Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
THE KNOTTER KEEPS BREAKING THE STRING. TRIED ADJUSTING. BALED 10O BALES YESTERDAY THEN STRING STARTED BREAKING ADJUSTED AGAIN. BALED 10 MORE STARTED BREAKING AGAIN THIS WENT ON FOR ABOUT 2 HOURS. IF ANYONE CAN GIVE US ANY HELP ON TROUBLESHOOTING THIS DARN 348 JOHN DEERE HAY BALER. RAIN COMING IN AND KNOTTER DOESN'T WORK
    President:
  • 2,468 Answers
How much tension is on the tensioner,back it off a bit and try it,also have you tried a different type or bail of twine depending how old the bail is your using and its not rotted
Posted on Jul 17, 2010
  • 6,826 Answers
Http://www.deere.com/en_US/ag/servicesupport/tips/hayforage/ottumwa-irregular-bale-length.html#
The above addresses irregular bale length. The knotter breaks the string.
http://www.deere.com/en_AU/equipment/ag/hay_forage/square_balers/gear.html
The above discusses using a gear driven knotter.
http://www.ytmag.com/implment/messages/145993.html
The above discusses troubleshooting the knotter in Yesterday's tractor forum.
I think there are literally hundreds of resouces if you search under
the following search terms:
'348 JOHN DEERE HAY BALER troubleshooting knotter'
I can't go through all of them, now, but I'm sure it will lead to a solution for you.
Good luck, to you, in baling hay.
What oil pressure is needed in the rams on the back door which set bale pressure on a krone 1250 round pack
tough question that
http://www.mascus.co.uk/specs/round-balers_985594/krone/round-pack-1250_1024021
Krone Round Pack 1250 Baler, multicut 17 knives, , rotor feed, 15.0/55-17 tyres, bale kicker, 2.0m pick up, wide angle pto c/w cam clutch.
Jul 04, 2016 | Cars & Trucks
Bale tying
then you need to work on the knotter mechanism or replace it .
Oct 16, 2015 | Garden
Twine running over end of bale
The twine arm has to be adjusted If this can't be done maybe the twine arm is bent and needs to be re-shaped so it does not go off the end. But first check the adjustment. It should be in your operators manual
May 20, 2015 | Garden
Welger ap 53 baler
My guess is that there is some kind of bind that the twine is in between the spool of twine and the knotter... resulting in the twine being continuously too tight for proper tying. Check for restrictions and then make double sure you've cleaned out ALL of the bunched up twine and twine ends... Are you using the correct twine??
Oct 30, 2013 | Garden
I have a problem with the band breaking on my Markant 50. Just on one side. I am left with a short length on the knotter and a length still attached to the last good bale. Can you help please
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 23, 2012 | Cars & Trucks
String tensioner and knotter on new holland baler 319
I would say first check the twine tensioners where the twine comes out of the box it's held in. They are simple spring loaded slip tensioners, make sure both have the same tension. From there check all the twine passages for rust or servos
Jul 09, 2012 | Garden
The only information written on my hay baler is Mobilco Super 59. I have been trying to bale my hay but the knots on the left side aren't tying. I adjusted this and it tied a few then the knotter on...
The mobilco sounds like a gar lubricant. I bale myself and work on my own machinery. The first thing you need is the make, model and serial numbers. There shuold be a tag somewhere fastened to the machine. Both of mine have the tag riveted to the flywheel side of the frame.Mine are old john deere balers. Balers can be very complicated machines and you need the manual to dial them in right unless you know that machine like the back of your hand. Sometimes you can have tying problems from bad twine that might have been damp or knotters rusty and not moving right. Some times penetrating oil on the moving parts of a knotter will do wonders. I am assuming that you are talking about an old square baler since I dont know what you have for sure. I started having problems with mine when the twine started wearing a pretty deep groove in one of the parts it dragged across (dont remember which part it was) but anyway, I replaced and reshimmed accordingly, and it ties really good now. Hope I could be of some help.
Sep 02, 2011 | Garden
The shear pins on the rake keep breaking on a 853 NEW HOLLAND ROUND BALER. What is ?
Do you mean the driveline protection shear pin (pickup, roll the bale and wrap it) or the overfill protection shear pin?
For the driveline shear pin, check the type of pickup that you have. Make sure that you have the correct shear pin for the pickup (wide or regular). Also check the year of your baler, there are substitute shear bolts available that do not work on a range of the 853 baler. New Holland has a parts list for the baler on their site. Start at http://partstore.agriculture.newholland.com/us/ and use the Look up parts by equipment on the left of the page or see your manual. Next check the air bag pressure. (Make sure that you are in the operating range with a regular pressure gauge. It's possible for the gauge on the baler to read low.) If the pressure is out of the operating range, the roller bars can hit other parts of the baler and cause the shear pin to break.
If your baler uses net wrap, make sure that the wrap isn't caught in the unit. (If the knife doesn't cut the net wrap, it will get caught in the tailgate and the rest of the baler. If it tears in use, it may wrap around the pickup and cause the shear pin to break.) This may apply to twine as well but I do not have experience with it happening with the twine tied 853 baler.)
For the rest of the checks, you will have to remove any bale that is in the baler. If it is large enough it may roll out even if it isn't wrapped when the tailgate is up (try driving up hill). Otherwise, you need to pull, cut or pry the bale out. Standing on the kicker can help the bale roll out if sufficient weight is added. We've found that a spare bale spear works well. Removing the hay in small sections can also work.
What is the moisture of the bale? If the bale is too wet, it will be too heavy and shear the pin before the bale chamber is full.
Next check all of the roller bars in the unit. If any are bent significantly, that one can hit another part of the baler and break the shear pin. It's possible to straighten some of the bars out depending on the damage. If the bar is S-shaped or severely bent, replace it. (Your New Holland parts store may have someone who will demonstrate the technique for bar straightening. It involves hammering the bar straight when it is securely held in a vise. If you can hold the bar safely, I've also seen a bucket on a front-loader straighten the bars.) If a rock gets past the windrow guard, the bars can get bent.
Check that the chains are centered and that none of the gears are shifted to narrow or wider paths in a spot. (There are bars that can be adjusted between two sets of gears near the top front of the baler. Loosen the four bolts and push the parts closer or pull them farther apart.) Check that none of the bearings for the apron motion are frozen or damaged. Replace or repair anything that is damaged.
Do not make the bales too large or uneven. (If you have a Bale Command unit on the baler, it is easier to control the even formation of the bale.)
For the overfill protection, make sure to reset the unit after replacing the shear pin. It can be tough to pull the trip arm fully back. Make sure that nothing is in the tailgate. If your baler has a kicker, make sure that that the two springs on the sides are undamaged and holding the kicker level.
I hope this helps.
(my 853 baler with the wide pickup uses Driveline shear pin 46520 and Overfill shear pin 46047. I'm not sure of the year of the unit. When we got shear pins with a different number, we broke 3 or 4 in a row before realizing that we'd gotten the wrong ones; they were noticably thinner than the required ones. Roller bars are what I call the bars between the chains and we've replaced/straightened many of them.)
Aug 09, 2011 | Computers & Internet
Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
355 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
