Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Device is not turning on
I have a plantronics 220 and I know I have complete charge on it, yet I cannot even power on the device. I have searched manuels and guides and nothing seems to lead me in any pluasible direction to fixing this. I've had the device for 4 years and love it. Please help.
    Problem Solver:
  • 10 Answers
Reset it by holding down the power button until light flashes red and blue.
Posted on Jul 22, 2010
How to link my blue tooth
Pairing the Plantronics Explorer 220:
For most phones, select Settings/Tools, Connections, Bluetooth, On. See your phone's user guide for more information.
With the 220 headset powered off, turn on the headset by pressing and holding the call control button for approximately 5 seconds until the LED flashes red & blue. The Explorer 220 headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again and hold for 5-6 seconds until you see the red & blue flash.
From your phone, go to the Bluetooth menu and select "Search" or "Add Device". Your phone should find the headset which will appear as "2xxPlantronics" in your list of devices.
If prompted for the Passkey (PIN code), enter 0000. If your phone asks for a PIN/passkey, enter 0000 (4 zeros). Pairing is successful when the LED on your headset flashes blue. Your headset is now connected and ready to use.
Here is the link below for step by step instructions.
http://www.headsetsdirect.com/plantronics-explorer-220-bluetooth-pairing-instructions
Good luck from Headset Direct - 800-914-7996.
Aug 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My 220 plantronics bluetooth keeps shutting off on me during calls sometimes it will stay on for 30 sec. or so if im lucky.even when its just connected on stand by it turns off. i have a Blackberry curve...
You have an older headset and it sounds like the battery isn't holding a charge. Try pairing a different headset to your phone and see if the problem goes away. If it does, you know it's the battery. If the problem continues, then you will know the problem is with your phone and it's Bluetooth connection.
Good Luck from Headset Direct!
Apr 13, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My iPhone 4 bluetooth won't discover the plantronics 220 Bluetooth earpiece for pairing. Both devices are on including bluetooth on my phone
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My Plantronics 220 light is green indicating it has been charged. When I try to turn it on I get no light. It hasn't been used for months and I want to pair it with my iphone.
Turn off the Bluetooth on your iPhone. When charging the Plantronics 220, hold down its on/off button until it starts to blink two different colors. Then turn the Bluetooth to on once again on your phone. Once it detects the device, press pair. The pin is '0000'. A little late but hope it helps.
Dec 11, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My lg cu920 can't read my plantronic 220 what can i
Do you mean it "can" or can't connect to your CU920?
If your CU920 is already paired to a computer or other device this first pairing must be stopped before the steps below will work.
On the Bluetooth headset: 1. Turn your headset ON. 2. Hold down the headset power button until the power indicator light blinks an alternating red & blue.
Then using your CU920.... 3. Turn Bluetooth ON, 4. Search "New Device," 5. Under "devices found" select your headset. 6. Select "Add." The CU920 will ask for a passcode. 7. Enter "0000" (four zeros) the default for the Explorer 220.
The Plantronics earpiece should automatically "pair" with your CU920.
Oct 11, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Syncing a Plantronics 220 to a Nokia 6030
This phone is simple phone and its not compact able with blue tooth device .............................
May 28, 2008 | Nokia 6030 Cellular Phone
Plantronics 220 blue tooth
Another bang bang solution...
Be sure to charge your headset for atleast 15-25 minutes minimum to get a starting charge. This will also give you 15-30 minutes of talk time to test out your headset and placement, and also get used to being a part of the bluetooth generation.
Once charged, press the call button(the big button on the side) and hold it down until you see a flashing red/blue combination of lights, now you only have 2 minutes to set this up, or you have to start over.
Once the lights are flashing on the headset, it is searching for a phone, now you go to your phone, and find your options for connectivity or bluetooth, once in your menu, look for the option to search or connect to a blue tooth device. Let it search/connect automatically.
Once it is connected, the flashing lights on your headset should stop, finish the connect process on your phone, if it says found it, install it, entering device data, etc etc, follow everything it says by entering YES, hitting OK, or CONTINUE.
Once it says CODE or PASSWORD to enter for your bluetooth device, enter 0000 .Which is ZERO ZERO ZERO ZERO and then press enter.
It should take 2-10 seconds for the password to initiate, record into your phone, and pair your device. This is a detailed explanation. Please rate me for my effort.
ManOwar
Dec 31, 2007 | Plantronics - Bluetooth Headset Plus Base...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
278 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
