Question about Compaq (253219-002) Motherboard
Compaq 252608-001 motherboard
I bought a used motherboard with no manual, i'm having some trouble in connecting the power switch cable, power led cable, cpu led cable.
can u help me?
thanks
  • Anonymous Nov 24, 2008
    I got the same problem, I can't find anything you have written like pwr switch or hddled
Its not written on the board...
All that's written on it is the P codes, which are damn hard to read as it is, never mind trying to read anything on it...
Spkr and HDLED, and PWRLED are all marked, but the pwr and reset arent... or if they are, i cant find them
Posted on Jun 07, 2008
  • 655 Answers
Hello sosumo,
see carefully on the board there might be some sign like:
  • HDD-LED
  • PWR SWTCH
  • SPKR
  • RSET
  • PWR LED
These are the points on your board where you have to connect frontpanel connections.
For more details goto HP website and search manual for your product using your board's model no.
Thanks
Iqbal
Posted on Apr 21, 2008
Hp8710w
Have it checked in service. This could shortcircuit the display and burn it
Oct 12, 2012 | HP Hewlett-Packard Compaq 8710w Mobile...
Front panel wiring diagram ie power switch reset switch etc
HP Support > Compaq Presario SR5501F > Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01237538&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3740354
The motherboard is made by ECS for HP/Compaq
ECS model number is MCP61PM-HM
HP/Compaq's name is Iris 8.
There is no wiring diagram per se to give you.
I'll have to detail the wiring connections step by step for you.
This may be a little lengthy.
On the link above you are looking at a photo of your motherboard.
There is also an illustration available.
I would like you to copy, and save them both.
Using this method you will be able to enlarge them for further clarity, of the connections to the motherboard.
Right-click on the motherboard photo. Left-click on Save Image As, in the list.
In the Save Image window that comes up, you will see the heading File name:
To the right of File name: will be c01237541.
Unless you want to search for c01237541 you may wish to do this:
Put your mouse cursor after the 1 in c01237541.
Left-click twice.
Make one space with your spacebar.
Type Compaq Presario SR5501F Mobo photo.
(Mobo stands for MOtherBOard)
You want this photo to go to your My Pictures folder.
(Windows XP. Different for Vista)
At the top of the Save Image window is the heading - Save in:
In the box to the right you should see - My Pictures
If you do Not you will have to change the destination.
Left-click on the blue down arrow to the right of the box.
In the list, left-click on - My Documents, then left-click on - My Pictures.
Now go to the bottom right of the Save Image window, and left-click on Save.
In the link, scrolling down you will see the heading - Motherboard layout
Left-click on the + sign next to Motherboard layout.
Copy and save it as you did for the motherboard photo.
In the File name: box type - Compaq Presario SR5501F Mobo Illustration.
Now all you have to do is go to your My Pictures folder (Start>My Pictures), and double-click on the photo, or illustration.
Left-click on the Zoom In icon at the bottom of the window to enlarge.
(+ sign in a magnifying glass icon)
Wiring Connections to the Motherboard:
A) Front Panel header: (Panel 1)
The Front Panel, is the plastic front of your computer where the Power On button, HarDDrive LED light, and Power On LED light is located.
The Front Panel header is the connections, or pins, on the motherboard, where the cables (Wires) go to from the Front Panel.
On the motherboard illustration it is marked as Panel 1.
(Down in the bottom right corner)
On your motherboard, Panel 1 (Front Panel header) is Black in color.
As you can see it is a rectangular block, and is placed vertically.
Has 2 columns of pins.
5 in the left column, 4 in the right column.
The Left column is numbered Odd.
Starting at the Top going down, Pins 1, 3, 5, 7, and 9
The Right column is numbered Evenly.
Starting at the top going down, Pins 2, 4, 6, and 8.
Pins 1 and 3 are for the HarDDrive LED light.
(HDD activity LED)
Pin 1 is for the Positive connection ( + )
Pins 5 and 7 are for the Reset switch.
Pin 7 is for the Positive connection. ( + )
Pin 9 is reserved, and may not be used.
Pins 2 and 4 are for the Message LED light. (LED = Light Emitting Diode)
Power On LED light.
Pins 6 and 8 are for the Power On switch.
There is No Pin 10.
If the cables (Wires) are not marked coming from the Front Panel, you will have to remove the Front Panel, and trace where they go.
You will be able to physically see where wires go to the Power On switch, Power On LED light, HarDDrive activity LED
Sep 21, 2011 | HP Compaq d530 SFF PC Desktop
I would like to see an inside wiring diagram to see if I plugged something in wrong or not
If this problem is in direct relation to a Compaq Presario SR5501F desktop computer;
Left-click twice.
(HDD activity LED)
Power On LED light.
There is No Pin 10.
You will be able to physically see where wires go to the Power On switch, Power On LED light, HarDDrive activity LED light, and so on.
B) 24-pin ATX main power cable:
Only plugs in one direction. Plugs next to the blue IDE connector on the motherboard. (To the right of the ram memory slots)
C) 4-pin ATX +12 Volt power cable.
Looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Plugs into the whitish square 4 socket hole connector on the motherboard, next to the Processor socket.
(On the motherboard illustration this connector is labeled - ATX12V1
D) Processor Fan:
Connects to the 3-pin CPU header on the motherboard. Right above the ram memory slots.
E) Harddrive:
You have a SATA harddrive. (500GB in size)
Connects to the SATA 1 header on the motherboard.
The SATA 1 header on the motherboard is Black in color.
The data interface cable has 7 pins.
Looks similar to this, (May not have a 90 degree elbow though),
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
The SATA power cable has 15 pins.
Looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
If your SATA harddrive has a place for a SATA power cable, AND a 4-pin Peripheral power cable, DO NOT plug both power cables in!!
This will lead to damage of the SATA harddrive!
The standard 4-pin Peripheral power cable looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The standard 4-pin Peripheral power cable connector, has had a misnomer for years as a Molex connector.
Molex was the first design implemented when this style of connector came out.
The name stuck.
It is the same as calling an adjustable open-end wrench a Crescent wrench)
F) Optical drives:
If you have a DVD burner drive it plugs into the SATA header 2.
(Uses the same style of SATA data interface cable, as the SATA harddrive)
If any of your optical drives are IDE, they plug into the blue IDE header, next to the ram memory slots.
This is what a flat ribbon IDE data interface cable looks like,
http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
(You can click on the photo to enlarge. You can enlarge twice)
G) The Floppy Disk drive, (If your computer came with one), plugs into the FDD connector shown on the motherboard illustration.
(Black in color, right above the 24-pin ATX main power cable connector)
Do you need information on the USB connections?
Post in a Comment.
Jul 07, 2010 | HP Compaq Presario SR5501F Athlon 64 X2...
How can I connect power switch and LED indicators
u need the user manual or see the board there is information on board
this are the connector u have to connect this pin to front pannel
Nov 14, 2009 | Compaq ( 277498-001) Motherboard
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
f_Panel
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
Need to find out where the on/off cables hook to a 277977-001 motherboard by compaq
Generaly, the little connectors on the printed side will face the bottom of the case. Also, typically, Black is negative, and white/colour is positive (except on the power sw, it doesn't matter). On the motherboard, where the connectors go, there should be some kind of print saying where to plug them in. (IE, POWER SW, would go into PWR, and HDD LED would go into HDLED and POWER LED would go into PWRLED).
It may look different than this, but generally the same kind of layout, as you can see, it shows the positions, as well as positive and negative.
Unfortunetely, I can't seem to find a schematic for the Compaq 277977-001 motherboard. I will try and find one, but I hope this helps you out with what you are trying to do...
Sep 05, 2008 | Intel DG965RY Motherboard
Pin alignment on motherboard for led switches
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
Front panel green LED
HDA#
Out
Hard disk active LED
HDR_BLNK_YEL
Out
Front panel yellow LED
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Apr 01, 2008 | Compaq (283983-001) Motherboard
Compaq presario 158793-001 motherboard
Hey Mike
Go back and check the fine cabling that connects LED indicaters to motherborad. There's got to be a small cable you forgot to plug into the board to feed back poer state. Take your time and check everything twice.
Dec 12, 2007 | HP (158800-001) for Compaq Presario 1246,...
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
Compaq (253219-002) Motherboard Logo
740 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
