Question about Asrock AM2NF6G-VSTA Motherboard
On start up bios says boot error. no power up of monitor or key board
  • 182 Answers
If monitor does not power up where do you get boot error
Posted on Jul 17, 2010
Is my computer in standby mode?
Make sure you have the cable that plugs into the back of the computer from the monitor screwed in tight. Also make sure the cable on the back of the monitor is screwed in tight and also that the power cord on the back of the monitor is pushed in all the way.
I'm almost certain you're not in standby mode. Does the computer stay on when you get the no signal message? Do you hear the fan blowing, do you hear the disk drive spinning? If not, I think your system has completely shut down. I'm thinking maybe a virus or some hardware/software conflict is stopping it from completing the boot cycle.
Try getting into the Bios or System Setup to see if the LCD Stays on and the computer stays on. Turn the computer off, then hit the power button to turn it back on. Look at the lcd screen and it will tell you what key to hit to go into the Bios or System Setup. Go into it and let the computer sit for 10 minutes or so to see if it shuts itself off.
If you are successful with the computer staying in the Bios or System Setup lets try getting into Safe Mode and see what happens. Turn the computer off and hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see the SAFE MODE option. Select the Safe Mode option and let the system boot up. Safe mode will look different to you. The icons will be bigger and the lcd screen darker, but that's normal. If you are able to see the desktop in safe mode just try opening up MS Word and maybe let it sit for a few minutes to see if it shuts off.
If safe mode was successful, then try booting it normally. If it fails, we know we've got an issue.
Mar 23, 2012 | Acer Aspire X3400 PC Desktop
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
HP G61 NOTEBOOK PC BIOS BLINK ERROR CODE 2 BLACK SCREEN LED LIGHTS ABOVE NUM LOCK KEY AND LED LIGHTS TO LEFT OF CAPS LOCK KEY FLASH 2 BLINKS.NO MONITOR WHEN HOOKED UP TO AN EXTERNAL MONITOR.CD DISC DRIVE...
It would seem that your BIOS has become corrupted somehow. First try entering your BIOS setup. I believe for HP computers when you press power tap the F10 key until it opens. There you can try to reset them in some fashion and save. Try rebooting. If that fails then remove the battery and repeatedly press the power button for about 10 seconds.. (make sure it is also unplugged, this is to discharge the power from the system) then replace the battery and try booting again. Otherwise it would seem that you might have tried to load the wrong BIOS into your laptop. Check with HP then if you are still covered or not. :/
Mar 24, 2011 | Computers & Internet
My hp womt start up the quixk start lighta cpme on then notging
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance.
Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset, some devices are often overlooked.
Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.
If the computer can access part of the memory, it may be possible to access the BIOS Setup Utility display and perform a memory self test to identify other memory issues. If the computer cannot boot to the BIOS Utility, try removing and reseating the memory and the hard drive, and then repeat the following steps to perform the memory self test.
  1. Plug the AC adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. In the BIOS Setup Utility, use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Diagnostics .
  5. Use the Up Arrow or Down Arrow keys to select Memory Test .
  6. Press Enter , and then Yes to perform memory test.
  7. After test completes, press f10 to Save and Exit , and then press Enter to Exit Saving Changes? .
Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. Use the steps below to test the hard drive in a computer using the HP Hard Drive Self Test.
Plug the AC Adapter into the computer.
Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup Menu.
Use the Left Arrow or Right Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer.
Turn off the computer and wait 5 seconds. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  • Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
  • NOTE: The exact wording of the option for your particular BIOS may be slightly different.
    1. If Windows does not start properly, reset the BIOS to the default settings. Using the default settings, you should be able to boot into Safe Mode and install the latest BIOS. To reset the BIOS, press the power button to start the computer and repeatedly press the f10 to enter the BIOS setup, then press f9 key to Reset BIOS Default . For more information, refer to the HP Notebook PCs - Configuring the Boot Order in the System BIOS support document.
    2. If it will not boot to the BIOS, you may need to remove and re-seat the hard drive. Instructions may vary depending on the notebook model you are using. For specific instructions on re-seating the hard drive in the notebook, refer to the HP Notebook PCs - Steps for Removing and Replacing the Hard Drive support document.
    3. After re-seating the hard drive,perform a hard drive reset.
    Nov 16, 2010 | HP Pavilion dv6000z Notebook
    Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
    I still did not find beep code that match your problem..
    Anyways here are the common beep codes for your motherboard.. it might help you too.
    1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
    2. 1beep - board is working fine.
    3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
    4. 1short beep - system boots normally
    5. 2short beeps - CMOS setting error.
    6. 1long 1short beep - dram error
    7. 1long 2 short beep - video card or monitor not connected
    8. 1long 3 short beep - keyboard error.
    9. 1long 9short beep - ROM error
    10. Long beep - memory card is missing or not connected
    11. Short beep - power supply error
    12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
    Hope this gave you an idea of your problem..
    Much appreciated if you rate this help..thanks..
    May 23, 2010 | Abit AV8-3rd Eye Motherboard
    Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
    Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
    Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
    Blank screen on start up on Acer Extensa 4620
    Did you switch displays to the external video? Try hitting the Fn key and whichever function key at the top of the keyboard has a little TV screen icon over it at the same time.
    Jan 04, 2009 | Acer Extensa 4620 Notebook
    Hardware malfunction - The system has halted
    to get into the bios, you either need to press F1, delete or F2 as the computer boots. Look very carefully at the screen when it boots because it will only tell you briefly what key you need to press on your keyboard. Once you have got into bios use your cursor keys to get to the correct page where it will tell you the boot options. Then change the boot options to your preference and save the changes and exit.
    You are right about the monitor though, it will not come on if your computer doesn't boot correctly.
    Oct 29, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
    Motherboard installation
    Hello mecompe,
    If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
    There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
    First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
    section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
    [AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
    Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
    If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
    Need the Asus manual? Click this link;
    http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
    To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
    http://www.adobe.com/products/reader/
    (The green led (light), means standby. The board is receiving 5volts DC.
    If you still do not have display just let me know.
    Good luck mecompe!
    Mike
    Oct 28, 2008 | ASUS P4SGX-MX Motherboard
    Asrock AM2NF6G-VSTA Motherboard Logo
    89 people viewed this question
    Top Asrock Computers & Internet Experts
    David
    David
    Computer Links
    Iqbal Husain
    Iqbal Husain
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
