Question about Maxtor Hard Drive
Maxtor hard drive diamondmax plus 9 ata
What is the master pin setting for this unit please
Regards
  • 724 Answers
closest to the cable are the master
like jed said the lable has this info
Posted on Aug 19, 2010
  • 177 Answers
Usually the PIN settings are indicated on top of the drive. Have a good look at the sticker. Hope this helps.
Posted on Jul 17, 2010
My Maxtor DiamondMax Plus 9 80GB ATA/133 HDD with a X-Media USB2.0 TO IDE & SATA cable adapter
Check (under high light) flat IDE cable pins on the mini-board. Many pins, and many chance to loose contact.
Feb 10, 2014 | Computers & Internet
Which are the slave pins on Maxtor diamondMax Plus 9 160GB ATA/133 HDD harddrive???????????
Look for a grid of gold-coloured pins between the power-connector and the data-connector.
Look CLOSELY at the engraving on the top of the disk-drive, near those pins,
looking for 'MA(ster)' or 'SL(ave)' or 'C(able)S(elect)'.
Or, especially for MAXTOR drives, read the text printed on the label on the top of the disk,
for the "pairs" of pins that need to be set.
Nov 08, 2010 | Maxtor Hard Drive
How to set jumper to slave mode on maxtor 6y080m0(picture pls)
These are the jumper settings for a Maxtor Diamond Max ATA hard drive.
Sep 23, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 Hard Drive ATA/133 HDD Internal HD not reconizing in any computer .think it is not getting any power to HD so the PCB Board i think might be gone.any help be...
Power comes from the power supply. Check yellow and black and red and black. You need both 5v and 12v. Are you sure you have the jumper set correctly for the application? Master or single - master with slave present or some computers require CS (cable select)
Dec 05, 2009 | Maxtor Hard Drive
Is the maxtor 6y120p0 a ata or sata format
Maxtor DiamondMax Plus 9 120GB 7200RPM IDE Ultra ATA-133 3.5-Inch Internal Hard Drive Mfr P/N 6Y120P0
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Diamondmax plus 9 120gb hard drive
IF THIS IS AN ATA TYPE DRIVE (please verify this from you drive's documentation or labeling) -- you may need to review the following link to determine the proper method to install your new drive. This review should also take into account any documentation received with the drive. There are several variations of drive issues that cause the drive to register as the incorrect size described in the link. If you have questions please add them as a comment to this issue and we can review them before you take any unwise actions with this drive. Read the page carefully there are as stated before multiple reasons for this type of issue and multiple resolutions. Seagate acquired Maxtor so this link could be appropriate.
ATA 32GB Drive Issues
Dec 14, 2007 | Maxtor Open Box 120GB DiamondMax Plus 9...
Maxtor Hard Drive Logo
96 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
