Model kx-tga226f
How do you access voice mail when you have forgotten the code? What do you even have to do just to get to vice mail. It is not a primary phone that we use but I want to clear the voice mail. Can I get a free owner's manual?
SOURCE: voice mail greeting
Sign in to mailbox 999 and 998 and poke around. You should find some greetings in there. Else, if you have the installer software you can go in from that and make the changes.
SOURCE: I don't remember how to access my kx-tga931t voice messages remot
There should be a 2 or 3 digit number that you can recall on the main base. Once you have that number you call your number and as the answering machine starts press # then enter the number. Hope this helps.
SOURCE: Changing the voice mail access number.
press menu
arrow down to "Initial setting"
press select
"voice mail" will sow on the screen
press select
"store VM access#" will sow on the screen
press select
edit the number and press save
SOURCE: I have inherited a KX-T7633 and cannot access
It depends on what you mean by "can't access". The Panasonic voice mail system is accessed by dialing the VM access code, sometimes 500 or 165, from the phone you want to use. If you, for example, are extension 105, and it has a voice mail box, the lady will either tell you how many messages you have, or ask for a password. If that's how you can't access VM because you don't have a password, then the password can be reset from mailbox 999, the system administrator's mailbox.
There are two passwords YOU ABSOLUTELY HAVE TO HAVE. If you don't know the passwords to 998 and 999, then you will have to get them from the original installer, or call your Panasonic dealer. Alternatively, if you have the VM maintenance console password, you can reset 998 and 999's password.
Carl
SOURCE: New Voice Mail message
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
