Question about Dell Optiplex GX280 (99301) Motherboard
Cpu fan runs fast and no video output - Dell Optiplex GX280 (99301) Motherboard
  • Shaun Harris
    Shaun Harris Jul 17, 2010
    What is the brand, model and serial or product number?
    Sergeant:
  • 298 Answers
Check your video card
Posted on Jul 17, 2010
5 Suggested Answers
lolita
  • 385 Answers
SOURCE: AsRock Motherboard
First of all, not all the time memory is bad it gives a beep. So you might still want to verify that it's not the memory. Try the memory in another cpu or try another memory in your cpu.
If you have verified that the memory is not the issue, then your next culprit is the video card. Make sure the video card is working. Take it out and clean the contacts with a clean piece of cloth and then reseat it properly.
Please let me know when you have verified the above recommendation and if it works or not.
Thanks and good luck
Lolita
Posted on Dec 14, 2007
  • 238 Answers
SOURCE: no video output,
hi, did u check the ram, try cleaning the contacts, or replacing it,
and as u say the fan is working that means the smps is switching on, so it could be ur motherboard, remove any addon cards and then check..enjoy
Posted on Dec 15, 2007
  • 166 Answers
SOURCE: PC wont boot cpu fan runs extreemly loud and fast.
You may have a failed motherboard or bad/weak poswer supply unit (PSU) then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. The DELL GX270 and GX 280 were the main DELL models affected by this situation. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Make sure you look under the fan shroud. Most of the bad ones had either a plus + or X on the top - depending on your interpretation. There are a few companies that will repair broken capacitor issues. If it has recently gone out of warranty you could try to contact DELL to see if they will ship you another one. I was able to get them to fix a couple of mobos out of warranty, but that was two years ago. To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard or power supply issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. And remember a bad PSU does not mean no power, just not enough to run the computer. If you change out the PSU, the one that you replace has to have the same or greater output watts?
Posted on Apr 30, 2009
  • 111 Answers
SOURCE: after installation no video output
This isn't a RAM issue if you're getting a clean POST. Make sure that in the BIOS you have onboard video disabled.
Posted on May 26, 2009
No video output. fan speed fast
sounds like a faulty GPU . your graphic chip or card could be burned out which explains the no display and high speed fan.it can also be it cant boot to BIOS.
Nov 11, 2013 | Intel Corporation Network Servers...
Gateway pa6 fan problems
old post.
odd symptoms.
the OP never once told the full story
what works good and not.
XP runs? surely it can, 0.4% 2016 run XP world wide and way less now 2018, due to virus magnet status.
do not run XP , and the fan is not XP job.
BIOS runs the fans.
if the PC runs at 56C or so and the fans slow that is normal
The bios only speeds up facts at start,
the slows them and monitors CPU heat and GPU heat
if they rise too high the fans spin up.
this is how all PC run
my fancy desktop has 600rpm fans right now, due to cool running CPU. 4 pin fans can do that magic.
The reason for the fast spin up is easy to learn turned on fresh.
the PC ASSUMES the chip are hot.
say PC parked in a trunk at 120F
the you go indoors and turn it on
so to be safe, it runs them fast (like at BIOS machine code instruction 1 or first. it spins them up then watches CPU temps live. this can take a few seconds to do a scan, see a TREND
if the trend show low, temps, it then uses a PWM fan table in the BIOS, and set the fan speed off that hard coded table)
get that?
now say PC was hot turned on then it slows only if fast fans speeds can lower the CPU temp
then rule 2 and 3 on BIOS CPU temps
if bios does not like say 80C it can turn itself off.
if failing to do that, say fan is dead, learn that ALL CPUs from P4 up
can turn them selves off they HALT.
ALL AMD and intel CPU do that.
ok?
and did you really clean it
is the RAD clean.?
http://www.pcdied.com/overheated.html
Jan 13, 2018 | Gateway Computers & Internet
I have change my old CPU intel Celeron D 3.06Ghz to intel dual 2 core but my pc no display my pc is power on my monitor is power on also. The CPU fan is running slower then old CPU . My motherboard
is the monitor running through a vga connection? sounds to me like the mobo is bypassing the connection your using and sending your video signal elswhere. did you change any settings in the bios? try other video outputs to get the screen on then go into bios settings and change the video output to a connection your familiar with. help is here if you need it :)
Nov 20, 2012 | Computers & Internet
My computer dell gx 620 desktop fan is running fast and it keeps on restarting and hanging especiall during heavy games and also videos and the fan is running fast
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Aug 30, 2011 | Dell OptiPlex GX620 PC Desktop
Shuttle SG41 - J1 - New build, no video output, power light on, fan running. Removed & tested CPU (intel Pentium D 2.8G), it's OK. RAM OK.
Hi, I have exactly the same problem and done the same checks as you. Did you manage to resolve it and if so can you please tell me ho?
Thank you
Jul 18, 2011 | Shuttle SG41J1 Plus SG41-J1-BK-VP-H...
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
My computer is beeping every so often it beeps about 3 times and it does it fast please tell me why
It only mens that there's an error on your computer.
Beep codes are use to check or identify which computer part/s causing the problem.
Beeps
Error Message
Description
1long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1long, 3short No video card or bad video RAM Reseat or replace the video card. High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow. Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
May 11, 2011 | Toshiba Computers & Internet
I have a hp slimline 3100. the cpu fan runs fast everytime i open a program or play a cd. it speeds up the slows down. sometimes it runs really fast, then the computer shuts down. whats going on?
This is an indication of overheating within the PC. Open the PC case and clean all the air vents. Take the heatsink and fan off the CPU and give it them a good clean. Put the heatsink and fan back on to the CPU and start up the PC. check that the fan on the heatsink is running smoothly.
Also, make sure the vents on the power supply are clear and the fan on the power supply runs well.
If you go into the BIOS setup, you may be able to monitor the fan and the CPU temperature.
Mar 18, 2011 | Computers & Internet
GA-7N400 Pro2 at startup i hawe long separate continus beeps
Possibly Ram, try and see if removing and replacing helps
Other causes may be voltage issues ( check the bios and see what the various rails are telling you)
eg: there should be readings for 12 volts 5 volts and 3 volts, if any are + or - by 10%, there is an issue with the voltge controller. You might want to try a replacement PSU?
After this.. bad video ( check by installing a video card)
Temperature warnings ( check in bios to see under PC health status) what the cpu and board temps are running at, if above 70 degrees...overheating issue or more likely at start up, board thinks that the CPU fan is not running fast enough or not working. If fan IS working, you have a problem with the CPU fan sensor, will need to replace mobo
Jan 27, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
I have a HP M1270N Media Center PC. The CPU Fan
The CPU fan is designed to run constantly to prevent the CPU from overheating. The speed depends on temperature condition of the room; slow in cold and fast in a hot room. However if you suspect that it runs too fast them try re-seating the CPU. WARNING: Re-seating should only be done if you are know how to do; don't experiment.
If it is running noisy, you can apply one or two drops of machine oil to the fan's spindle.
Other reasons include deposits of dust; use a blower to remove dust from the heat-sink.
To make sure you CPU is not in a critical state, log in the BIOS and in the hardware monitoring tab check the CPU temperature. It should be near 60 deg Celsius or 140 Fahrenheit.
One thing more, do not apply thermal grease in excess; its a conductive compound and can short the motherboard if it melts and deposits on the motherboard due to high CPU temperature.
May 25, 2010 | HP Media Center m1270n (PP132AA#ABA) PC...
Computers & Internet Logo
475 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
