causing it to stall in gear,, get some one to hold the brakes hard on and with the engine running in gear ajust the tick over till its reving at 750 - 850 rpm the revs will go up a bit when its out of gear,, before you pick a gear to go into push the foot brake down to stop the car lurching,,,
Feb 19, 2010 | 1997 Cadillac DeVille
2006 kawasaki 750 vulcan will not idle , will idle with choke
ok buddy on the carb will be some sort of screw and idle screw turn this in 1/4 of a turn with the machine running until it idles at 1000rpm also the choke will stall the engine when warm the choke is only for cold starts get back to me more info or problems f4d68ca.jpg
Sep 24, 2009 | 1992 kawasaki VN 750 Vulcan
Hi i have a GT 750 kawa, and having trouble with the air shocks, what pressure to pump to etc..?
depends on the weight on the bike but no more than 25psi they are low pressure.
Sep 14, 2009 | 1992 kawasaki GT 750
K and N Kawasaki 750 Brute Force K and n Air Filter 0507 Logo
166 people viewed this question
Top K and N Toys Experts
Andrew Taylor
Andrew Taylor
Are you a K and N Toy Expert? Answer questions, earn points and help others
