Question about Gateway GT4024 PC Desktop
My computer is having connectivity issues. At times I get online ok,but often I get a notice "acquiring network address" or "limited or no connectivity". I know the computer & modem are not communicating. I have reconfigured the modem, changed the ethernet cable, and updated the network adapters.I even downloaded PCPitstop to optimize my system, yet the problem continues.Any ideas?
  • mmrin511 Jul 18, 2010
    Firewall is "on".
  • mmrin511 Jul 20, 2010
    Could not connect with firewall off.
  • 62 Answers
Check your firewall settings. They may be blocking access.
Posted on Jul 17, 2010
  • David Moses
    David Moses Jul 18, 2010
    You're firewall being on could be blocking your internet connection. You would need to set the firewall to allow the connection. Try turning off your firewall temporarily and check to see if you can connect. If you can, your firewall will need to be set to allow it. Or just change the firewall settings and leave it on.
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
Dell inspiron e1405 cant acquire a network address?
Call Dell customer support phone number 1-800-204-4427 to get online help for technical problems related to Dell computer, laptop, printer, scanner and tablet Dell Laptop Support Phone Number 1 800 204 4427 Tech Help
May 17, 2017 | Dell Inspiron E1405 Notebook
Just install XP PRO sp3 on P4C800 board and current version of 3Com 3C940 onboard LAN. Installation went fine but LAN can not acquired network address and get no or limited connection.Therefore internet...
When your using Internet connection via LAN you need to configure the Internet Protocol (TCP/IP) Properties at the Network Connection Wizard. To configure the Network Connection just follow this steps:
1. Double click the My Computer from your desktop/screen.
2. At the left side of the My Computer menu click the My Network Places then click View Network Connections in the left side of that window also.
3. Double click the Local Area Connection and click Properties.
4. When the Local Area Connection Properties was appear select Internet Protocol (TCP/IP) then click Properties.
5. The Internet Protocol (TCP/IP) Properties are also apear, then click Use the following IP address and fill-up the following: IP Address, Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server.
6. After all you fill-up click OK Button.
Note: Make sure that the IP Address you fill-up in your network connection are not the same with the other computer to avoid conflict. Just copy the configuration on the computer like: Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server. Only the IP Address are unique to the other computer. Example; 192.168.0.5 that is the IP Address of last computer are connected in the network. The IP Address you able to use is 192.168.0.6, only the last digit of the IP Address your going to change.
Jun 04, 2010 | ASUS P4C800 Deluxe Motherboard
My Intel(R) PRO/Wireless 3945BG Network Connection , has a limited connectivity to the internet
Sometime when you switch on the computer and the wireless router (if you turn it off after using it) the computer does not get an IP address from the router in time when the computer finishes booting up. This problem may not occur all the time.
When you get the limited connectivity error, then right click on the wireless connection icon on the Task Bar and click REPAIR. This will get the wireless router to issue the wireless card an IP address.
Then you will have proper Internet connection.
Mar 09, 2010 | Intel PRO/Wireless 3945ABG Network...
I'm online, but i have "limited or no connectivity." It says that the network didn't assign a network address to the computer.. help! This the first time i've tried to connect...just got this thing today.
first you need to make sure that your modem or router is working good.. if no network address, check your wirless netwrpk settings and right click and go to properties, click wireless network in between general and advanced, make sure that "} use windows to configued my wireless network settings was check and then open your own wireless network prorties and type in your wpa or wep correctly..then click ok.. if still acquiring network address. check your network connectionif you are running bridge connection.. disable it and run ony wireless network connection or wlan.. if still the same , check tcp ip settings, and make sure that the settings was on automatic if you are using wireless modem, if using router, make sure that the ip address of your router and subneet mask and dns server address was type iin correctly.. if still not accepted ,, install another worireless adapter iin your pc...
Jan 04, 2010 | Acer Aspire One PC Notebook
Cannot acquire network address but sees router
You can first disconnect ur network name form router and then give a static ip in the range of the router on the wireless n/w connection of ur computer and then try to reconnect. Computer will automatically pick up the address and get u online, if problem still persists then reboot the comp once.
thanx and regards
sukhiii
Jul 24, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Acquiring network address/limited or no connectivity
network not set right check firewall disable it and try
Mar 29, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Set a Static IP Address on your computer to resolve the issue.
Mar 08, 2009 | NetGear WGR614 Wireless Router
if you are using the dell wireless utility to manage your card, then disable it, and manage your wireless adapter through the windows network connections. that way the wpa issue will be solved by windows xp wpa. i had a similar problem with my inspiron 1525 (dell wireless 1395)
Jun 09, 2008 | Computers & Internet
Cannot acquire network address from access point
then it seems thatb the wireless security key for your network is incorrect, make sure if you are entering the key correctly..
or else..
check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Dec 02, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Gateway GT4024 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
