Question about Keurig Elite B40 Coffee Maker
The orange, round sponge fell off
The orange, round sponge that goes around the needle dispenser fell off. Has this happen to anyone else?
Guage needle fell off joe blow pro pump
Had the same thing happen. It turns out you can pry off the plastic ring around the dial, then remove the clear plastic window. I did that and just stuck the needle back on at 0.
Oct 13, 2013 | Topeak Joe Blow Ace Floor Pump
Red light stays on and never goes back to green....
This is a common problem with this model. There is a microphone in the rear duct that is not firmly seated. Usually this can be cured by removing the duct at the rear of the vacuum, that the hose attaches to, and using a small screwdriver to push around the outer edges of the small round microphone button. It may not look as if anything is happening, but this will usually cure the problem. I like to put a small piece of sponge or rubber against the mike to hold it more firmly in place prior to re-assembly.
Mar 11, 2011 | Hoover U6455-900 WindTunnel Vacuum
Free Refer Hotpoint csx27dma. Owner had two new parts for the compressor. a start switch and an overload switch. The compressor has 3 round connection prongs for these parts to fit on to. Installed...
From cabinet you have three wires. 2 Orange,and 1, Black
1 Orange goes to on side of run capacitor the other Orange goes to the (2) R on the relay. The Black goes to the overload (round black disk). 1 White wire connector on end goes to run capacitor the other end connects to the (1) S on the relay.
The run capacitor is a small black cube like device with two prongs.
Oct 26, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
In 1st gear its nervous and in second it stalls....this happens when i go around a round about in 1st gear...
Sounds like a needle jet is stuck rich. Pull air filter and look in the carb then turn throttle to see if the jet needle goes up and down
Oct 11, 2009 | 2006 Yamaha XT 660 X
Tiny piece in ice in door fell out wont release ice to fall how do i put back
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Oct 10, 2009 | Whirlpool Refrigerators
Bad frost keeping building up around ice dispenser
This is usually caused because the door is not shutting all the way or not tight allowing air in.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
Sep 21, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water dispenser Paddle
The part the hinge fits into may be broken or the hinge it's self.
Aug 14, 2009 | Refrigerators
Hp 6500 office jet refill
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
www.catherinecollege.net
Jul 21, 2009 | HP Officejet 6500 Wireless All-in-One...
Keurig maker dispenses too little water when brewing
I found this solution on another post. Unfold a small metal paper clip and insert through the lower piercing needle of the cup holder to **** out any debris in the needle.Even a small piece of coffee or debris can slow the water flow through the cup.
Mar 22, 2009 | Keurig Platinum B70 Coffee Maker
My needle broke and a piece of metal fell out of machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Keurig Elite B40 Coffee Maker Logo
719 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
