Question about Samsung P30 Notebook
I can't load flash drive which contains bootable windows xp, i already set in bios first boot device to Flash drive, but it's still can't load, only apears black screen with only one blinking blank. please help, what i gotta do to boot windws? p.s. which is safe mode key in Samsung P30 Notebook?
  • 69 Answers
I would assume you made the flash drive bootable and did not just copy windows onto it,,
if you didnt make the flash drive bootable it simply wont work
go here for more info
Posted on Jul 17, 2010
How to boot with usb flash drive. detailed please, I'm trying to many diff ways nothing working, bios is the only thing on comp.
It is possible to boot from a USB drive....but only if the USB drive has been formatted as bootable, in the same way that OS CDs and DVDs are bootable media. You have to have an operating system either on the hard drive or on the flash drive in order to boot the computer. The BIOS is simply a "Basic Input-Output System" that interfaces the computer hardware to the OS, whatever media it is on. That is why you have to select the boot device and the boot device priority in the BIOS during setup, so it can direct itself to the bootable OS. Once you have installed an OS, then all will work fine. Until then, you will continue to have issues. Normally, with Window-based systems (you don't say what OS you are trying to use), you would insert the bootable Windows setup disk in the CD/DVD drive, ensure the BIOS was set to boot to CD/DVD first, and start the computer. The windows setup file would load itself and start the OS install process. It may even be necessary to partition and format the hard drive during this evolution, but the setup program would lead you through that as well. I have seen Windows setup files loaded to USB sticks, but they require a special process to generate so the BIOS sees the USB as bootable.
Jun 26, 2015 | ASUS Computers & Internet
RES. SIR, CAN WE PROPERLY BOOT WINDOWS XP/7 TO PC USING USB PORT(PEN DRIVE/MEMORY CARD)? IF YES THEN PLEASE TELL WHICH BACK UP WE HAVE TO KEEP IN PEN DRIVE (XP IMAGE OR COPY OF DATA),PROVIDE THE VALIDE...
To create a Bootable USB flash drive or pen drive you can try the steps on this website: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
Note: This only works for windows 7 and windows vista.
For BIOS settings you need to set the first boot on USB Device. If you can give me the brand and model of your computer or BIOS version I might be able to give you the step by step information on how to set your first boot on USB Device.
Apr 23, 2011 | Computers & Internet
How to boot hp nx9010 from usb to install windows xp because it's cd drive is not working
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 1-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some bios's may refer to your flash drive as a USB floppy or USB zip. Of course there are exceptions, perhaps some are covered here.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. You "may" have to format your floppy disk first in WinXP before you create a bootdisk as XP may "not" like working later on with a disk formatted otherwise.
7. Included below is a bootable ISO of DOS 7.1 which may be used with some of these methods if you do not have a 1.44 drive.
Nov 17, 2010 | HP Compaq nx9010
How can i make bootable sandisk 4 GB for instalation window xp sp2 please give best solution Tikendra
This is only possible if there is an option in device boot order in the BIOS configuration.
In older motherboards there are no options for booting up with a USB flash drive in a USB port, because there are no USB drivers installed until Windows boots up.
Oct 13, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
An error occured while attempting to read the boot configuration data The above appears on boot-up, how can I make a bootable usb stick in order to copy XP onto it to try and use "repair" to rix the...
U will have to extract the Windows CD to a file folder on your pc. Run Nlite to make a bootable file to load to ur flash drive. Then u will need to set ur bios to boot from USB device. Mainly needing the Boot.INI
Aug 16, 2010 | Advent 4211c Notebook
I want to format my pc but when xp pro bootable cd inserted and tried to boot it simpely boot in normal xp n there is no message saying "press any key to boot from cd". My 1st boot device is cd 2nd is hdd
My first suggestion would be to clean your XP disk and make sure there are no scratches on it.
Then depending on the BIOS of your machine when starting up press either F10 or F12 to enter the boot device menu there select your cd and hit enter.
This should fix your problem for you
Jul 02, 2010 | Microsoft Windows XP Professional
I was trying to boot my pc from usb but it was noot bootable how to make usb drive bootable
Have had loads of usb media, as far as I know some USB sticks are bootable others are not, usually it will say either on the manual or on the box of the product whether its bootable. If it is bootable format the usb drive fully then copy the BOOT.INI, NTLDR, and NTDETECT from the root directory of your PC's boot drive to the flash drive. These files are hidden by default, so you will either have to configure Windows Explorer to show hidden files (including protected operating system files) or you will have to open a Command Prompt window and use the COPY command to copy the files. If you choose to use the Windows Explorer method, then open Internet Explorer and enter C: into the address bar so that you are looking at your local hard drive. Next, select the Folder Options command from the Tools menu. When the Folder Options properties sheet opens, select the View tab. Now, just select the Show Hidden Files and Folders and deselect the Hide Extensions for Known File Types and the Hide Protected Operating System Files check boxes. Click OK to continue.
Now that you have formatted your USB flash drive and installed the boot files onto it, the next thing that you must do is to configure your PC to allow you to boot from the flash drive. This is all done through the computer's BIOS Setup. I can't give you specific instructions for this part, because every computer is different. I can give you a few pointers though.
You can access your computer's BIOS by pressing a specific key immediately after you turn the PC on. The key varies, but it is usually either [F1], [F2], or [Delete]. Once you are in the BIOS Setup, you should verify that all of your computer's USB options are enabled. This might include things like support for legacy USB devices or support for USB 2.0. If there is a time out setting for USB devices, you should set it to the max to insure that the system doesn't time out while waiting on the USB device to boot.
Next, find the section on boot device priority. Normally, a USB flash drive (which is usually listed as USB-HDD, but may be listed as a removable device) will have a very low boot priority. If the USB flash drive's boot priority is lower than the hard disk (listed as HDD) then the only time the computer would ever boot off of the USB flash drive is if the system were to fail to boot from the hard disk. You must therefore rearrange the boot device priority so that the flash drive has a higher priority than the hard drive.
Jul 01, 2009 | SanDisk Computers & Internet
I can't use this as a bootable device with Windows XP.
Dear,
Not every PC is capable of booting from a USB flash drive. For the most part, computers manufactured within the last two years are generally able to boot from a flash drive. Older systems may require a BIOS update, or might not be able to boot from a flash drive at all.
Drive must be formatted with FAT file system.
For your systen you need an internal Hard drive.
Regards,
Rakesh Kumar
Apr 08, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Bootable files
When a computer is powered on, the BIOS ("basic input output system") has only a few commands available to it, and the main one is to search for a "boot device" - a storage device which contains "bootable files". The first device it finds with "boot records" is used to load the operating system.
Usually this is the C drive, but could also be a floppy, USB flash memory, or CD.
In order to get the boot records onto a device, a special option must be used when the device is formatted. This boots the boot records in a place where the BIOS knows to look for them.
So, a bootable file (or "bootable device") is a storage device which has been set up with these boot records.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Samsung P30 Notebook Logo
136 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
