Question about JBL MR140
Hello. I have a JBL Marine MR-140 that does not work half the time. It is receiving power and will work fine one day and the next will not work at all. The wiring seems secure and it has not been exposed to much rain/water. This problem has been here since day one. Thanks for any help. John
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 04, 2008
  • 131 Answers
SOURCE: won't read the CD's now
have you ever cleaned the lazer lens? goto any CD store and pick up a CD cleaner CD, it is a CD that you place a drop of cleaner on the brushes on the bottom of place it in the CD player and let it play, it will clean the lens that reads the cd, you might have to run it a few times if you have never done this before. that should fix the problem. the CD cleaners are not that expansive, can find them under $20...... hope this helps you..........
Posted on Jun 01, 2009
  • 9 Answers
SOURCE: I can't find whether or not The JBL MR-17 will
It Does Not. Only standard CDs the manual is here:.http://www.prospecelectronics.com/JBL%20MR17%20manual.pdf
Posted on Jun 28, 2009
JBL MR-17.2 not recognizing Sirius satellite receiver.
I have the exact same issue. I have swapped with two identical MR17.2 radios and swapped out the sirius receiver. No change. I even bought a remote thinking I had to have a remote installed to get it to work...still no diff. Have you ever found a solution?
Jul 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Volume dial decreases volume if turned either way
i took my head unit face apart and got the volume control off, sprayed a little WD40 and it worked like a beauty!
Jun 03, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Won't read the CD's now
Jun 01, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Problem with compact dic player
contact your installer of the spa they will determine what needs to be done as I dont have enough info to assit you
Mar 26, 2006 | JBL MR-4 AM / FM / CD 180 Watts Marine...
JBL MR140 Logo
147 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
