Question about Nokia 5310 Cellular Phone
How to delete miro sd sandisk memory card password i have set it on phone and i forget it,it works fine in my nokia 5310 and it is accesible on pc through USB cable but the problem comes only when i insert the memory card in any other phone it ask for password.please suggest me something
  • 524 Answers
Hi....
please try this
1.Download the FE explorer from this site http://gallery.mobile9.com/f/1210278/
and install it to your mobile phone.
2.. open up FE explorer.
3.. Go to C:\system\ folder and locate a file called mmcStore. Scroll down till you find it.
4.. Copy it to C:\nokia\others
5. mark it
6. click options
7. FILE>RENAME
8. change the name to "MMCSTORE.txt"
9. try to open it, (that should be your password, if nothing happens then go to 10.)
10. connect phone to pc
11. Open the file from C:\NOKIA\OTHERS\MMCSTORE
12. copy the file to your desktop
13. open with Windows notepad/ microsoft word
14. that should be your password
thanx
Posted on Jul 17, 2010
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have forgotten the memory card password in my nokia 5310 .My nokia' s imei no. is 354171020960101.How can i delete or change or recover that password. application x plore is not working in my phone
Insert the MicroSD card into an available media reader slot on your PC. If your media reader can't read MicroSD cards, but can read ordinary SD cards, first insert the MicroSD card into an SD adapter, and then insert the adapter into the slot. You will see an autoplay menu for the disk pop up on the screen.2 Open the folders on the disk and navigate to the "System" folder. Click on the "Open folders to view files" option from the autoplay menu, then double-click on the folder that says "System." This is where your card's password file is stored.3 Open the password file. In the "System" folder, find the file that has MMCSTORE somewhere in its name. It may have additional letters, numbers and characters, but it will always have MMCSTORE in the title. Double-click on this file to open it in Notepad. The text inside this file is your lost Micro SD password.
  • Oct 13, 2011 | Nokia 5310 Cellular Phone
    Hi i have my memory card password forget
    you can unlock your 2gb sd card..
    1. Insert the sd card into a software phone. (eg. Nokia 6120c, 5800, 5233 etc..)
    2. Select settings > data mgr > memory > options > format memory card..
    Note- formating memory card will delete all datas in your sd card
    Sep 24, 2011 | SanDisk 2GB microSD Memory Card
    I forgot my memory card password .. plz help ??? thnx
    you can use the Nokia 5310 for many different storage and entertainment functions. The mobile phone has the ability to save all of your large files (such as pictures) to a memory card instead of using up all of the built-in device storage. You may run into issues with the memory card if it is locked. This can happen if you buy a used card or if you forget the password that you programmed into the card at the time of purchase. You can unlock the card with a default password, or you can delete the option that requires the memory card from requiring a password at all.
    Instructions
            Unlock the Memory Card
      1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.
      2. Click the "Menu" key down from the main screen of the 5310. Select the menu option for "Extras."
      3. Navigate the cursor down to the bottom of the page. Press down on the option for "Memory Card."
      4. Click the "Options" selection that appears as a screen prompt. Move through the options until you reach the "Unlock Memory Card" option. Click the cursor to select the "OK" option.
      5. Manually enter in the unlock password with the 5310 keyboard in the password box. When you cannot remember the password, the generic passcode is "12345" or "1357."
            Delete the Memory Card Password
      1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.Click the "Menu" button down from the main screen of the 5310. Select the menu option for "Fun & Apps."
      2. Scroll down to the selection for "Gallery" and then press on the "OK" key. Navigate to the "Memory Card" screen selection and then press on "Options." Move through the list until you reach "Memory Card."
      3. Press down on the option for "Delete Password" when the screen pop-up menu loads. Verify that the words "Memory card will unlock now, do you wish to proceed?" appears. Select the option for "Yes" to verify the unlocking.
      4. Navigate to the password box and manually type in the default passcode. When you cannot remember the password, the generic passcode is "12345" or "1357." Select the "OK" key when you are complete to remove any passcode requirements from the 5310.
    Dec 08, 2010 | Nokia 5310 Cellular Phone
    Nokia 5310 micro SD memory card
    If you dont remember the password that you gave it, will be undone only by formatting the memory card and thus loosing all data on it.
    Aug 31, 2009 | Nokia 5310 Cellular Phone
    NOkia 5310 SD Memory Card Problem
    i have forgotten the password to my SD memory card. FExplorer.sis is not supported in NOKIA 5310. Can any one help for this... plzzz...
    Dec 06, 2008 | Nokia 5310 Cellular Phone
    I forgot d password of my nokia 5310 memory card
    hi
    Default code for Nokias is 12345. This will work if you did not change access code.
    If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
    After installing file manager
    check the folder C:Systemmmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
    Here is also a reset procedure that works on some Nokia, I do not know if it is good for 5310.
    Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
    Take the SIM card out.
    Make sure your phone battery is fully charged.
    Press * 3 send at the same time and turn the phone on.
    Keep this two buttons pressed until the reset screen appears.
    Wait some time to reset.
    Switch phone back on.
    By Mr.GINKO plz do rate this post
    Oct 20, 2008 | Cell Phones
    Help
    Insert the memory card in the nokia phone and change the settings to the memory card without password and then insert the memory card in your motorola phone.. it will fix the issue...
    Otherwise, connect your nokia phone with your computer and transfer all the contents from the memory card to pc and insert it into motorolla, format the card and copy it from your pc... make sure your having pc suite for doing this...
    Sep 10, 2008 | SanDisk 2GB microSD Memory Card
    Nokia 5310 Cellular Phone Logo
    77 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
